Daikin Hardware
spiderjn
Target OS: Raspberry Pi
Domoticz version: 3.8834
Daikin Hardware
Post by spiderjn » Thursday 28 December 2017 21:49
hi,
i discover a standard hardware controler Daikin (code by gizmocuz), i try it on my first wifi and it's worked by i can't change value or acces to all command.
I discovered code letting me think that the development was made under windows (and debug).
I try to add a second hardware but nothing seems to be add to my config (Sensor,..)
there are other posts on the subject, but I would like that kind of device can be managed as standard by my installation.
how i can help to complete this interesting feature ?
Best regards
spiderjn
Re: Daikin Hardware
Post by spiderjn » Thursday 04 January 2018 10:31
Hi All
i've made some modification to existing module, Start/Stop, Set Thermostat, Led On/Off.
Now i want add a multivalue switch, but i can't find information or sample to do that in source.
Any information for help me ?
Best regards
spiderjn
Re: Daikin Hardware
Post by spiderjn » Sunday 07 January 2018 10:36
done, need to be tested by other user.
Pull created : https://github.com/domoticz/domoticz/pull/2044
Have fun
remb0
Re: Daikin Hardware
Post by remb0 » Sunday 07 January 2018 20:27
great! will test it soon.
spiderjn
Re: Daikin Hardware
Post by spiderjn » Tuesday 23 January 2018 7:51
do you have test it from beta ?
Best regards
remb0
Re: Daikin Hardware
Post by remb0 » Tuesday 23 January 2018 20:52
Yes and it works great! I will test it better tomorrow. and report it when i found something. but for now: great work!!
spiderjn
Re: Daikin Hardware
Post by spiderjn » Sunday 11 March 2018 11:20
Hi Remb0,
i search how automatize temerature set point, i can change it on web interface, but how do that with "Scénario" ?
i lost something in module ?
Best regards
tcviper
Re: Daikin Hardware
Post by tcviper » Monday 16 July 2018 11:40
This plugin/module for domoticz works very well, the only thing Im missing is, when I add the 'Mode', how am i then able to have this say "Heat", "Cool", "auto" and so on? What do I need to change for that to work?
Update:
For those wanting to know, i changed the Airco Mode to Selector and then manually added these to each button:
- Off : http://192.168.1.19/aircon/set_control_info?pow=0&mode=3&stemp=19&shum=0&f_rate=A&f_dir=0
- Cool : http://192.168.1.19/aircon/set_control_info?pow=1&mode=3&stemp=18&shum=0&f_rate=A&f_dir=0
- Heat : http://192.168.1.19/aircon/set_control_info?pow=1&mode=4&stemp=21&shum=0&f_rate=A&f_dir=0
- Auto : http://192.168.1.19/aircon/set_control_info?pow=1&mode=0&stemp=19&shum=0&f_rate=A&f_dir=0
The 192.168.1.19 is the IP of my Daikin Wifi module.
