Python Plugin: PiMonitor
McMelloW
Target OS: Raspberry Pi
Domoticz version: V3.beta
Re: Python Plugin: PiMonitor
Post by McMelloW » Sunday 25 March 2018 22:31
No errors after the update to v3.9054. Good job
Greetings McMelloW
Xorfor
Post by Xorfor » Sunday 25 March 2018 22:35
Thnx :) !!!
McMelloW
Post by McMelloW » Friday 30 March 2018 11:26
When you change the icons of some devices to another one then the PiMonitors' original. You will receive the errors again after a restart of Domoticz, but only once.
2018-03-30 11:15:08.631 Error: (RPi Monitor) 'onStart' failed 'KeyError'.
2018-03-30 11:15:08.631 Error: (RPi Monitor) ----> Line 164 in /home/pi/domoticz/plugins/PiMonitor/plugin.py, function onStart
2018-03-30 11:15:08.631 Error: (RPi Monitor) ----> Line 59 in /home/pi/domoticz/plugins/PiMonitor/plugin.py, function onStart
It is not surprising. Replace the icons with the originals again the errors don't appears with a restart of Domoticz.
So there is something sensitive about the way you handle the icons. But this is just a cosmetic issue
Greetings McMelloW
pigloox
Post by pigloox » Saturday 14 April 2018 17:49
Hello
Is it possible to include the monitoring of another raspberry present on the network as with the Jeedom plugin?
Is this possibility studied or will not be develloped?
RPI3 Stretch (Hard disk)
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
Post by waaren » Tuesday 17 July 2018 23:13
Xorfor wrote:
Tuesday 09 January 2018 23:22
A small plugin available for the Raspberry Pi:
https://github.com/Xorfor/Domoticz-PiMonitor-Plugin
To monitor CPU speed, usage, temperature, etc.
@Xorfor,
I use this plugin on my Pi systems and it is working great. I have a feature request to add another virtual sensor that shows the amount of memory used by domoticz.
I am no linux expert, so not sure it will give an accurate result but found
sudo pmap $(cat /var/run/domoticz.pid) | grep total
as a method to get the amount of memory in use by domoticz.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Xorfor
Post by Xorfor » Thursday 19 July 2018 23:21
@waaren
Under investigation :)
DarkG
Domoticz version: 4.10076
Post by DarkG » Thursday 08 November 2018 16:32
Can you add Voltage to the Plugin?
RPi3b+ Max Cube ESPEasy RMMini
Xorfor
Post by Xorfor » Thursday 08 November 2018 23:42
Done
Xorfor
Post by Xorfor » Thursday 08 November 2018 23:43
Done
Xorfor
Post by Xorfor » Thursday 08 November 2018 23:48
Version 2.0.0 is out
  • Fixed loading images (hopefully)
  • Added memory usage Domoticz
  • Added voltage devices
  • Reformatting code, for better maintenance
Users browsing this forum: EdwinK and 4 guests
