Python Plugin: Python Plugin Manager
misko903
Target OS: Raspberry Pi
Domoticz version: Latest
Re: Python Plugin: Python Plugin Manager
Post by misko903 » Sunday 04 November 2018 21:17
ycahome wrote:
Tuesday 30 October 2018 14:23
misko903 wrote:
Tuesday 30 October 2018 11:22
plus I can't see the latest published zigbee2mqqt plugin. Is there way to update?
zigbee2mqqt plugin just added.
In order to add plugin to PP Manager you should raise a "Pull Request" on github
TO CONTRIBUTE YOUR PLUGINS:
In order to add your plugins to PP-Manager, make a "pull request" with your lines added:
Under 'label="Domoticz Plugin"' in alphabetical order by 'label' and
Under 'self.plugindata' in alphabetical order by 'pluginText'
repeated the steps to install PPManager. Now I can see zigbee2mqtt!
thanks
misko903
Post by misko903 » Sunday 04 November 2018 21:19
ycahome wrote:
Tuesday 30 October 2018 14:20
misko903 wrote:
Monday 29 October 2018 9:15
what about updates of plugins?
after every restart, my RPi is telling me, that update for ebusd plugin is available. How can i update it?
Thank you,
Michal
Read the very first post for usage:
"Auto Update" Options (After every change press "Update")
"All": Continuously update all plugins
"Selected":Continuously update selected plugin (You should first select desired plugin from "Domoticz Plugin" field)
"All (NotifyOnly)": Check all plugins for updates and generate notification email.
"Selected (NotifyOnly)":Check selected plugin for updates and generate notification email. (You should first select desired plugin from "Domoticz Plugin" field)
Thanks, I am using Slovak translation of DZ, it is partially translated, therefor I was confused. Now setted up correctly and it does not bother me again...
dextm80
Domoticz version: 4.10159
Post by dextm80 » Thursday 08 November 2018 9:10
dextm80 wrote:
Saturday 03 November 2018 17:45
2018-11-03 16:45:10.005 Error: Python Plugin Manager hardware (13) thread seems to have ended unexpectedly
why?
i've already this error, anyone who known this error mean?
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
ycahome
Domoticz version: lat Beta
Post by ycahome » Thursday 08 November 2018 10:10
why?
This is a generic Domoticz alert. Can you post your settings in order to see if there is something wrong? Have you set "Data Timeout" to "Disabled"?
ycahome
Post by ycahome » Friday 09 November 2018 11:21
Version 1.5.13 is out
v.1.5.13
Added: "eQ-3 MAX!" plugin (Thanks to @mvzut)
Added: "SmogTok Air Quality monitor" plugin (Thanks to @smogtok)
dextm80
Post by dextm80 » Sunday 11 November 2018 19:45
why?
yes, data timeout is disabled, other settings are default. i've upgrade 1.5.13 but the error stay here yet
1x Fibaro Wall Plug
Philips Hue Bridge
ycahome
Post by ycahome » Sunday 11 November 2018 20:06
PP-Manager is Hardware Idx 13?
nono212
Domoticz version: 3.6179
Post by nono212 » Monday 12 November 2018 18:00
this is not working with Synology
I tryed to install eq-3 max
I had some errors
I can be a beta tester for Synology if needed
To make it work I had to launch the command my self ... but in sudo mode
mvzut
Post by mvzut » Monday 12 November 2018 19:14
I had some errors
Others have successfully installed the plugin (directly) on Synology. So I assume your errors have to do with the Plugin Manager. If there is anything I can do (as eQ-3 Max! plugin author) please let me know.
Raspberry Pi 3 - RFXtrx433 - Aeon Z-Stick gen5 - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - Xiaomi Gateway - Sonos - IP cameras - Wall mounted tablet + Imperihome - Alexa - MANY switches/sensors
ycahome
Post by ycahome » Tuesday 13 November 2018 12:41
ok,
maybe we found something here.
