Update rasberry from pi 1 to pi 3
marktn
Post by marktn » Wednesday 03 January 2018 17:36
What is the best way to upgrade from rapberry pi 1 to pi3?
Mark
emme
Target OS: Raspberry Pi
Domoticz version: latest
Re: Update rasberry from pi 1 to pi 3
Post by emme » Wednesday 03 January 2018 17:41
Install a fresh new Jesse image on the PI3
install all the needed dependecies and then install Domoticz following the Wiki
after that, move the domoticz folder from PI1 to PI3 and then reboot the PI3
that should be enogh
ciao
M
"We always done this way"
marktn
Post by marktn » Wednesday 03 January 2018 18:20
emme wrote:Install a fresh new Jesse image on the PI3
ciao
M
Thanks! I will try that.
Verstuurd vanaf mijn SM-T800 met Tapatalk
jannl
Post by jannl » Wednesday 03 January 2018 19:39
Hm. I use stretch, work fine.
I would never copy the complete domoticz folder. Only the db and the scripts directory. And some other manually updated files.
marktn
Post by marktn » Wednesday 03 January 2018 20:04
What do you mean with stretch?
Is there a wiki/manual for it what to copy?
jannl
Post by jannl » Wednesday 03 January 2018 20:24
stretch is basically the successor of jessie, a new raspbian version.
There seem to be some problems however with stretch, one is when using the stable, Domoticz wants to use libssl1.1.0 (I think), which is default in jessie, but also is not safe, hence the reason it is not in stretch. On the forum is explained how to install that library manually. Normally I would suggest using the beta, but there seem to be some issues with the latests beta's....
But hey, when going to a new PI, you can install everything, test/debug etc and leave the old pi running.......that is what I did recently when going from a pi2 to a pi3 and stretch,
marktn
Post by marktn » Wednesday 03 January 2018 20:39
That will indead then the best, keep the old PI running. Installing the new one, install RFLink.
And wait how much faster domoticz is :D
jannl
Post by jannl » Wednesday 03 January 2018 20:43
success, I did not see that much difference between pi2 and pi3, not as much as between pi b+ and pi2 anyway
RezzZ
Post by RezzZ » Monday 10 September 2018 13:54
will this simple migration of domoticz folders also work with attached (usb) devices?
I have a smartmeter (P1) attached to USB, same with a aeotec zstick dongle. Will they just work out of the box eventhough the hardware/usb port might be different?
