Community Hardware (for Domoticz) : nearly there Topic is solved
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
Is the community interested in a Community edition Hardware?
Yes, definitely
43
54%
Maybe if it goes via an open Kickstarter or similar campaign and I can have it fully built
19
24%
Probably not
7
9%
Only if I can get it as DIY in part to assembly myself
10
13%
Something else (please leave comment on forum thread)
0
No votes
Total votes: 79
EdddieN
Target OS: Raspberry Pi
Domoticz version: 4.9700
Re: Testers for Dev wanted :: Community Hardware (for Domoticz)
Post by EdddieN » Thursday 05 July 2018 19:03
I have updated the github and I wonder if someone knows about a more elegant way of doing this:
https://github.com/EdddieN/machinon/blo ... i_setup.md
There's a part where I need to give nginx access to the python files to push the configuration of the hardware board via the UART. Without these permissions, the web client will not allow to execute the python files.... for good reason!
Is there a different way of doing this? So far this is what I have to do:
sudo chown -R www-data /var/www/html
sudo chmod -R 770 /var/www/html/
sudo usermod -a -G dialout www-data
sudo usermod -a -G www-data pi
11101101 - www.machinon.com
D'rMorris
Post by D'rMorris » Friday 06 July 2018 13:29
If you're still looking for beta-testers: we're currently remodeling our house (completely) so I'm installing a home automation system. Still thinking whether I should install z-wave or a PLC system. Would be interested in testing your prototype!
EdddieN
Post by EdddieN » Friday 06 July 2018 17:54
Yes interested, I have 1, maybe 2 units left so need to make sure they good into a good (developer) house.
The key area I would love help is an easier integration with Domoticz, see this link and you'll see what I mean:
The other area which is not really machinon related but I'm quite keen to lift up Domoticz UX is here:
http://www.domoticz.com/forum/viewtopic.php?f=8&t=24084
If you can help... I'll fight for you for a prototype :D
EdddieN
Post by EdddieN » Monday 16 July 2018 20:11
A bit of topic, started to play with Raex motors, their dry contact remotes and also with RFXCom. A few videos here:
https://www.machinon.com/blog/all-work- ... a-dull-boy with this theme: http://www.domoticz.com/forum/viewtopic.php?f=8&t=24084
EdddieN
Re: Community Hardware (for Domoticz) : nearly there
Post by EdddieN » Friday 20 July 2018 18:10
Many people have asked about cost, so this is where I am so far: https://shoutout.wix.com/so/9MIuI9Ht if anyone can help, please do.
EdddieN
Post by EdddieN » Saturday 28 July 2018 13:43
Ok, thinking about simplifying the design and focusing more on the I/Os only, that is no LCD display. That should help to bring the cost down to the circa €100.
Has anyone any reason to need the LCD display?
Prutsium
Post by Prutsium » Saturday 28 July 2018 14:09
Would a simple Oled display not be more cheaper to use?
In general i think only having basic info on the display would be required like IP, Load, Bandwidth
EdddieN
Post by EdddieN » Saturday 28 July 2018 14:53
Is not so much the LCD but the extra electronic circuit and its mechanical parts assembly. Is almost like having x 2 of everything
EdddieN
Post by EdddieN » Tuesday 31 July 2018 12:21
Nice one, a blog on Hackster about machinon and by extention domoticz:
https://blog.hackster.io/machinon-takes ... da1d4c5adb
BarryT
Post by BarryT » Saturday 11 August 2018 22:24
+1! Great job :-)
Hope to see a oob working NTC - PTC / PT100 / PT1000 input on this... That should made my day!
6x Raspberry 3
2x VPS Server
2x Active VPN
A lot of scripts, switches and sensors :)
EdddieN
Post by EdddieN » Sunday 12 August 2018 14:08
What is a oob?
NTC / PTC = yes
PT100 / PT1000 = I'll have a look, probably PT1000 too as the ADC converter is a 14-16 bit
BarryT
Post by BarryT » Sunday 12 August 2018 14:10
Oob, out of box :)
6x Raspberry 3
2x VPS Server
2x Active VPN
EdddieN
Post by EdddieN » Friday 19 October 2018 15:24
I had this thread a bit forgotten for a while... things still moving. Got this week final pre-production unis and are looking really nice:
The attachment machinon_blocks.jpg is no longer available
and also thinking bout the UpBoard as an alternative for the RPI. It is an Intel version of it, the key thing I like is that it does not have a SD card but built in 32GB of eMMC. Anyway... just toying with the idea for now.
Also leave here an interesting video of how it was made ;)