So, the question is:
"is there anyone that had -even a single- plugin installed on Synology Based Domoticz via PP-Manager (or without sudo?)?"
nono212
Post by nono212 » Tuesday 13 November 2018 16:53
Sorry the name is not correct in the image ...
the name MaxCube is not correct it should be pp_manager
dextm80
Post by dextm80 » Wednesday 14 November 2018 23:44
yes
1x Fibaro Wall Plug
Philips Hue Bridge
RickU09
Post by RickU09 » Monday 10 December 2018 20:26
How can I uninstall PP-Manager?
I'm new to Domoticz/RPi
I tried
-Cd domoticz/plugins
-pip uninstall PP-MANAGER
No result, Domoticz stopped working after installing this plugin manager.
Cannot switch to python 3.4 (Which should solve the problem??)
pi@raspberrypi:~ $ sudo apt-get install python3.4
Reading package lists... Error!
E: Splitting of file /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease failed as it doesn't contain all expected parts 0 1 0
E: The package lists or status file could not be parsed or opened.
Also tried
pi@raspberrypi:~ $ sudo apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Err:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Splitting up /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease into data and signature faile d
Err:2 http://archive.raspberrypi.org/debian stretch InRelease
Splitting up /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_stretch_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will b e used. GPG error: http://raspbian.raspberrypi.org/raspbian stretch InRelease: Splitting up /var/lib/apt/lists/raspbian.r aspberrypi.org_raspbian_dists_stretch_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will b e used. GPG error: http://archive.raspberrypi.org/debian stretch InRelease: Splitting up /var/lib/apt/lists/archive.raspb errypi.org_debian_dists_stretch_InRelease into data and signature failed
W: Failed to fetch http://raspbian.raspberrypi.org/raspbia ... /InRelease Splitting up /var/lib/apt/lists/rasp bian.raspberrypi.org_raspbian_dists_stretch_InRelease into data and signature failed
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... /InRelease Splitting up /var/lib/apt/lists/archive .raspberrypi.org_debian_dists_stretch_InRelease into data and signature failed
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: Splitting of file /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease failed as it doesn't co ntain all expected parts 0 1 0
Then did this:
pi@raspberrypi:~ $ sudo apt-get clean
pi@raspberrypi:~ $ sudo rm-vf /var/lib/apt/lists/*
sudo: rm-vf: command not found
pi@raspberrypi:~ $ sudo rm -vf /var/lib/apt/lists/*
removed '/var/lib/apt/lists/archive.raspberrypi.org_debian_dists_stretch_InRelease'
removed '/var/lib/apt/lists/archive.raspberrypi.org_debian_dists_stretch_main_binary-armhf_Packages'
removed '/var/lib/apt/lists/archive.raspberrypi.org_debian_dists_stretch_ui_binary-armhf_Packages'
removed '/var/lib/apt/lists/lock'
rm: cannot remove '/var/lib/apt/lists/partial': Is a directory
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_contrib_binary-armhf_Packages'
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease'
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_main_binary-armhf_Packages'
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_non-free_binary-armhf_Packages'
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_rpi_binary-armhf_Packages'
pi@raspberrypi:~ $ sudo rm -vf /var/lib/apt/lists/partial/*
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Get:4 http://archive.raspberrypi.org/debian stretch/main armhf Packages [200 kB]
Get:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [40.3 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages [56.9 kB]
Get:7 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages [95.5 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages [1,360 B]
Fetched 12.1 MB in 36s (329 kB/s)
Reading package lists... Done
pi@raspberrypi:~ $ sudo apt-get upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
base-files geany geany-common gtk2-engines-clearlookspix libbasicusageenvironment1 libgroupsock8 libgs9 libgs9-common liblivemedia57 libobrender32v5 libobt2v5 libperl5.24
libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libsmbclient libssl1.1 libtiff5 libusageenvironment3 libwbclient0 openbox openssl perl perl-base
perl-modules-5.24 pi-greeter pipanel policykit-1 python-rpi.gpio python3-rpi.gpio raspberrypi-sys-mods raspberrypi-ui-mods raspi-config rp-prefapps rpi-chromium-mods
samba-common samba-libs zenity zenity-common
39 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 39.8 MB of archives.
