pushover sound
tiga
Target OS: Raspberry Pi
pushover sound
Post by tiga » Thursday 04 January 2018 23:21
im testing out pushover and have the following problem:
in blockly when specifying the sound(in whatever prioroty), i get the "standard" sound on my Phone.
via the pushover-website sending a test message it works perfect!
how to solve this?
thank you!!
Denny64
Domoticz version: 3.8153
Re: pushover sound
Post by Denny64 » Friday 05 January 2018 11:20
Is "Always use default tone" unchecked on the Pushover app?
For me it works properly. Domoticz 3.5877 on Rpi3.
tiga
Re: pushover sound
Post by tiga » Friday 05 January 2018 11:23
Yes it is unchecked
Denny64
Re: pushover sound
Post by Denny64 » Friday 05 January 2018 12:30
Which domoticz version do you have?
Has the same behavior in switch notification?
tiga
Re: pushover sound
Post by tiga » Friday 05 January 2018 21:00
Version: 3.8153
in switch notification i cannot chose a sound
tiga
Re: pushover sound
Post by tiga » Friday 05 January 2018 21:25
just did a test with sending a message in lua...same result
Denny64
Re: pushover sound
Post by Denny64 » Sunday 07 January 2018 9:42
Try to set two different sounds in the app, not stock sounds, (one for normal level and one for alarm) and try to see If Domoticz works well. Don't forget to check "Always use the default tone".
If It works, then go back, uncheck "Always use the default tone" and test If different stock sounds are correctly played with Domoticz.
George
Domoticz version: V4.9700
Re: pushover sound
Post by George » Sunday 14 October 2018 14:47
Hi, Same problem here.
No matter what i tried, I alway get the default tone (Even tried with a dummy switch):
Event test schakelaar (Dummy Switch).JPG (33.1 KiB) Viewed 145 times
Played a lot with settings in App, but cant solve the problem.
settings 1.JPG (94.59 KiB) Viewed 145 times
What am i doing wrong?
Raspberry Pi 3 Model B+ | Domoticz V4.9700 (Build Date: 2018-06-23 16:24:51) | Aeotec ZW090 Z-Stick Gen5 EU
settings 1.JPG (94.59 KiB) Viewed 146 times
Event test schakelaar (Dummy Switch).JPG (33.1 KiB) Viewed 146 times
George
Re: pushover sound
Post by George » Sunday 14 October 2018 16:05
Strange, but in case i choose:
Through subsystem "all", than the sound choice works.
But Through subsystem "pushover" I alway get the default sound and sound choice plays alway default sound, no matter what i choose.
Through subsystem all sound choice works but default sound when subsystem is pushover.JPG
Through subsystem all sound choice works but default sound when subsystem is pushover.JPG (34.54 KiB) Viewed 140 times
Ofcourse I do not want to send it to all subsystems! Only to pushover.
tlkg
Domoticz version: 4.9700
Re: pushover sound
Post by tlkg » Friday 09 November 2018 17:40
Any new developments on this?
I have the same problem, when Pushover is selected, notification sound is always the "Default" regardless of what is specified.
Users browsing this forum: JoshDinsdale and 1 guest
