[REQUEST] Plugin for Tuya
frenchyyii
Target OS: Raspberry Pi
Re: [REQUEST] Plugin for Tuya
Post by frenchyyii » Saturday 20 October 2018 1:45
For the moment I do not find bugs but I'll try to make some more tests with scenes etc...
For the 1/2/3 On/Off yes I think It should be usefull as in domoticz Master/slave does not work (the switchs on DZ changes but the sockets do not activate/desactivate). If I use group mode it works but it's not clean. In fact this multiplug is quite usefull for the price but there is no "keep USB ON or Off" in the app. Each time you switch off in the app you switch everything, it should be better to be able to switch only the 220v sockets without switching USB. As I can see you could do it using your code.
Really thanks for all that work, I was going to wire another model of esp, or rewriting the code of the original one but I would have lost the Tuya apps fonctions. Your work is really great to avoid the DIY mods on a 220V hardware (that should be risky)
Have a good rest ;)
Eric
tixi7
Post by tixi7 » Sunday 28 October 2018 8:15
I put a new version on github where i removed hard coded stuff.
Do not try to use domoticz groups with the multiplug version, it may result in anormal behavior.
When i will have time, i will try to provide groups inside the plugin.
I guess 2 optional and configurable groups is enough, 1 for outlet and 1 for usb. what do you think?
Seidel
Post by Seidel » Tuesday 06 November 2018 3:06
How can you add slaves plug ??
frenchyyii tu es français ? Peux-tu m'aider ?
tixi7
Post by tixi7 » Tuesday 06 November 2018 6:18
Once again I put a new version for multiplug.
I guess now the domoticz's group function can be used.
Like before, I cannot test it so let me know for bugs.
Seidel, you should be able to use slave for single and multi plug like for other devices.
Seidel
Post by Seidel » Tuesday 06 November 2018 8:41
sudo python3 get_dps.py 192.168.0.15 DEVID
Plug State Information:
{'devId': 'xxxxxxxxxxxxxxx', 'dps': {'1': True, '2': 0}}
Plug DPS List:
1
But I've 2 slaves plugs... On the Tuya app, they appear.
Why not here ?
Seidel
Post by Seidel » Tuesday 06 November 2018 21:04
2018-11-06 20:03:34.024 (Tuya SmartPlug) Pushing 'onHeartbeatCallback' on to queue
2018-11-06 20:03:34.041 (Tuya SmartPlug) Processing 'onHeartbeatCallback' message
2018-11-06 20:03:34.041 (Tuya SmartPlug) Calling message handler 'onHeartbeat'.
2018-11-06 20:03:34.043 (Tuya SmartPlug) Pushing 'WriteDirective' on to queue
2018-11-06 20:03:34.043 (Tuya SmartPlug) Processing 'WriteDirective' message
2018-11-06 20:03:34.043 (Tuya SmartPlug) Sending 86 bytes of data
2018-11-06 20:03:34.043 (Tuya SmartPlug) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 67 77 ..U�...........F{"gw
2018-11-06 20:03:34.043 (Tuya SmartPlug) 49 64 22 3a 22 30 32 37 35 30 38 30 31 38 34 66 33 65 62 35 Id":"0275080184f3eb5
2018-11-06 20:03:34.043 (Tuya SmartPlug) 32 34 35 64 33 22 2c 22 64 65 76 49 64 22 3a 22 30 32 37 35 245d3","devId":"0275
2018-11-06 20:03:34.043 (Tuya SmartPlug) 30 38 30 31 38 34 66 33 65 62 35 32 34 35 64 33 22 7d 00 00 080184f3eb5245d3"}..
2018-11-06 20:03:34.044 (Tuya SmartPlug) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-11-06 20:03:34.048 (Tuya SmartPlug) Pushing 'ReadEvent' on to queue
2018-11-06 20:03:34.094 (Tuya SmartPlug) Processing 'ReadEvent' message
2018-11-06 20:03:34.094 (Tuya SmartPlug) Received 83 bytes of data
2018-11-06 20:03:34.094 (Tuya SmartPlug) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 43 00 00 00 00 ..U�...........C....
2018-11-06 20:03:34.095 (Tuya SmartPlug) 7b 22 64 65 76 49 64 22 3a 22 30 32 37 35 30 38 30 31 38 34 {"devId":"0275080184
2018-11-06 20:03:34.095 (Tuya SmartPlug) 66 33 65 62 35 32 34 35 64 33 22 2c 22 64 70 73 22 3a 7b 22 f3eb5245d3","dps":{"
2018-11-06 20:03:34.095 (Tuya SmartPlug) 31 22 3a 74 72 75 65 2c 22 32 22 3a 30 7d 7d 4c 3d af 89 00 1":true,"2":0}}L=��.
2018-11-06 20:03:34.095 (Tuya SmartPlug) 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .�U
2018-11-06 20:03:34.095 (Tuya SmartPlug) Pushing 'onMessageCallback' on to queue
2018-11-06 20:03:34.095 (Tuya SmartPlug) Processing 'onMessageCallback' message
2018-11-06 20:03:34.095 (Tuya SmartPlug) Calling message handler 'onMessage'.