After this operation, 155 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.org/debian stretch/ui armhf rpi-chromium-mods armhf 20181204 [9,174 kB]
Get:2 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf base-files armhf 9.9+rpi1+deb9u6 [67.5 kB]
Get:3 http://mirror.proserve.nl/raspbian/raspbian stretch/main armhf libperl5.24 armhf 5.24.1-3+deb9u5 [2,837 kB]
Get:4 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf perl armhf 5.24.1-3+deb9u5 [219 kB]
Get:6 http://mirror.transip.net/raspbian/raspbian stretch/main armhf perl-modules-5.24 all 5.24.1-3+deb9u5 [2,722 kB]
Get:8 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libsmbclient armhf 2:4.5.12+dfsg-2+deb9u4 [144 kB]
Get:5 http://mirror.proserve.nl/raspbian/raspbian stretch/main armhf perl-base armhf 5.24.1-3+deb9u5 [1,198 kB]
Get:9 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf samba-libs armhf 2:4.5.12+dfsg-2+deb9u4 [4,379 kB]
Get:7 http://mirror.proserve.nl/raspbian/raspbian stretch/main armhf libwbclient0 armhf 2:4.5.12+dfsg-2+deb9u4 [121 kB]
Get:11 http://mirror.proserve.nl/raspbian/raspbian stretch/main armhf libssl1.1 armhf 1.1.0j-1~deb9u1 [1,115 kB]
Get:10 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf samba-common all 2:4.5.12+dfsg-2+deb9u4 [172 kB]
Get:12 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libbasicusageenvironment1 armhf 2016.11.28-1+deb9u1 [19.7 kB]
Get:14 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libtiff5 armhf 4.0.8-2+deb9u4 [220 kB]
Get:13 http://mirror.transip.net/raspbian/raspbian stretch/main armhf libgroupsock8 armhf 2016.11.28-1+deb9u1 [24.8 kB]
Get:15 http://mirror.nl.leaseweb.net/raspbian/raspbian stretch/main armhf libgs9 armhf 9.26~dfsg-0+deb9u1 [1,863 kB]
Get:16 http://mirror.transip.net/raspbian/raspbian stretch/main armhf libgs9-common all 9.26~dfsg-0+deb9u1 [5,140 kB]
Get:17 http://mirror.nl.leaseweb.net/raspbian/raspbian stretch/main armhf liblivemedia57 armhf 2016.11.28-1+deb9u1 [265 kB]
Get:20 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libpolkit-backend-1-0 armhf 0.105-18+deb9u1 [39.8 kB]
Get:21 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libpolkit-gobject-1-0 armhf 0.105-18+deb9u1 [37.8 kB]
Get:22 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libusageenvironment3 armhf 2016.11.28-1+deb9u1 [12.2 kB]
Get:23 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf openssl armhf 1.1.0j-1~deb9u1 [712 kB]
Get:24 http://archive.raspberrypi.org/debian stretch/ui armhf geany armhf 1.29-1+rpt2 [1,224 kB]
Get:18 http://mirror.transip.net/raspbian/raspbian stretch/main armhf policykit-1 armhf 0.105-18+deb9u1 [61.7 kB]
Get:19 http://mirror.transip.net/raspbian/raspbian stretch/main armhf libpolkit-agent-1-0 armhf 0.105-18+deb9u1 [22.3 kB]
Get:25 http://archive.raspberrypi.org/debian stretch/ui armhf geany-common all 1.29-1+rpt2 [2,461 kB]
Get:26 http://archive.raspberrypi.org/debian stretch/ui armhf gtk2-engines-clearlookspix armhf 1:2.20.7 [66.0 kB]
Get:27 http://archive.raspberrypi.org/debian stretch/ui armhf libobt2v5 armhf 3.6.1-4+rpi8 [62.3 kB]
Get:28 http://archive.raspberrypi.org/debian stretch/ui armhf libobrender32v5 armhf 3.6.1-4+rpi8 [69.7 kB]
