Python Plugin: Python Plugin Manager
Derik
Target OS: Raspberry Pi
Re: Python Plugin: Python Plugin Manager
Post by Derik » Monday 04 June 2018 20:41
ycahome wrote:
Monday 04 June 2018 20:39
my suggestion will re-apply your installation files even if your version is the same.
Another test you can make is to backup your database and reinstall your Domoticz.
Seems that your installation has some problems..
mmm did install last weekend a clean and new setup on a new RpiB+...
So i think.... there is something else wrong..:-)?
Derik
Post by Derik » Monday 04 June 2018 22:13
What version of python do i need?? in your opinion
Perhaps there is something to see?
ycahome
Domoticz version: lat Beta
Post by ycahome » Monday 04 June 2018 22:18
I think 3.4.4 is ok.
I have installed a lot of raspberry pies with domoticz and various plugins over the time. It's quite straight forward (except from raspbian stretch that requires libssl to start domoticz).
If you have reinstalled your domoticz and don't work from the very beginning, then sorry but, you are doing something wrong :roll: :cry:
Derik
Post by Derik » Monday 04 June 2018 22:20
I have installed a lot of raspberry pies with domoticz and various plugins over the time. It's quite straight forward (except from raspbian jessie that requires libssl to start domoticz).
I run stretch perhaps there is something different??
How can i check or install?
Is it possible to use multiple python versions @ the same time?
ycahome
Post by ycahome » Monday 04 June 2018 22:28
sorry I meant "stretch", the latest version not "Jessie".
Did you installed libssl in order to start Domoticz? Is it starting automatically?
Derik
Post by Derik » Monday 04 June 2018 22:35
Dear I am a bricklayer...
With a nice hobby Domoticz..
Only linux love only i cannot understand some things
I did install Domoticz with the bash script from the wiki
When you tell me what i mst do..
I do the things you ask..
The question how do i now/can i see what i install?
Derik
Post by Derik » Monday 04 June 2018 22:51
I think 3.4.4 is ok.cry:
I run:
pi@raspberrypi:~ $ sudo apt-get install python3
Pakketlijsten worden ingelezen... Klaar
Boom van vereisten wordt opgebouwd
De statusinformatie wordt gelezen... Klaar
python3 is reeds de nieuwste versie (3.5.3-1).
Perhaps the 3.4.4 is to old?
This running on my pi:
pi@raspberrypi:~ $ python --version
Python 2.7.13
pi@raspberrypi:~ $ python3 --version
Python 3.5.3
IDANIT
Post by IDANIT » Tuesday 05 June 2018 20:13
at Domoticz check the log (Setup/Log/Status) You should see
 PluginSystem: Started, Python version '3.4.4'.
if not or different version number (3.5.5)
sudo apt-get remove python 3.5
it should did the trick
blauwebuis
Domoticz version: current
Post by blauwebuis » Monday 09 July 2018 18:26
Another nice theme:
http://domoticz.com/forum/viewtopic.php?f=8&t=24084
Time to dust-of the idea of letting this plugin install themes too?
landaisbenj
Domoticz version: stable
Post by landaisbenj » Tuesday 10 July 2018 8:59
Another nice theme:
:!: Really good idea
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