2018-11-06 20:03:34.096 (Tuya SmartPlug) onMessage called: 192.168.0.15:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00C\x00\x00\x00\x00{"devId":"0275080184f3eb5245d3","dps":{"1":true,"2":0}}L=\xaf\x89\x00\x00\xaaU'
2018-11-06 20:03:34.096 Error: (Tuya SmartPlug) 'onMessage' failed 'KeyError'.
2018-11-06 20:03:34.096 Error: (Tuya SmartPlug) ----> Line 306 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onMessage
2018-11-06 20:03:34.096 Error: (Tuya SmartPlug) ----> Line 229 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onMessage
What is the problem ??
tixi7
Post by tixi7 » Wednesday 07 November 2018 5:14
Seidel, can you send me a link to have the description of your devices.
The log and get_dps.py script show that you have a single plug.
Are you using the single plug version of the plugin or the multiplug version?
How many physical plugs do you have?
Can you describe a bit more what you want to achieve?
manutremo
Post by manutremo » Thursday 08 November 2018 9:37
I have one of those multiplug devices that works with the Tuya app. This one has 4 plugs and a group of USBs.
My Domoticz runs on a Synology. I installed the plugin following the procedure and modifying the necessary paths accordingly. pycrypto can not be installed in Synology but I have installed pycryptodome. The plugin is apparently starting but only one device is created for the full device. If I turn debug on I get a long list of messages but no errors; however after some minutes domoticz just hangs.
Is there anyone that is running this plugin into a synology box that can help me?
Thx!
DAVIZINHO
Post by DAVIZINHO » Friday 09 November 2018 1:01
hello!
i have a new smart plug (4 plugs and 4 usb) and im trying to configure this plugin.
In firs place sorry for my poor english, is not my natural languaje.
I install this plugin:
https://github.com/tixi/Domoticz-Tuya-SmartPlug-Plugin
is this the correct? or this is for single plug and there is another for multiplug?
thanks!
tixi7
Post by tixi7 » Friday 09 November 2018 6:02
For multiplug, the version to use is:
https://github.com/tixi/Domoticz-Tuya-S ... /multiplug
But have in mind that this version is still in test mostly because I do not have such a kind of plug.
Bug report are welcome.
For bug report, please provide:
- the domoticz version,
- the platform you are using (rpi...) If possible an url to the description of the product if it is not rpi (I need the processor description and the amount of ram)
- an url to the plug (amazon...)
- description of the problem
- logs with debug mode
tixi7
Post by tixi7 » Friday 09 November 2018 6:09
Thx!
Can you send the description of the synology box you are using? and the domoticz version?
You can try to use pyaes:
https://github.com/ricmoo/pyaes
Instead of pycrypto since the pytuya library is also defined for it.
If the problem still exist, can you try to change the value of __HB_BASE_FREQ to 6 inside the plugin
manutremo
Post by manutremo » Friday 09 November 2018 16:33
My synology is a DS1513+. Domoticz is v4.10078.
I have unistalled pycrytodome and installed pyaes. No I get error:
2018-11-09 15:19:36.614 Error: (tixi_tuya_smartplug_plugin) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/Domoticz-Tuya-SmartPlug-Plugin-multiplug/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.
2018-11-09 15:19:36.614 Error: (Regleta) Module Import failed, exception: 'ImportError'
2018-11-09 15:19:36.614 Error: (Regleta) Module Import failed: ' Name: pyaes'
2018-11-09 15:19:36.614 Error: (Regleta) Error Line details not available.
In synology, python modules are installed in /volume1/@appstore/py3k/usr/local/lib/python3.5/site-packages. Now there is no Crypto folder here of course since no pyCrypto nor pyCryptodome are installed.
Should I create a symbolic link in the plugin folder like:
ln -s /volume1/@appstore/py3k/usr/local/lib/python3.5/site-packages/pyaes Crypto
or
ln -s /volume1/@appstore/py3k/usr/local/lib/python3.5/site-packages/pyaes pyaes
manutremo
Post by manutremo » Friday 09 November 2018 18:35
Ok I respond to myself - I managed to make it work installing pyaes and then doing
in the plugin folder.
However I don't think this was the cause of my problems. I also discovered as part of the investigation that my localKey was wrong :D ... so it may also work with pycryptodome... I just didn't try, if it works do not touch it.
Now it is working perfectly with this device:
https://www.amazon.es/gp/product/B078W2 ... TF8&psc=1
Great work, many thanks!
vrega
Post by vrega » Sunday 11 November 2018 17:43
I've a tuya bulb.
I've installed the Smart-Bulb plugin and it does not give me errors.
I've added the lamp switch but i cannot power on and off the bulb.
If i power on and off the bulb via the tuya app it works well and the status on the domoticz switch is updated.
Also,after some minutes, Domoticz stop working and i need to restart it.
Can you help me to solve the problem?
Regards.
vrega
DAVIZINHO
Post by DAVIZINHO » Sunday 11 November 2018 19:42
EDIT my message:
I delete the previous installal and make a new git clone -b with the branch of multiplug.
Now im testing.
