Domoticz webserver goes offline and events stop working
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Tweek
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by Tweek » Friday 12 January 2018 23:07
Version: 3.8153
Platform: Raspberry Pi
Plugin/Hardware:
- OpenZWave USB 1.4-2501-g5af6780-dirty
- Phillips Hue Bridge
- Nest Thermostat
- Milight Controller
Description:
At seemingly random times my Domoticz installation will stop responding to both lua events and HTTP calls. After a restart Domoticz works fine again. The Domoticz service itself still reports being enabled during this state:
Netstat also reports the webport still being open, the port responds but the webserver doesn't return a result:
I tried creating a log but that does not return any useful info. This is the log which just stops having any events somewhere during the night, the next entries are from after I manually restarted the service:
2018-01-12 04:54:27.306  (Nest) Thermostat (Nest Setpoint)
2018-01-12 04:54:27.317  (Nest) Temp + Humidity (Nest living TempHum)
2018-01-12 04:54:57.934  (Nest) Thermostat (Nest Setpoint)
2018-01-12 04:54:57.946  (Nest) Temp + Humidity (Nest living TempHum)
2018-01-12 04:55:28.540  (Nest) Thermostat (Nest Setpoint)
2018-01-12 04:55:28.552  (Nest) Temp + Humidity (Nest living TempHum)
2018-01-12 04:55:59.133  (Nest) Thermostat (Nest Setpoint)
2018-01-12 04:55:59.144  (Nest) Temp + Humidity (Nest living TempHum)
2018-01-12 04:56:00.252  EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_update_hue_power.lua
2018-01-12 04:56:29.739  (Nest) Thermostat (Nest Setpoint)
2018-01-12 04:56:29.751  (Nest) Temp + Humidity (Nest living TempHum)
2018-01-12 04:57:00.487  (Nest) Thermostat (Nest Setpoint)
2018-01-12 08:50:36.994  Incoming connection from: 192.168.2.14
2018-01-12 08:50:38.831  AppLamp: Worker Started...
2018-01-12 08:50:38.832  Nest: Worker started...
2018-01-12 08:50:38.832  Philips Hue: Worker started...
2018-01-12 08:50:38.833  EventSystem: reset all events...
2018-01-12 08:50:38.834  EventSystem: reset all device statuses...
2018-01-12 08:50:38.959  EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2018-01-12 08:50:38.959  EventSystem: Started
2018-01-12 08:50:39.332  OpenZWave: using config in: /home/pi/domoticz/Config/
2018-01-12 08:50:39.336  OpenZWave: Starting...
2018-01-12 08:50:39.336  OpenZWave: Version: 1.4-2501-g5af6780-dirty
2018-01-12 08:50:39.572  OpenZWave: Driver Ready
Anyone who can help me figure out the root of this issue?
Tweek
Re: Domoticz webserver goes offline and events stop working
Post by Tweek » Saturday 20 January 2018 11:10
I have created a debug level log instead of the default log posted here, it created 282k lines between 3pm and 10pm when Domoticz crashed. Near the end it shows no sign of any error what so ever:
2018-01-16 22:08:40.657  WEBH : Host:192.168.2.9 Uri;/json.htm?type=command&param=updateuservariable&vname=updateHueStatus&vtype=integer&vvalue=1
2018-01-16 22:08:40.662  WEBS GetJSon :updateuservariable :/json.htm?type=command&param=updateuservariable&vname=updateHueStatus&vtype=integer&vvalue=1
2018-01-16 22:08:40.663  SQLQ query : SELECT ID FROM UserVariables WHERE Name='updateHueStatus'
2018-01-16 22:08:40.663  SQLR result: 1;
2018-01-16 22:08:40.664  SQLQ query : UPDATE UserVariables SET Name='updateHueStatus', ValueType='0', Value='1', LastUpdate='2018-01-16 22:08:40' WHERE (ID == '1')
2018-01-16 22:08:40.665  SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='MeterDividerEnergy')
2018-01-16 22:08:40.665  SQLR result: 1000;;
2018-01-16 22:08:40.666  SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='MeterDividerGas')
2018-01-16 22:08:40.666  SQLR result: 100;;
2018-01-16 22:08:40.666  SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='MeterDividerWater')
2018-01-16 22:08:40.670  SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SecStatus')
2018-01-16 22:08:40.670  SQLR result: 0;;
2018-01-16 22:08:40.769  SQLQ query : SELECT ID FROM DeviceStatus WHERE (Name == 'Bedroom Dimmer Remote Button Off')
2018-01-16 22:08:40.769  SQLR result: 77;
2018-01-16 22:08:40.769  SQLQ query : SELECT Type,SubType,SwitchType FROM DeviceStatus WHERE (ID == 77)
2018-01-16 22:08:40.769  SQLR result: 244;73;0;
2018-01-16 22:08:40.770  RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:     llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-01-16 22:08:40.770  SQLQ query : SELECT SwitchType, AddjValue2 FROM DeviceStatus WHERE (ID == 77)
2018-01-16 22:08:40.770  SQLR result: 0;0.0;
2018-01-16 22:08:40.770  SQLH AddTask: Request to add task: idx=77, DelayTime=0.000000, Command='Off', Level=0, Hue=-1, RelatedEvent='/home/pi/domoticz/scripts/lua/script_variable_updateHueStatus.lua'
2018-01-16 22:08:40.770  SQLQ query : SELECT ID FROM DeviceStatus WHERE (Name == 'Bedroom Dimmer Remote Button On')
