Aurora theme
step
Domoticz version: 4.9796
Re: Aurora theme
Post by step » Sunday 05 August 2018 1:41
I have trouble adding my two cameras to the Dashboard. I've tried several things (I thought maybe my Hikvision DS-2CD2112-I camera's may be the problem but they work fine everywhere else including the browser).
Screen Shot 2018-08-05 at 01.28.35.jpg (105.69 KiB) Viewed 2001 times
- I've set the substream to mjpg:
* used the link http://IP/Streaming/Channels/102/httppreview (real substream with mjpg)
* used the link http://IP/Streaming/Channels/1/picture (main stream with h264)
- I've set theme modes to Compact and Normal
- Made a virtual switch with a text sensor (with the links instead of Hello World)
- Tried an on/off virtual light switch with the cameras added to the active scene
- In the cameras in Domoticz, the cameras work fine:
Screen Shot 2018-08-05 at 01.22.35.png (21.69 KiB) Viewed 2001 times
- I made sure that the "camera preview in Dashboard" is set to ON in the Aurora theme settings
- I read something about a bug in domoticz where the link may have to be changed but I am unable to find the escaping characters to do so...
-- Domoticz V4.9797
-- Aurora version (most recent)
Anyone else have an idea how to get the cameras into an iFrame on the Dashboard?
blauwebuis
Target OS: Raspberry Pi
Domoticz version: current
Re: Aurora theme
Post by blauwebuis » Tuesday 07 August 2018 9:41
The Aurora theme actually has a special mode for getting camera preview images on the dashboard. But that doesn't use the iFrame feature. Instead, you attach a camera to a switch, and then place the switch on the dashboard.
step
Re: Aurora theme
Post by step » Wednesday 08 August 2018 11:16
Please do explain. I've connected the camera's to a virtual switch, an existing switch, a group and a group scene (all lights and blinds) and put them on the Dashboard to no avail. Am I missing something here? What kind of switch?
The camera works if I click on the camera on the Dashboard while it pops up... however no preview image on the Dashboard.
Type of switches I just tried:
blauwebuis
Re: Aurora theme
Post by blauwebuis » Wednesday 08 August 2018 11:54
You're doing it correctly.
Are you in compact mode perhaps?
step
Re: Aurora theme
Post by step » Wednesday 08 August 2018 23:37
I was, but changing it to Normal mode doesn't change anything. Except for the larger columns etc.
- Checked to see if camera was still connected to the switch
- Popup camera mode works (clicking the small icon to enlarge)
- Switched browser (Safari to Firefox)
- Cleared cache etc
blauwebuis
Re: Aurora theme
Post by blauwebuis » Saturday 11 August 2018 19:51
And you've enabled showing the 3 highlighted items? And it's in those 3?
step
Re: Aurora theme
Post by step » Sunday 12 August 2018 22:41
Yes:
Screen Shot 2018-08-12 at 22.40.54.png (42.1 KiB) Viewed 1684 times
dpui7736
Domoticz version: 4.9700
Re: Aurora theme
Post by dpui7736 » Tuesday 14 August 2018 9:49
I have some problems.
I only see Room selector in Temperature page. Not in utility neither Switches page.
Utility page have different style (Black letters not white,...)
Thanks,
madpatrick
Re: Aurora theme
Post by madpatrick » Wednesday 05 September 2018 22:24
I hope some one can help me on this.
I like to change the background color on the mobile theme.
This is now white, but i like to change this to for examply light grey
Where can i change this and which line do i need to change
thanks for the support
ClearOS v7.5.0 - Toon2 v4.19.10 (rooted) - Domoticz v4.9700
jannnfe
Re: Aurora theme
Post by jannnfe » Thursday 13 September 2018 0:16
Same thing here. Nothing works. Someone any ideas?
jeanclic
Re: Aurora theme
Post by jeanclic » Thursday 13 September 2018 7:53
I have a camera in my highlighted items on my dashboard, and it is working perfectly...
Maybe try to put your camera as first in your switch list ?
Send via Tapatalk
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
CLEMENT99
Re: Aurora theme
Post by CLEMENT99 » Friday 21 September 2018 8:59
In the system settings, check your Dashboard Mode, it must be set in normal mode.
In the theme settings, check Show three highlighted items (must be checked) and Camera previews on the dashboard (must be checked).
andyesten
Re: Aurora theme
Post by andyesten » Saturday 13 October 2018 22:53
I am using Domoticz version 4.9700 and have installed the Aurora theme as described, and restarted Domoticz. But the theme is not showing up in the theme select list. Am I overlooking something?
Alexander
itjensen
Re: Aurora theme
Post by itjensen » Saturday 20 October 2018 17:43
Send via Tapatalk
Thanks, I have tried many things and putting the camera first in switch list solved my preview problem.
I am using a Xiaomi Dafang camera. My selector switch now both display video and have up, down, left, right control buttons.
Pandabeer
Domoticz version: 4.9954
Re: Aurora theme
Post by Pandabeer » Sunday 28 October 2018 10:09
I'm facing problems with the Aurora theme - When in dashboard or other sreens I try to get the trend from e.g. power usage - but no new window will be shown - when I use another theme - without any problems I will get the requested graphs from power usage / consumption / heat / temperature etc (I use the latest version of Chrome and Domoticz v4.10111)
Hope somebody can help,
Thank you
Patricen
Domoticz version: Beta rel
Bug found
Post by Patricen » Wednesday 31 October 2018 12:19
I mentioned that there is not a sufficient space on the page footer for switches log.
Clicking on the chart context menu works, but it is not possible to reach "Download CSV" line.
Best,
Patrice
blauwebuis
Re: Aurora theme
Post by blauwebuis » Thursday 01 November 2018 18:36
I fixed the events page. It should now work fine.
Ivanhoe1
Re: Aurora theme
Post by Ivanhoe1 » Friday 02 November 2018 16:53
Really nice theme!
How can I change the boxsize for my camera picture on dashboard? Now it gets croped so im missing like 50% in height.
madpatrick
Re: Aurora theme
Post by madpatrick » Saturday 03 November 2018 11:11
How can i change the color of the text at the Utility page ?
These are still black and not easy to read
JHO01
Domoticz version: 49700
Re: Aurora theme
Post by JHO01 » Sunday 04 November 2018 19:58
Great theme, is it possible to get Spotify on the dashboard, showing the current song?
RPI-3, Z-stick Gen5, RFlink, 1-wire DS18B20, Fibaro switches, various RF-433 sockets, , BMP018