EDIT AGAIN:
Now i have the 4 switches in my domoticz. and if i turn on or off in the tuya android app, the domoticz update the status of the switches.
But if i change the status in domoticz (power on, or power off) nothing ocurrs. I think the problem is mine, maybe i forget something?
For bug report:
- the domoticz version: beta: 4.10198
- the platform you are using: Raspberry pi3b+
- an url to the plug: https://es.aliexpress.com/item/Cable-de ... 86078.html
- description of the problem: i push the power on in a switch and nothing occurs
 2018-11-11 22:00:33.860 Status: User: Admin initiated a switch command (248/Fri_Regleta - Tuya SmartPlug #7/On)
2018-11-11 22:00:35.792 (Fri_Regleta) 31 22 3a 74 72 75 65 2c 22 32 22 3a 74 72 75 65 2c 22 33 22 1":true,"2":true,"3"
2018-11-11 22:00:35.792 (Fri_Regleta) 3a 74 72 75 65 2c 22 34 22 3a 74 72 75 65 2c 22 37 22 3a 66 :true,"4":true,"7":f
2018-11-11 22:00:35.792 (Fri_Regleta) 61 6c 73 65 2c 22 31 30 31 22 3a 30 2c 22 31 30 32 22 3a 30 alse,"101":0,"102":0
2018-11-11 22:00:35.792 (Fri_Regleta) 2c 22 31 30 33 22 3a 30 2c 22 31 30 34 22 3a 30 2c 22 31 30 ,"103":0,"104":0,"10
2018-11-11 22:00:35.792 (Fri_Regleta) 35 22 3a 30 7d 7d 60 bc 99 33 00 00 aa 55 .. .. .. .. .. .. 5":0}}`��3..�U
2018-11-11 22:00:35.793 (Fri_Regleta) Pushing 'onMessageCallback' on to queue
2018-11-11 22:00:35.793 (Fri_Regleta) Processing 'onMessageCallback' message
2018-11-11 22:00:35.793 (Fri_Regleta) Calling message handler 'onMessage'.
2018-11-11 22:00:35.793 (Fri_Regleta) onMessage called: 192.168.1.85:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x8a\x00\x00\x00\x00{"devId":"17007751600194afc4b0","dps":{"1":true,"2":true,"3":true,"4":true,"7":false,"101":0,"102":0,"103":0,"104":0,"105":0}}`\xbc\x993\x00\x00\xaaU'
2018-11-11 22:00:35.794 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:35.795 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:35.795 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:35.795 (Fri_Regleta) Sending 171 bytes of data
2018-11-11 22:00:35.795 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 9b 33 2e 31 35 ..U�...........�3.15
2018-11-11 22:00:35.795 (Fri_Regleta) 62 66 35 64 66 65 36 37 38 31 63 63 66 31 32 76 38 2b 6f 50 bf5dfe6781ccf12v8+oP
2018-11-11 22:00:35.795 (Fri_Regleta) 57 57 53 48 7a 77 46 4b 77 41 59 7a 65 72 35 6f 70 57 65 73 WWSHzwFKwAYzer5opWes
2018-11-11 22:00:35.795 (Fri_Regleta) 69 74 32 56 2b 45 56 5a 4e 36 58 33 59 72 6d 39 56 4a 57 68 it2V+EVZN6X3Yrm9VJWh
2018-11-11 22:00:35.795 (Fri_Regleta) 2b 72 61 58 54 4f 53 4d 79 4a 38 42 65 4d 4c 57 75 6b 4b 6e +raXTOSMyJ8BeMLWukKn
2018-11-11 22:00:35.795 (Fri_Regleta) 57 72 2f 37 39 33 61 79 6d 42 6a 6e 74 49 2f 4d 34 35 44 70 Wr/793aymBjntI/M45Dp
2018-11-11 22:00:35.795 (Fri_Regleta) 34 63 79 74 42 6d 55 6d 48 67 73 41 6e 77 6d 59 56 64 67 79 4cytBmUmHgsAnwmYVdgy
2018-11-11 22:00:35.795 (Fri_Regleta) 53 30 33 7a 37 51 49 41 68 75 71 75 35 73 6d 59 34 35 41 59 S03z7QIAhuqu5smY45AY
2018-11-11 22:00:35.795 (Fri_Regleta) 64 4b 2b 00 00 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. dK+......�U
2018-11-11 22:00:35.799 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:35.800 (Fri_Regleta) Sending 86 bytes of data
2018-11-11 22:00:35.800 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-11-11 22:00:35.800 (Fri_Regleta) 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 30 31 39 34 vId":"17007751600194
2018-11-11 22:00:35.800 (Fri_Regleta) 61 66 63 34 62 30 22 2c 22 67 77 49 64 22 3a 22 31 37 30 30 afc4b0","gwId":"1700
2018-11-11 22:00:35.800 (Fri_Regleta) 37 37 35 31 36 30 30 31 39 34 61 66 63 34 62 30 22 7d 00 00 7751600194afc4b0"}..
