Digoo WiFi Ip cam Watherproof
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
EdwinK
Target OS: Raspberry Pi
Re: Digoo WiFi Ip cam Watherproof
Post by EdwinK » Monday 15 January 2018 19:06
The password works fine ;), but I just can't get it to work with Domoticz :(
According to Fing the following ports are open:
23
80
554
5050
6670
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
frostwork
Post by frostwork » Tuesday 16 January 2018 8:07
oh, it works? so does domoticz even support rtsp streams (very likely port 554 here as well)?
if not you still could put it into motioneye and use its http stream url in domoticz. better than nothing.
port 23 is telnet btw. maybe you find something interesting in your cam. user root, password probably empty.
Derik
Post by Derik » Tuesday 16 January 2018 8:26
mmm can i use rtsp stream in domoticz???
I was thinking only http and https?
Should be nice to use rtsp??
Perhaps a feature request... to rob??
Or does anyone have the rtsp working?
EdwinK
Post by EdwinK » Tuesday 16 January 2018 8:37
Will try this this weekend. Bit of a hectic week.
You can't use rtsp in domoticz. Hope it will be one day.
EdwinK
Post by EdwinK » Monday 22 January 2018 22:41
frostwork wrote:
Wednesday 10 January 2018 18:41
(my digoos try to reach multiple p2p$NUMBER.cloud(-)links.(net|cn) servers)
How can I add this to Pihole? Or do I need to add those servers one by one?
frostwork
Post by frostwork » Tuesday 23 January 2018 17:19
pihole accepts wildcards, so the 4 wildcards for
cloudlinks.cn
cloudlinks.net
cloud-links.cn
cloud-links.net
should be enough.
I don't use the blacklist feature of pihole though and prefer to use my own dnsmasq.d/randomname.conf
with the "pihole dnsmasq".
EdwinK
Post by EdwinK » Thursday 25 January 2018 13:20
Thnks. I think I'm fine then.
for the othe thing, that sounds too technical for me.
EdwinK
Post by EdwinK » Wednesday 07 February 2018 12:14
At last a reaction from 'support'
Sorry for this late reply.
1. This camera has a website to view the camera in PC. Here is the link : https://eyeplus.closeli.com/
2. The onvif password of this camera is dg20160404 and user name is admin. If you wanna connect this camera to some onvif software, you should connect then in the same lan and input the onvif password.
3. After the trial subscription is over, you should insert a SD card into this camera for saving the videos. Otherwise, you could only view the live video in the app.
No word on WHY the camera doesn't want to connect anymore.
So, I would advise to STAY AWAY from this type of camera, it might be cheap, but so is support. Too bad, because the quality of the camera is great.
Derik
Post by Derik » Wednesday 07 February 2018 21:20
Only do you have perhaps a simple and good working waterproof HD camera that works under Domoticz?
EdwinK
Post by EdwinK » Tuesday 12 June 2018 13:40
i got a new one from Digoo, after mailing back and forth for about 4!! months (it seems they can only send out mails once a week I think), and ofcourse they keep blaming the user for it not working So far I had it working for 5 minutes
EdwinK
Post by EdwinK » Wednesday 13 June 2018 10:18
Found out that the camera is also know as Eyeplus, model EYEPLUS_DEV.
EdwinK
Post by EdwinK » Thursday 14 June 2018 16:59
So far I've got it working in Synology, so... there is hope. I thought I read on the changelog of one of the beta's that RTSP was possible now. Or did I just dream it?
Users browsing this forum: No registered users and 5 guests
