Python Plugin: Python Plugin Manager
misko903
Target OS: Raspberry Pi
Domoticz version: Latest
Re: Python Plugin: Python Plugin Manager
Post by misko903 » Sunday 04 November 2018 21:17
ycahome wrote:
Tuesday 30 October 2018 14:23
misko903 wrote:
Tuesday 30 October 2018 11:22
plus I can't see the latest published zigbee2mqqt plugin. Is there way to update?
zigbee2mqqt plugin just added.
In order to add plugin to PP Manager you should raise a "Pull Request" on github
TO CONTRIBUTE YOUR PLUGINS:
In order to add your plugins to PP-Manager, make a "pull request" with your lines added:
Under 'label="Domoticz Plugin"' in alphabetical order by 'label' and
Under 'self.plugindata' in alphabetical order by 'pluginText'
repeated the steps to install PPManager. Now I can see zigbee2mqtt!
thanks
misko903
Post by misko903 » Sunday 04 November 2018 21:19
ycahome wrote:
Tuesday 30 October 2018 14:20
misko903 wrote:
Monday 29 October 2018 9:15
what about updates of plugins?
after every restart, my RPi is telling me, that update for ebusd plugin is available. How can i update it?
Thank you,
Michal
Read the very first post for usage:
"Auto Update" Options (After every change press "Update")
"All": Continuously update all plugins
"Selected":Continuously update selected plugin (You should first select desired plugin from "Domoticz Plugin" field)
"All (NotifyOnly)": Check all plugins for updates and generate notification email.
"Selected (NotifyOnly)":Check selected plugin for updates and generate notification email. (You should first select desired plugin from "Domoticz Plugin" field)
Thanks, I am using Slovak translation of DZ, it is partially translated, therefor I was confused. Now setted up correctly and it does not bother me again...
dextm80
Domoticz version: 4.10159
Post by dextm80 » Thursday 08 November 2018 9:10
dextm80 wrote:
Saturday 03 November 2018 17:45
2018-11-03 16:45:10.005 Error: Python Plugin Manager hardware (13) thread seems to have ended unexpectedly
why?
i've already this error, anyone who known this error mean?
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
2x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
ycahome
Domoticz version: lat Beta
Post by ycahome » Thursday 08 November 2018 10:10
why?
This is a generic Domoticz alert. Can you post your settings in order to see if there is something wrong? Have you set "Data Timeout" to "Disabled"?
ycahome
Post by ycahome » Friday 09 November 2018 11:21
Version 1.5.13 is out
v.1.5.13
Added: "eQ-3 MAX!" plugin (Thanks to @mvzut)
Added: "SmogTok Air Quality monitor" plugin (Thanks to @smogtok)
dextm80
Post by dextm80 » Sunday 11 November 2018 19:45
why?
yes, data timeout is disabled, other settings are default. i've upgrade 1.5.13 but the error stay here yet
1x Fibaro Wall Plug
Philips Hue Bridge
ycahome
Post by ycahome » Sunday 11 November 2018 20:06
PP-Manager is Hardware Idx 13?
nono212
Domoticz version: 3.6179
Post by nono212 » Monday 12 November 2018 18:00
this is not working with Synology
I tryed to install eq-3 max
I had some errors
I can be a beta tester for Synology if needed
To make it work I had to launch the command my self ... but in sudo mode
mvzut
Post by mvzut » Monday 12 November 2018 19:14
I had some errors
Others have successfully installed the plugin (directly) on Synology. So I assume your errors have to do with the Plugin Manager. If there is anything I can do (as eQ-3 Max! plugin author) please let me know.
Raspberry Pi 3 - RFXtrx433 - Aeon Z-Stick gen5 - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - Xiaomi Gateway - Sonos - IP cameras - Wall mounted tablet + Imperihome - MANY switches/sensors
ycahome
Post by ycahome » Tuesday 13 November 2018 12:41
ok,
maybe we found something here.
So, the question is:
"is there anyone that had -even a single- plugin installed on Synology Based Domoticz via PP-Manager (or without sudo?)?"
nono212
Post by nono212 » Tuesday 13 November 2018 16:53
Sorry the name is not correct in the image ...
the name MaxCube is not correct it should be pp_manager
dextm80
Post by dextm80 » Wednesday 14 November 2018 23:44
yes
1x Fibaro Wall Plug
Philips Hue Bridge
Users browsing this forum: moroen and 5 guests