2018-11-11 22:00:35.800 (Fri_Regleta) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-11-11 22:00:35.998 (Fri_Regleta) Pushing 'ReadEvent' on to queue
2018-11-11 22:00:36.001 (Fri_Regleta) Processing 'ReadEvent' message
2018-11-11 22:00:36.001 (Fri_Regleta) Received 154 bytes of data
2018-11-11 22:00:36.001 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 8a 00 00 00 00 ..U�...........�....
2018-11-11 22:00:36.001 (Fri_Regleta) 7b 22 64 65 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 {"devId":"1700775160
2018-11-11 22:00:36.001 (Fri_Regleta) 30 31 39 34 61 66 63 34 62 30 22 2c 22 64 70 73 22 3a 7b 22 0194afc4b0","dps":{"
2018-11-11 22:00:36.001 (Fri_Regleta) 31 22 3a 74 72 75 65 2c 22 32 22 3a 74 72 75 65 2c 22 33 22 1":true,"2":true,"3"
2018-11-11 22:00:36.001 (Fri_Regleta) 3a 74 72 75 65 2c 22 34 22 3a 74 72 75 65 2c 22 37 22 3a 66 :true,"4":true,"7":f
2018-11-11 22:00:36.001 (Fri_Regleta) 61 6c 73 65 2c 22 31 30 31 22 3a 30 2c 22 31 30 32 22 3a 30 alse,"101":0,"102":0
2018-11-11 22:00:36.001 (Fri_Regleta) 2c 22 31 30 33 22 3a 30 2c 22 31 30 34 22 3a 30 2c 22 31 30 ,"103":0,"104":0,"10
2018-11-11 22:00:36.001 (Fri_Regleta) 35 22 3a 30 7d 7d 60 bc 99 33 00 00 aa 55 .. .. .. .. .. .. 5":0}}`��3..�U
2018-11-11 22:00:36.001 (Fri_Regleta) Pushing 'onMessageCallback' on to queue
2018-11-11 22:00:36.001 (Fri_Regleta) Processing 'onMessageCallback' message
2018-11-11 22:00:36.001 (Fri_Regleta) Calling message handler 'onMessage'.
2018-11-11 22:00:36.001 (Fri_Regleta) onMessage called: 192.168.1.85:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x8a\x00\x00\x00\x00{"devId":"17007751600194afc4b0","dps":{"1":true,"2":true,"3":true,"4":true,"7":false,"101":0,"102":0,"103":0,"104":0,"105":0}}`\xbc\x993\x00\x00\xaaU'
2018-11-11 22:00:36.003 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:36.004 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:36.004 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:36.004 (Fri_Regleta) Sending 171 bytes of data
2018-11-11 22:00:36.004 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 9b 33 2e 31 36 ..U�...........�3.16
2018-11-11 22:00:36.004 (Fri_Regleta) 33 66 35 38 61 62 62 34 64 61 33 33 65 31 30 76 38 2b 6f 50 3f58abb4da33e10v8+oP
2018-11-11 22:00:36.004 (Fri_Regleta) 57 57 53 48 7a 77 46 4b 77 41 59 7a 65 72 35 6f 70 57 65 73 WWSHzwFKwAYzer5opWes
2018-11-11 22:00:36.004 (Fri_Regleta) 69 74 32 56 2b 45 56 5a 4e 36 58 33 59 72 6d 39 56 4a 57 68 it2V+EVZN6X3Yrm9VJWh
2018-11-11 22:00:36.004 (Fri_Regleta) 2b 72 61 58 54 4f 53 4d 79 4a 38 42 65 4d 4c 57 75 6b 4b 6e +raXTOSMyJ8BeMLWukKn
2018-11-11 22:00:36.004 (Fri_Regleta) 57 72 2f 37 39 33 61 79 6d 42 6a 6e 74 49 2f 4d 34 35 44 70 Wr/793aymBjntI/M45Dp
2018-11-11 22:00:36.004 (Fri_Regleta) 34 63 79 74 42 6d 55 6d 48 67 73 41 6e 77 6d 59 56 64 67 79 4cytBmUmHgsAnwmYVdgy
2018-11-11 22:00:36.004 (Fri_Regleta) 53 32 42 6d 41 79 57 6c 4a 7a 56 65 51 5a 65 2b 76 63 6c 4d S2BmAyWlJzVeQZe+vclM
2018-11-11 22:00:36.004 (Fri_Regleta) 35 4e 30 00 00 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. 5N0......�U
2018-11-11 22:00:36.005 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:36.005 (Fri_Regleta) Sending 86 bytes of data
2018-11-11 22:00:36.005 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-11-11 22:00:36.005 (Fri_Regleta) 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 30 31 39 34 vId":"17007751600194
2018-11-11 22:00:36.005 (Fri_Regleta) 61 66 63 34 62 30 22 2c 22 67 77 49 64 22 3a 22 31 37 30 30 afc4b0","gwId":"1700
2018-11-11 22:00:36.005 (Fri_Regleta) 37 37 35 31 36 30 30 31 39 34 61 66 63 34 62 30 22 7d 00 00 7751600194afc4b0"}..