2018-01-16 22:08:40.770  SQLR result: 76;
2018-01-16 22:08:40.771  SQLQ query : SELECT Type,SubType,SwitchType FROM DeviceStatus WHERE (ID == 76)
2018-01-16 22:08:40.771  SQLR result: 244;73;0;
2018-01-16 22:08:40.771  RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:     llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-01-16 22:08:40.771  SQLQ query : SELECT SwitchType, AddjValue2 FROM DeviceStatus WHERE (ID == 76)
2018-01-16 22:08:40.771  SQLR result: 0;0.0;
2018-01-16 22:08:40.771  SQLH AddTask: Request to add task: idx=76, DelayTime=0.000000, Command='On', Level=0, Hue=-1, RelatedEvent='/home/pi/domoticz/scripts/lua/script_variable_updateHueStatus.lua'
I am really considering reinstalling Domoticz completely, perhaps even changing the Pi and SD card to be sure. This situation just doesn't work. Though I am not sure if I should backup the database to save a lot of work or if that could bring back the bug into a new installation as well.
digdug3
Post by digdug3 » Saturday 20 January 2018 11:57
Please check
/etc/init.d/domoticz.sh
. Looks like domoticz isn't listening properly.
Should be something like this:
DAEMON=/home/pi/domoticz/$NAME
DAEMON_ARGS="-daemon"
#DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 80"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
Change it, restart the service and post
netstat -tulpn
or
ss -tulpn4
again
febalci
Post by febalci » Saturday 20 January 2018 12:36
I am having the same issue with 3.8153 on Synology. All of a sudden domoticz service stops and in the log files there are no clues at all. I am suspicious of the event scripts, now i am disabling them one by one to track which one have a problem. I suspect the error handling in the scripts is not mature enough to spit out an error. Maybe you can also try by disabling your 'script_time_update_hue_power.lua' script for a while...
Tweek
Post by Tweek » Saturday 20 January 2018 12:55
Please check
netstat -tulpn
or
ss -tulpn4
again
This is in my init script:
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
#DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"
#DAEMON_ARGS="$DAEMON_ARGS -loglevel 3 -debug -verbose"
After a restart of the Domoticz service/whole Pi the web interface is reachable fine. It is only after a few days/hours that the web interface goes unresponsive.
I updated the init script and after restarting the service the ports change along with it (to 8081 and 8443):
pi@raspberrypi:~ $ sudo netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      454/sshd
tcp6       0      0 :::8081                 :::*                    LISTEN      5316/domoticz
tcp6       0      0 :::22                   :::*                    LISTEN      454/sshd
tcp6       0      0 :::8443                 :::*                    LISTEN      5316/domoticz
tcp6       0      0 :::6144                 :::*                    LISTEN      5316/domoticz
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           290/avahi-daemon: r
udp        0      0 0.0.0.0:68              0.0.0.0:*                           449/dhcpcd
udp        0      0 0.0.0.0:45674           0.0.0.0:*                           5316/domoticz
udp        0      0 0.0.0.0:40122           0.0.0.0:*                           290/avahi-daemon: r
udp6       0      0 :::5353                 :::*                                290/avahi-daemon: r
udp6       0      0 :::46491                :::*                                290/avahi-daemon: r
udp6       0      0 :::546                  :::*                                449/dhcpcd
Tweek
Post by Tweek » Saturday 20 January 2018 12:58
I have had this issue for a long time, although at first it happened once every few weeks. Since adding more devices, and scripts along with them, the crashes started happening more often to even daily right now. I think you may be on to something that the script error handling could use some work. Maybe I will create a second pi that will clone this install except for the scripts to see if that matters.
domorob
Domoticz version: 3.8392
Post by domorob » Saturday 20 January 2018 14:00
i have the same issue after the latest update to beta 3.8833 on RPI2, the web server is reachable for a few minutes...
sudo service domoticz status says
Jan 20 11:10:51 domoticz systemd[1]: Starting LSB: Home Automation System...
Jan 20 11:10:51 domoticz domoticz.sh[594]: 2018-01-20 11:10:51.167 Domoticz V3.8833 (c)2012-2018 GizMoCuz
Jan 20 11:10:51 domoticz domoticz.sh[594]: 2018-01-20 11:10:51.167 Build Hash: 60050638, Date: 2018-01-19 13:22:13
Jan 20 11:10:51 domoticz domoticz.sh[594]: 2018-01-20 11:10:51.168 Startup Path: /home/pi/domoticz/
Jan 20 11:10:51 domoticz domoticz.sh[594]: domoticz: Domoticz is starting up....