Get:29 http://archive.raspberrypi.org/debian stretch/ui armhf openbox armhf 3.6.1-4+rpi8 [281 kB]
Get:30 http://archive.raspberrypi.org/debian stretch/ui armhf pi-greeter armhf 0.9 [40.8 kB]
Get:31 http://archive.raspberrypi.org/debian stretch/ui armhf zenity-common all 3.28.1-1.1~bpo9+rpt1 [4,126 kB]
Get:32 http://archive.raspberrypi.org/debian stretch/ui armhf zenity armhf 3.28.1-1.1~bpo9+rpt1 [268 kB]
Get:33 http://archive.raspberrypi.org/debian stretch/ui armhf pipanel armhf 20181126~094616 [19.2 kB]
Get:34 http://archive.raspberrypi.org/debian stretch/main armhf python-rpi.gpio armhf 0.6.5~stretch-1 [23.5 kB]
Get:35 http://archive.raspberrypi.org/debian stretch/main armhf python3-rpi.gpio armhf 0.6.5~stretch-1 [23.6 kB]
Get:36 http://archive.raspberrypi.org/debian stretch/main armhf raspberrypi-sys-mods armhf 20181127 [10.2 kB]
Get:37 http://archive.raspberrypi.org/debian stretch/ui armhf rp-prefapps armhf 0.5 [175 kB]
Get:38 http://archive.raspberrypi.org/debian stretch/ui armhf raspberrypi-ui-mods all 1.20181206 [318 kB]
Get:39 http://archive.raspberrypi.org/debian stretch/ui armhf raspi-config all 20181118 [20.2 kB]
Fetched 39.8 MB in 12s (3,302 kB/s)
Reading changelogs... Done
Extracting templates from packages: 100%
Preconfiguring packages ...
dpkg: unrecoverable fatal error, aborting:
files list file for package 'openvpn' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
And then:...
The following additional packages will be installed:
libpython3.4-minimal libpython3.4-stdlib python3.4-minimal
Suggested packages:
python3.4-venv python3.4-doc binfmt-support
The following NEW packages will be installed:
libpython3.4-minimal libpython3.4-stdlib python3.4 python3.4-minimal
0 upgraded, 4 newly installed, 0 to remove and 39 not upgraded.
Need to get 0 B/4,049 kB of archives.
After this operation, 20.7 MB of additional disk space will be used.
Selecting previously unselected package libpython3.4-minimal:armhf.
pi@raspberrypi:~ $ compgen -c python
python3.5-config
python3.5m
python2.7
python3.5
python3-config
python
python3
python2.7-config
python2-config
python3.5m-config
python3m
python3m-config
python-config
python2
pi@raspberrypi:~ $
Still no Python3.4????
Not getting it to work properly...
ycahome
Post by ycahome » Monday 10 December 2018 21:31
I tried
Just like any other plugin. Delete plugin folder(PP-Manager).
RickU09
Post by RickU09 » Wednesday 12 December 2018 20:51
I've tried again with a new fresh install.
I've managed to install 3.4 and remove 3.5.
After installing Python Plugin Manager again I cannot find it in domoticz. Like there is not running any version of python anymore?
Also my Sony Bravia plugin is not working anymore.
My last tries:
pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.4 4
update-alternatives: using /usr/bin/python3.4 to provide /usr/bin/python (python) in auto mode
pi@raspberrypi:~ $ sudo update-alternatives --config python
There is only one alternative in link group python (providing /usr/bin/python): /usr/bin/python3.4
Nothing to configure.
ycahome
Post by ycahome » Wednesday 12 December 2018 21:30
check for the prerequisites of python framework.
You need the also relative python3-dev
Users browsing this forum: No registered users and 3 guests