2018-11-11 22:00:36.005 (Fri_Regleta) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-11-11 22:00:36.032 (Fri_Regleta) Pushing 'ReadEvent' on to queue
2018-11-11 22:00:36.055 (Fri_Regleta) Processing 'ReadEvent' message
2018-11-11 22:00:36.055 (Fri_Regleta) Received 154 bytes of data
2018-11-11 22:00:36.055 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 8a 00 00 00 00 ..U�...........�....
2018-11-11 22:00:36.055 (Fri_Regleta) 7b 22 64 65 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 {"devId":"1700775160
2018-11-11 22:00:36.055 (Fri_Regleta) 30 31 39 34 61 66 63 34 62 30 22 2c 22 64 70 73 22 3a 7b 22 0194afc4b0","dps":{"
2018-11-11 22:00:36.055 (Fri_Regleta) 31 22 3a 74 72 75 65 2c 22 32 22 3a 74 72 75 65 2c 22 33 22 1":true,"2":true,"3"
2018-11-11 22:00:36.056 (Fri_Regleta) 3a 74 72 75 65 2c 22 34 22 3a 74 72 75 65 2c 22 37 22 3a 66 :true,"4":true,"7":f
2018-11-11 22:00:36.056 (Fri_Regleta) 61 6c 73 65 2c 22 31 30 31 22 3a 30 2c 22 31 30 32 22 3a 30 alse,"101":0,"102":0
2018-11-11 22:00:36.056 (Fri_Regleta) 2c 22 31 30 33 22 3a 30 2c 22 31 30 34 22 3a 30 2c 22 31 30 ,"103":0,"104":0,"10
2018-11-11 22:00:36.056 (Fri_Regleta) 35 22 3a 30 7d 7d 60 bc 99 33 00 00 aa 55 .. .. .. .. .. .. 5":0}}`��3..�U
2018-11-11 22:00:36.056 (Fri_Regleta) Pushing 'onMessageCallback' on to queue
2018-11-11 22:00:36.056 (Fri_Regleta) Processing 'onMessageCallback' message
2018-11-11 22:00:36.056 (Fri_Regleta) Calling message handler 'onMessage'.
2018-11-11 22:00:36.056 (Fri_Regleta) onMessage called: 192.168.1.85:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x8a\x00\x00\x00\x00{"devId":"17007751600194afc4b0","dps":{"1":true,"2":true,"3":true,"4":true,"7":false,"101":0,"102":0,"103":0,"104":0,"105":0}}`\xbc\x993\x00\x00\xaaU'
2018-11-11 22:00:36.057 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:36.058 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:36.058 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:36.058 (Fri_Regleta) Sending 171 bytes of data
2018-11-11 22:00:36.058 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 9b 33 2e 31 36 ..U�...........�3.16
2018-11-11 22:00:36.058 (Fri_Regleta) 33 66 35 38 61 62 62 34 64 61 33 33 65 31 30 76 38 2b 6f 50 3f58abb4da33e10v8+oP
2018-11-11 22:00:36.058 (Fri_Regleta) 57 57 53 48 7a 77 46 4b 77 41 59 7a 65 72 35 6f 70 57 65 73 WWSHzwFKwAYzer5opWes
2018-11-11 22:00:36.058 (Fri_Regleta) 69 74 32 56 2b 45 56 5a 4e 36 58 33 59 72 6d 39 56 4a 57 68 it2V+EVZN6X3Yrm9VJWh
2018-11-11 22:00:36.058 (Fri_Regleta) 2b 72 61 58 54 4f 53 4d 79 4a 38 42 65 4d 4c 57 75 6b 4b 6e +raXTOSMyJ8BeMLWukKn
2018-11-11 22:00:36.058 (Fri_Regleta) 57 72 2f 37 39 33 61 79 6d 42 6a 6e 74 49 2f 4d 34 35 44 70 Wr/793aymBjntI/M45Dp
2018-11-11 22:00:36.058 (Fri_Regleta) 34 63 79 74 42 6d 55 6d 48 67 73 41 6e 77 6d 59 56 64 67 79 4cytBmUmHgsAnwmYVdgy
2018-11-11 22:00:36.058 (Fri_Regleta) 53 32 42 6d 41 79 57 6c 4a 7a 56 65 51 5a 65 2b 76 63 6c 4d S2BmAyWlJzVeQZe+vclM
2018-11-11 22:00:36.058 (Fri_Regleta) 35 4e 30 00 00 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. 5N0......�U
2018-11-11 22:00:36.059 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:36.059 (Fri_Regleta) Sending 86 bytes of data
2018-11-11 22:00:36.059 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-11-11 22:00:36.059 (Fri_Regleta) 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 30 31 39 34 vId":"17007751600194
2018-11-11 22:00:36.059 (Fri_Regleta) 61 66 63 34 62 30 22 2c 22 67 77 49 64 22 3a 22 31 37 30 30 afc4b0","gwId":"1700
2018-11-11 22:00:36.059 (Fri_Regleta) 37 37 35 31 36 30 30 31 39 34 61 66 63 34 62 30 22 7d 00 00 7751600194afc4b0"}..