Jan 20 11:10:51 domoticz domoticz[601]: Domoticz running...
Jan 20 11:10:51 domoticz systemd[1]: Started LSB: Home Automation System.
sudo service domoticz restart make the webserver for a few minutes available....
Any idea ?
febalci
Post by febalci » Saturday 20 January 2018 14:56
Especially for those scripts which have outer ip connection, like google traffic or weather information connection scripts.
Tweek
Post by Tweek » Saturday 20 January 2018 17:41
I have none of those, everything that runs so far is in-house.
febalci
Post by febalci » Saturday 20 January 2018 17:57
Now i am beginning to suspect the same thing might be valid for Python plugins also, not only the scripts. so i am testing it that way. The funny thing is when the server goes off, i start domoticz again; it goes on for 1 minute and the service stops. I have to try 2-3 times, then it goes on for another day! So far, my domoticz never worked more than 5 days. The last time it run for 5 days (last week), then i installed a new zwave device. After 3 days it starts this funny nonsense, altough I highly doubt that it is because of the zwave device. Really started pissing me off. I didn't changed anything on my Synology during that time, so that's why i am suspicious that it might be an outer influence.
Also, apart from the condition on Pi, in Synology the service also stops. I didn't checked it actually from the command line yet; but in Package Center i see that Domoticz is Stopped.
digdug3
Post by digdug3 » Sunday 21 January 2018 16:32
I disabled IPv6 on my Pi and after that did not have problems anymore.
nano /etc/sysctl.conf
and add these lines to the end:
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
net.ipv6.conf.eth0.disable_ipv6 = 1
reboot the system to disable ipv6.
Tweek
Post by Tweek » Tuesday 23 January 2018 23:35
So far, so good! Been running stable for a day and a half again.
void
Post by void » Wednesday 31 January 2018 10:16
Sorry for being the necromancer, but I've got the same issue.
Domoticz being unresponsive out without a probable cause as far as I can tell from the logs.
I've just tried the IPv6 thing, but did you guys have a good stable experience since you changed it?
And if so, is it a hardware related issue with a certain Pi version?
It's just that I've just ordered a new Pi (3B) and I want to be sure I can restore a backup on there without having the same issues all over again in case it is something in the config or a script which causes some internal stress.
Cheers,
void
Tweek
Post by Tweek » Wednesday 31 January 2018 10:39
Cheers,
void
So far I have been running on a Pi 2B and the IPv6 fix has made it completely stable for me. Not a single crash any more after the change. Not sure what the cause of the issue is (hardware or software) but if it is the same issue it should run stable for you whether or not you change to Pi 3.
ben53252642
Post by ben53252642 » Wednesday 31 January 2018 11:08
I'm seeing the same problem.
thebeetleuk
Post by thebeetleuk » Tuesday 27 March 2018 12:35
OK do I had the same issue. Disabling IP6 worked for me. Not sure whats going on tho! :)
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
thebeetleuk
Post by thebeetleuk » Sunday 01 April 2018 20:58
Reporting back that I now have the issue again even after changing this setting :(
thebeetleuk
Post by thebeetleuk » Monday 02 April 2018 18:57
OK so now I have updated to the latest version and I'm back up and running. no root cause yet but at least I have a system back up and running.
EDsteve
Post by EDsteve » Tuesday 15 May 2018 17:21
I had the same yesterday. Domoticz service was still running, but HTTP did not respond including events. Lucky i was at home and realized it one hour after.
Domoticz takes care of the temperature in my terrarium. So this bug can actually kill all my plants and animals inisde.
ed@nanopineo:~$ sudo service domoticz status
[sudo] password for ed:
? domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; bad; vendor preset: enabled)
   Active: active (running) since Wed 2018-05-09 19:17:16 CEST; 4 days ago
     Docs: man:systemd-sysv-generator(8)
  Process: 559 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SU
   CGroup: /system.slice/domoticz.service
           +-576 /home/ed/domoticz/domoticz -daemon -www 8080 -sslwww 8090
Warning: Journal has been rotated since unit was started. Log output is incomple
ed@nanopineo:~$ sudo service httpd status
? httpd.service
   Loaded: not-found (Reason: No such file or directory)
   Active: inactive (dead)
Reason: No such file or directory?? HMM
Is there a script we can use? Like:
IF HTTP = dead
restart Domoticz
be happy
For debugging: In which log files should i dig, to find more info about it?
SweetPants
Domoticz version: V4.10007
Post by SweetPants » Tuesday 15 May 2018 18:49
IF HTTP = dead
restart Domoticz
be happy
You can use monit for that. Please search the forum
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
