Honeywell Lyric Thermostat
devguy
Target OS: Raspberry Pi
Re: Honeywell Lyric Thermostat
Post by devguy » Monday 26 November 2018 11:39
I've finished my changes and did some testing yesterday. I'm going to submit the pull request to the dev team later today. As soon as they accept my changes the Honeywell thermostat improvements will become public in the next beta.
Improvements:
- Configure the API key instead of the default embedded one
- Fixed some bugs in the OAuth2 handling
- Added a new device for the equipment state
- Added a new device 'away' (based on geofencing)
Once in a while (about every 12-24 hours) the Honeywelll server is still responding with a 401 (Authorization required). I don't know why because the authorization token is valid. Anyway, it's much better compared to the version included in the stable release of Domoticz.
daniellee
Post by daniellee » Monday 26 November 2018 11:54
THanks, but I'm using Domoticz on my Synology NAS and the latest version is V3.8153. So there is nog type of Honeywell, unfortunately. So I have to wait I guess. Or do you have a suggestion?
Saughassy
Post by Saughassy » Tuesday 27 November 2018 14:04
I bought a T6R but the plugin seems to be unusable at the moment. I cant see the t6r's sensors, and as an on off switch.
(Im using latest build of Domoticz on a Synology NAS.)
After this fix would be nice a status monitoring. I'd like to see when and how long my boiler works.
Thanks for your efforts.
MikeF
Domoticz version: V4.9700
Post by MikeF » Friday 30 November 2018 18:20
Does anybody know if the Honeywell T6 Lyric can be used 'locally', i.e., without the need to connect to a remote server?
- given that it operates over WiFi, is supported in Domoticz, and has a published API (and a nice thermostat display - WAF!).
I currently have a British Gas Hive Heating thermostat, but I'm not comfortable with its use of a hub and need to 'phone home', just to allow me to change the temperature of my heating. (I can do the remote access stuff through Domoticz.)
devguy
Post by devguy » Saturday 01 December 2018 20:32
The updates are now available in the beta release of domoticz. Please empty your browser cache first to see the API key changes.
Please take a look at the website http://www.jadahl.com . This website contains Synology packages of beta versions of Domoticz.
There is no direct connection available to the T6 thermostat. You have to use the online API. :-(
Toop68
Post by Toop68 » Monday 03 December 2018 11:05
hi since last Wednesday the returned outdoor temperature is -18 ?? while before it was working perfectly . if i look in the app of honeywell it shows the outdoor temp is 11. anyone an idea whats going on?
Huntback
Domoticz version: 4.9700
Post by Huntback » Thursday 06 December 2018 14:34
Hey,
I have a Lyric T6R and have been waiting for this API update :D
I have updated my Synology NAS DS411 + II with the latest Domoticz Beta (version: 4.10253, Build Hash: b8aeb96-modified, Compile Date: 2018-12-04 17:12:17)
Then I followed the steps of the wiki at https://www.domoticz.com/wiki/HoneywellDeveloperApiKey
But at step 8 I do not get the expected answer.
I put the full custom URL on the Synology (SSH) command line (same as in steps 4 and 6) but do not get a result.
What am I doing wrong?
All help is appreciated.
Thanks in advance.
Synology - DS411+II
Synology - DS918+
RFXCOM - RFXtrx433
TFA - Weatherstation
Some KAKU, Impuls, etc.
devguy
Post by devguy » Friday 07 December 2018 22:43
Can you send me some more details? What did the server respond?
hscholing
Domoticz version: 4.10216
Post by hscholing » Friday 07 December 2018 23:47
Updated to latest beta, now problems figuring out what is meant in the wiki getting the key.
WIKI states
. Finally make the last webrequest to the Honeywell API to retrieve the Access Token and Refresh Token. Make sure to replace the Base64 encoded string and the CODE:
curl -X POST -H 'Authorization: Basic [[BASE64-ENCODED-STRING]]' -H 'Content-Type: application/x-www-form-urlencoded' -H 'Accept: application/json' -d 'grant_type=authorization_code&code=[
]&redirect_uri=none' https://api.honeywell.com/oauth2/token
[/quote]
Where to do this and what code do I need for [[CODE]] ? I tried something on the Linux prompt of the PI, but no response
devguy
Post by devguy » Saturday 08 December 2018 11:26
Where to do this and what code do I need for CODE ? I tried something on the Linux prompt of the PI, but no response
According to step 4 of the Wiki page you have to browse with your browser to the following page:
https://api.honeywell.com/oauth2/author ... client_id=[[YOURAPIKEY]]&redirect_uri=none
After loggin in with your thermostat credentials, you will be asked for permission to read out the thermostat values through the API. Your browser will be redirected to the invalid url 'none'. You can ignore this error. In the address bar of your browser the following address appeared containing the CODE value:
api.honeywell.com/oauth2/app/none?code=u0ZAfVyA&scope=
hscholing
Post by hscholing » Saturday 08 December 2018 12:16
Thank you Devguy, I now see I missed step 6 mentioning the code also. It's working now, great!
Huntback
Post by Huntback » Saturday 08 December 2018 14:50
thank you devguy,
I received no response at all after performing step 8.
so i just looked at the command line again and saw that I had not removed the [[ ]] signs :oops:
After having adjusted that and having requested a new CODE I got a response after executing step 8 and the requested access and refresh tokens.
Domoticz now shows the new devices :)
Synology - DS411+II
Synology - DS918+
RFXCOM - RFXtrx433
Robbedoes60
Domoticz version: 4.10267
Post by Robbedoes60 » Monday 10 December 2018 20:44
Same here, using Domoticz 4.10267 on a Linux server.
Toop68
Post by Toop68 » Friday 14 December 2018 13:02
found out by creating a testapi key and entering commands from a terminal session that the country for me was set to canada
changed in the Honeywell app my home location (added address specifics (had only zipcode, now full address)
tried again -> i've got now the correct outdoor temp although the country still was canada