2018-11-11 22:00:36.059 (Fri_Regleta) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-11-11 22:00:36.226 (Fri_Regleta) Pushing 'ReadEvent' on to queue
2018-11-11 22:00:40.749 (Fri_Regleta) 61 6c 73 65 2c 22 31 30 31 22 3a 30 2c 22 31 30 32 22 3a 30 alse,"101":0,"102":0
2018-11-11 22:00:40.750 (Fri_Regleta) 2c 22 31 30 33 22 3a 30 2c 22 31 30 34 22 3a 30 2c 22 31 30 ,"103":0,"104":0,"10
2018-11-11 22:00:40.750 (Fri_Regleta) 35 22 3a 30 7d 7d 60 bc 99 33 00 00 aa 55 .. .. .. .. .. .. 5":0}}`��3..�U
2018-11-11 22:00:40.750 (Fri_Regleta) Pushing 'onMessageCallback' on to queue
2018-11-11 22:00:40.750 (Fri_Regleta) Processing 'onMessageCallback' message
2018-11-11 22:00:40.750 (Fri_Regleta) Calling message handler 'onMessage'.
2018-11-11 22:00:40.750 (Fri_Regleta) onMessage called: 192.168.1.85:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x8a\x00\x00\x00\x00{"devId":"17007751600194afc4b0","dps":{"1":true,"2":true,"3":true,"4":true,"7":false,"101":0,"102":0,"103":0,"104":0,"105":0}}`\xbc\x993\x00\x00\xaaU'
2018-11-11 22:00:40.753 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:40.754 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:40.754 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:40.754 (Fri_Regleta) Sending 171 bytes of data
2018-11-11 22:00:40.754 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 9b 33 2e 31 66 ..U�...........�3.1f
2018-11-11 22:00:40.754 (Fri_Regleta) 63 63 65 38 35 34 66 35 34 66 38 30 63 33 32 76 38 2b 6f 50 cce854f54f80c32v8+oP
2018-11-11 22:00:40.754 (Fri_Regleta) 57 57 53 48 7a 77 46 4b 77 41 59 7a 65 72 35 6f 70 57 65 73 WWSHzwFKwAYzer5opWes
2018-11-11 22:00:40.754 (Fri_Regleta) 69 74 32 56 2b 45 56 5a 4e 36 58 33 59 72 6d 39 56 4a 57 68 it2V+EVZN6X3Yrm9VJWh
2018-11-11 22:00:40.754 (Fri_Regleta) 2b 72 61 58 54 4f 53 4d 79 4a 38 42 65 4d 4c 57 75 6b 4b 6e +raXTOSMyJ8BeMLWukKn
2018-11-11 22:00:40.755 (Fri_Regleta) 57 72 2f 37 39 33 61 79 6d 42 6a 6e 74 49 2f 4d 34 35 44 70 Wr/793aymBjntI/M45Dp
2018-11-11 22:00:40.755 (Fri_Regleta) 34 63 79 74 42 6d 55 6d 48 67 73 41 6e 77 6d 59 56 64 67 79 4cytBmUmHgsAnwmYVdgy
2018-11-11 22:00:40.755 (Fri_Regleta) 53 31 6d 69 55 57 76 66 2f 43 34 6f 58 4f 76 77 44 68 66 38 S1miUWvf/C4oXOvwDhf8
2018-11-11 22:00:40.755 (Fri_Regleta) 2b 4a 73 00 00 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. +Js......�U
2018-11-11 22:00:40.755 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:40.755 (Fri_Regleta) Sending 86 bytes of data
2018-11-11 22:00:40.755 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-11-11 22:00:40.756 (Fri_Regleta) 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 30 31 39 34 vId":"17007751600194
2018-11-11 22:00:40.756 (Fri_Regleta) 61 66 63 34 62 30 22 2c 22 67 77 49 64 22 3a 22 31 37 30 30 afc4b0","gwId":"1700
2018-11-11 22:00:40.756 (Fri_Regleta) 37 37 35 31 36 30 30 31 39 34 61 66 63 34 62 30 22 7d 00 00 7751600194afc4b0"}..
2018-11-11 22:00:40.756 (Fri_Regleta) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-11-11 22:00:40.977 (Fri_Regleta) Pushing 'ReadEvent' on to queue
2018-11-11 22:00:41.006 (Fri_Regleta) Processing 'ReadEvent' message
2018-11-11 22:00:41.007 (Fri_Regleta) Received 154 bytes of data
2018-11-11 22:00:41.007 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 8a 00 00 00 00 ..U�...........�....
