Remote Control of KAKU as command input
Toulon7559
Target OS: Raspberry Pi
Domoticz version: latest
Post by Toulon7559 » Thursday 25 January 2018 16:58
;-) Sometimes an idea/question just pops up, but the answer remains hidden.
I have a KAKU-set with 3 Switch Units and 1 Remote Control Unit.
The Remote Control Unit has 5 command sets On&Off for A, B, C and D, and All.
The obvious application is to use A, B and C for On&Off for the 3 switches.
Is it possible to apply commands D_On and D_Off as input for a virtual switch in Domoticz?
Would be handy to 'toggle' a display etc.
Howto?
Set1 = RPI-B+RFXCom433+S0PCM+Linksprite-shield for BMP180/DS18B20/RS485+DDS238-1ZN
Set2 = RPI-3+RFLinkGTW+ESP8266s+PWS_WS7000
Common = 3*PVLogger+PWS_TFA_Nexus+KAKUs
=> Energy & Data Management based on Time and on PV&Consumption&Meteo
hansies
Domoticz version: stable
Re: Remote Control of KAKU as command input
Post by hansies » Thursday 25 January 2018 17:23
Yes, that's possible. I use my remote to switch a virtual named disco. That starts a lightshow with all my Yeelights.
Domoticz stable | Intel NUC | VirtualBox | Ubuntu 16.04
RPI2B | RFLink
Yeelight | Sonoff Tasmota
butchamon
Domoticz version: 2.3530
Post by butchamon » Sunday 09 December 2018 0:29
Hi there, could you please let me know how this can be done? (or point me to the correct section where I can look for this ?)
Thanks.
Amsterdam020
Domoticz version: 3.5629
Post by Amsterdam020 » Tuesday 11 December 2018 23:57
Hi butchamon,
In the dashboard go to switches,
click on the right side on Learn Light/Switch
Press on the remote on the button you want to use and select the right type (for example on/off)
Go to setup
more options
events
click on the plus,
select lua,
select device
replace the code by
-- replace KAKU_name
-- replace lamp_name
if      (devicechanged["KAKU_name"] == 'On' )
then   commandArray['lamp_name'] ='Set Level: 50'
elseif  (devicechanged["KAKU_name"]== 'off')
then   commandArray['lamp_name'] ='off'
change KAKU_name and lamp_name
save the script
check if it works
Rp3, youlesss, rfxcom, philips hue, dsb1820
Users browsing this forum: No registered users and 6 guests
