Smappee
matteos1
Smappee
Post by matteos1 » Tuesday 03 April 2018 10:28
is it possible to introduce smappee in domoticz natively?
matteos1
Re: Smappee
Post by matteos1 » Friday 06 April 2018 7:46
anyone that have resolved this?
Egregius
Re: Smappee
Post by Egregius » Friday 06 April 2018 8:31
Use a script to query the smappee and push the data to domoticz.
Egregius
Re: Smappee
Post by Egregius » Friday 06 April 2018 10:19
This is what I do with it:
<?php
$smappee=json_decode(file_get_contents('http://192.168.2.19/gateway/apipublic/reportInstantaneousValues'),true);
if(!empty($smappee['report'])){
	$zon=apcu_fetch('zon');
	preg_match_all("/ activePower=(\\d*.\\d*)/",$smappee['report'],$matches);
	if(!empty($matches[1][1])){
		$newzon=round($matches[1][1],0);
		if($newzon<0)$newzon=0;
		if($zon!=$newzon)apcu_store('zon',$newzon);
		if(!empty($matches[1][2])){
			$consumption=round($matches[1][2],0);
			if($consumption!=apcu_fetch('verbruik'))apcu_store('verbruik',$consumption);
			$timestamp=strftime("%Y-%m-%d %H:%M:%S",time());
			$query="INSERT INTO `smappee` (`timestamp`,`consumption`) VALUES ('$timestamp','$consumption');";
			$db=new mysqli('127.0.0.1','domotica','domotica','domotica');if($db->connect_errno>0)die('Unable to connect to database [' . $db->connect_error . ']');if(!$result=$db->query($query))die('There was an error running the query ['.$query .' - ' . $db->error . ']');$db->close();
			if($consumption>8000){
				if(past('notify_power')>3600){
					apcu_store('Tnotify_power',time());
					telegram('Power usage: '.$consumption.' W!',false);
}else{
	if(shell_exec('curl -H "Content-Type: application/json" -X POST -d "" http://192.168.2.19/gateway/apipublic/logon')!='{"success":"Logon successful!","header":"Logon to the monitor portal successful..."}')exit;
function past($name){return time()-apcu_fetch('T'.$name);}
function telegram($msg,$silent=true,$to=1){
	$msg=str_replace('__',PHP_EOL,$msg);
	shell_exec('/var/www/html/secure/telegram.sh "'.$msg.'" "'.$silent.'" "'.$to.'" > /dev/null 2>/dev/null &');
Above script is executed every 10 seconds. It gives me the current power consumption and solar power. The data is stored in a SQL database and is the consumption is more than 8000W I receive a message.
And then in a cron job that runs every 2 minutes:
$timefrom=time-86400;
$chauth = curl_init('https://app1pub.smappee.net/dev/v1/oauth2/token?grant_type=password&client_id='.$smappeeclient_id.'&client_secret='.$smappeeclient_secret.'&username='.$smappeeusername.'&password='.$smappeepassword.'');
curl_setopt($chauth,CURLOPT_AUTOREFERER,true);
curl_setopt($chauth,CURLOPT_RETURNTRANSFER,1);
curl_setopt($chauth,CURLOPT_FOLLOWLOCATION,1);
curl_setopt($chauth,CURLOPT_VERBOSE,1);
curl_setopt($chauth,CURLOPT_SSL_VERIFYHOST,false);
curl_setopt($chauth,CURLOPT_SSL_VERIFYPEER,false);
$objauth=json_decode(curl_exec($chauth));
if(!empty($objauth)){
	$access=$objauth->{'access_token'};
	curl_close($chauth);
	$chconsumption=curl_init('');
	curl_setopt($chconsumption,CURLOPT_HEADER,0);
	$headers=array('Authorization: Bearer '.$access);
	curl_setopt($chconsumption,CURLOPT_HTTPHEADER,$headers);
	curl_setopt($chconsumption,CURLOPT_AUTOREFERER,true);
	curl_setopt($chconsumption,CURLOPT_URL,'https://app1pub.smappee.net/dev/v1/servicelocation/'.$smappeeserviceLocationId.'/consumption?aggregation=3&from='.$timefrom.'000&to='.time.'000');
	curl_setopt($chconsumption,CURLOPT_RETURNTRANSFER,1);
	curl_setopt($chconsumption,CURLOPT_FOLLOWLOCATION,1);
	curl_setopt($chconsumption,CURLOPT_VERBOSE,1);
	curl_setopt($chconsumption,CURLOPT_SSL_VERIFYHOST,false);
	curl_setopt($chconsumption,CURLOPT_SSL_VERIFYPEER,false);
	$objconsumption=json_decode(curl_exec($chconsumption),true);
	if(!empty($objconsumption['consumptions'])){
		$verbruikvandaag=$objconsumption['consumptions'][0]['consumption']/1000;
		apcu_store('verbruikvandaag',round($verbruikvandaag,1));
		$zonvandaag=$objconsumption['consumptions'][0]['solar']/1000;
		apcu_store('zonvandaag',round($zonvandaag,1));
		$gas=apcu_fetch('gasvandaag')/100;
		$water=apcu_fetch('watervandaag')/1000;
		@file_get_contents("https://xxx.xxx.xxx/secure/insertdata.php?user=xxx&verbruik=$verbruikvandaag&gas=$gas&water=$water&zon=$zonvandaag");
		lg("verbruik => gas = $gas | verbruik = $verbruikvandaag | zon = $zonvandaag | water = $water");
	curl_close($chconsumption);
Here I grab the daily totals and push them to php cache so I can see them on my floorplan and they're sent to a site where I monitor consumptions together with some friends.
matteos1
Re: Smappee
Post by matteos1 » Friday 06 April 2018 19:40
if would i control the plug?
Egregius
Re: Smappee
Post by Egregius » Friday 06 April 2018 19:48
You didn't specify that...
I don't have any smappee plugs but I guess you can easily grab the url from developper console from your browser.
simonrg
Target OS: Raspberry Pi
Domoticz version: 3.8807
Re: Smappee
Post by simonrg » Saturday 07 April 2018 0:09
Have you looked in the Wiki?
https://www.domoticz.com/wiki/Smappee
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Egregius
Re: Smappee
Post by Egregius » Saturday 07 April 2018 5:29
@simonrg
If you remove the code block the link will be clickable.
simonrg
Re: Smappee
Post by simonrg » Saturday 07 April 2018 15:50
@simonrg
Thanks, I meant to use:
[url]http://www.domoticz.com/wiki[/url]
not the code one, as just pasting in the url leads to truncation, so you can't see where you are going.
matteos1
Re: Smappee
Post by matteos1 » Thursday 10 May 2018 12:32
this is new specific send by smappe organizzation to me to control plug with mqtt system
Smappee local MQTT topics - 20180209 (1).pdf
(23 KiB) Downloaded 9 times
if someone can create script to control plug with mqtt system
thank a lot
MQTT broker configuration on Smappee Plus Pro (1).pdf
(190.71 KiB) Downloaded 9 times
simonrg
Re: Smappee
Post by simonrg » Thursday 17 May 2018 23:20
Great, I haven't used MQTT at all, but it looks like it should simple to talk to Smappee via MQTT.
However, there needs to be some programming to translate Smappee MQTT messasges which into MQTT messages which Domoticz would understand and for Domoticz MQTT to be transleted for Smappee.
Time to read the wiki - https://www.domoticz.com/wiki/MQTT and look at other people using MQTT https://www.sigmdel.ca/michel/ha/domo/domo_03_en.html.
I sse you have already posted in the MQTT support thread - http://www.domoticz.com/forum/viewtopic ... &start=320