2018-11-11 22:00:41.007 (Fri_Regleta) 7b 22 64 65 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 {"devId":"1700775160
2018-11-11 22:00:41.007 (Fri_Regleta) 30 31 39 34 61 66 63 34 62 30 22 2c 22 64 70 73 22 3a 7b 22 0194afc4b0","dps":{"
2018-11-11 22:00:41.007 (Fri_Regleta) 31 22 3a 74 72 75 65 2c 22 32 22 3a 74 72 75 65 2c 22 33 22 1":true,"2":true,"3"
2018-11-11 22:00:41.007 (Fri_Regleta) 3a 74 72 75 65 2c 22 34 22 3a 74 72 75 65 2c 22 37 22 3a 66 :true,"4":true,"7":f
2018-11-11 22:00:41.007 (Fri_Regleta) 61 6c 73 65 2c 22 31 30 31 22 3a 30 2c 22 31 30 32 22 3a 30 alse,"101":0,"102":0
2018-11-11 22:00:41.007 (Fri_Regleta) 2c 22 31 30 33 22 3a 30 2c 22 31 30 34 22 3a 30 2c 22 31 30 ,"103":0,"104":0,"10
2018-11-11 22:00:41.008 (Fri_Regleta) 35 22 3a 30 7d 7d 60 bc 99 33 00 00 aa 55 .. .. .. .. .. .. 5":0}}`��3..�U
2018-11-11 22:00:41.008 (Fri_Regleta) Pushing 'onMessageCallback' on to queue
2018-11-11 22:00:41.008 (Fri_Regleta) Processing 'onMessageCallback' message
2018-11-11 22:00:41.008 (Fri_Regleta) Calling message handler 'onMessage'.
2018-11-11 22:00:41.008 (Fri_Regleta) onMessage called: 192.168.1.85:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x8a\x00\x00\x00\x00{"devId":"17007751600194afc4b0","dps":{"1":true,"2":true,"3":true,"4":true,"7":false,"101":0,"102":0,"103":0,"104":0,"105":0}}`\xbc\x993\x00\x00\xaaU'
2018-11-11 22:00:41.011 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:41.012 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:41.012 (Fri_Regleta) Sending 171 bytes of data
2018-11-11 22:00:41.012 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 9b 33 2e 31 66 ..U�...........�3.1f
2018-11-11 22:00:41.012 (Fri_Regleta) 32 63 36 66 32 36 30 66 61 61 31 31 64 61 65 76 38 2b 6f 50 2c6f260faa11daev8+oP
2018-11-11 22:00:41.012 (Fri_Regleta) 57 57 53 48 7a 77 46 4b 77 41 59 7a 65 72 35 6f 70 57 65 73 WWSHzwFKwAYzer5opWes
2018-11-11 22:00:41.012 (Fri_Regleta) 69 74 32 56 2b 45 56 5a 4e 36 58 33 59 72 6d 39 56 4a 57 68 it2V+EVZN6X3Yrm9VJWh
2018-11-11 22:00:41.012 (Fri_Regleta) 2b 72 61 58 54 4f 53 4d 79 4a 38 42 65 4d 4c 57 75 6b 4b 6e +raXTOSMyJ8BeMLWukKn
2018-11-11 22:00:41.012 (Fri_Regleta) 57 72 2f 37 39 33 61 79 6d 42 6a 6e 74 49 2f 4d 34 35 44 70 Wr/793aymBjntI/M45Dp
2018-11-11 22:00:41.013 (Fri_Regleta) 34 63 79 74 42 6d 55 6d 48 67 73 41 6e 77 6d 59 56 64 67 79 4cytBmUmHgsAnwmYVdgy
2018-11-11 22:00:41.013 (Fri_Regleta) 53 30 4b 30 46 65 50 31 66 67 73 30 34 2f 4f 57 53 49 6e 4e S0K0FeP1fgs04/OWSInN
2018-11-11 22:00:41.013 (Fri_Regleta) 33 7a 39 00 00 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. 3z9......�U
2018-11-11 22:00:41.013 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:41.013 (Fri_Regleta) Sending 86 bytes of data
2018-11-11 22:00:41.013 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-11-11 22:00:41.013 (Fri_Regleta) 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 30 31 39 34 vId":"17007751600194
2018-11-11 22:00:41.013 (Fri_Regleta) 61 66 63 34 62 30 22 2c 22 67 77 49 64 22 3a 22 31 37 30 30 afc4b0","gwId":"1700
2018-11-11 22:00:41.014 (Fri_Regleta) 37 37 35 31 36 30 30 31 39 34 61 66 63 34 62 30 22 7d 00 00 7751600194afc4b0"}..
2018-11-11 22:00:41.014 (Fri_Regleta) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-11-11 22:00:41.157 (Fri_Regleta) Pushing 'onHeartbeatCallback' on to queue
2018-11-11 22:00:41.164 (Fri_Regleta) Processing 'onHeartbeatCallback' message
2018-11-11 22:00:41.164 (Fri_Regleta) Calling message handler 'onHeartbeat'.
2018-11-11 22:00:41.197 (Fri_Regleta) Pushing 'ReadEvent' on to queue
2018-11-11 22:00:41.214 (Fri_Regleta) Processing 'ReadEvent' message
2018-11-11 22:00:41.215 (Fri_Regleta) Received 154 bytes of data
2018-11-11 22:00:41.215 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 8a 00 00 00 00 ..U�...........�....
2018-11-11 22:00:41.215 (Fri_Regleta) 7b 22 64 65 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 {"devId":"1700775160
2018-11-11 22:00:41.215 (Fri_Regleta) 30 31 39 34 61 66 63 34 62 30 22 2c 22 64 70 73 22 3a 7b 22 0194afc4b0","dps":{"
2018-11-11 22:00:41.215 (Fri_Regleta) 31 22 3a 74 72 75 65 2c 22 32 22 3a 74 72 75 65 2c 22 33 22 1":true,"2":true,"3"
2018-11-11 22:00:41.215 (Fri_Regleta) 3a 74 72 75 65 2c 22 34 22 3a 74 72 75 65 2c 22 37 22 3a 66 :true,"4":true,"7":f
2018-11-11 22:00:41.215 (Fri_Regleta) 61 6c 73 65 2c 22 31 30 31 22 3a 30 2c 22 31 30 32 22 3a 30 alse,"101":0,"102":0
2018-11-11 22:00:41.215 (Fri_Regleta) 2c 22 31 30 33 22 3a 30 2c 22 31 30 34 22 3a 30 2c 22 31 30 ,"103":0,"104":0,"10
2018-11-11 22:00:41.216 (Fri_Regleta) 35 22 3a 30 7d 7d 60 bc 99 33 00 00 aa 55 .. .. .. .. .. .. 5":0}}`��3..�U
2018-11-11 22:00:41.216 (Fri_Regleta) Pushing 'onMessageCallback' on to queue
2018-11-11 22:00:41.216 (Fri_Regleta) Processing 'onMessageCallback' message
2018-11-11 22:00:41.216 (Fri_Regleta) Calling message handler 'onMessage'.
2018-11-11 22:00:41.216 (Fri_Regleta) onMessage called: 192.168.1.85:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x8a\x00\x00\x00\x00{"devId":"17007751600194afc4b0","dps":{"1":true,"2":true,"3":true,"4":true,"7":false,"101":0,"102":0,"103":0,"104":0,"105":0}}`\xbc\x993\x00\x00\xaaU'
2018-11-11 22:00:41.219 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:41.220 (Fri_Regleta) Pushing 'WriteDirective' on to queue
2018-11-11 22:00:41.220 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:41.220 (Fri_Regleta) Sending 171 bytes of data
2018-11-11 22:00:41.220 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 9b 33 2e 31 66 ..U�...........�3.1f
2018-11-11 22:00:41.220 (Fri_Regleta) 32 63 36 66 32 36 30 66 61 61 31 31 64 61 65 76 38 2b 6f 50 2c6f260faa11daev8+oP
2018-11-11 22:00:41.220 (Fri_Regleta) 57 57 53 48 7a 77 46 4b 77 41 59 7a 65 72 35 6f 70 57 65 73 WWSHzwFKwAYzer5opWes
2018-11-11 22:00:41.220 (Fri_Regleta) 69 74 32 56 2b 45 56 5a 4e 36 58 33 59 72 6d 39 56 4a 57 68 it2V+EVZN6X3Yrm9VJWh
2018-11-11 22:00:41.220 (Fri_Regleta) 2b 72 61 58 54 4f 53 4d 79 4a 38 42 65 4d 4c 57 75 6b 4b 6e +raXTOSMyJ8BeMLWukKn
2018-11-11 22:00:41.220 (Fri_Regleta) 57 72 2f 37 39 33 61 79 6d 42 6a 6e 74 49 2f 4d 34 35 44 70 Wr/793aymBjntI/M45Dp
2018-11-11 22:00:41.221 (Fri_Regleta) 34 63 79 74 42 6d 55 6d 48 67 73 41 6e 77 6d 59 56 64 67 79 4cytBmUmHgsAnwmYVdgy
2018-11-11 22:00:41.221 (Fri_Regleta) 53 30 4b 30 46 65 50 31 66 67 73 30 34 2f 4f 57 53 49 6e 4e S0K0FeP1fgs04/OWSInN
2018-11-11 22:00:41.221 (Fri_Regleta) 33 7a 39 00 00 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. 3z9......�U
2018-11-11 22:00:41.221 (Fri_Regleta) Processing 'WriteDirective' message
2018-11-11 22:00:41.221 (Fri_Regleta) Sending 86 bytes of data
2018-11-11 22:00:41.221 (Fri_Regleta) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2018-11-11 22:00:41.221 (Fri_Regleta) 76 49 64 22 3a 22 31 37 30 30 37 37 35 31 36 30 30 31 39 34 vId":"17007751600194
2018-11-11 22:00:41.221 (Fri_Regleta) 61 66 63 34 62 30 22 2c 22 67 77 49 64 22 3a 22 31 37 30 30 afc4b0","gwId":"1700
2018-11-11 22:00:41.222 (Fri_Regleta) 37 37 35 31 36 30 30 31 39 34 61 66 63 34 62 30 22 7d 00 00 7751600194afc4b0"}..
2018-11-11 22:00:41.222 (Fri_Regleta) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2018-11-11 22:00:42.336 (Fri_Regleta) Debug logging mask set to: NONE
thanks
vrega
Post by vrega » Monday 12 November 2018 11:39
DAVIZINHO,
it's the same problem that i've witch the smart-bulb plugin.
DAVIZINHO
Post by DAVIZINHO » Monday 12 November 2018 11:59
DAVIZINHO,
ouch, sorry. im stupid.
I dont read your post.
We have the same problem, jiji :-(
@tixi7 can i provide you some log or similar to help?. Tell me and im proud to help
