Aurora theme
step
Domoticz version: 4.9796
Re: Aurora theme
Post by step » Sunday 05 August 2018 1:41
I have trouble adding my two cameras to the Dashboard. I've tried several things (I thought maybe my Hikvision DS-2CD2112-I camera's may be the problem but they work fine everywhere else including the browser).
Screen Shot 2018-08-05 at 01.28.35.jpg (105.69 KiB) Viewed 478 times
- I've set the substream to mjpg:
* used the link http://IP/Streaming/Channels/102/httppreview (real substream with mjpg)
* used the link http://IP/Streaming/Channels/1/picture (main stream with h264)
- I've set theme modes to Compact and Normal
- Made a virtual switch with a text sensor (with the links instead of Hello World)
- Tried an on/off virtual light switch with the cameras added to the active scene
- In the cameras in Domoticz, the cameras work fine:
Screen Shot 2018-08-05 at 01.22.35.png (21.69 KiB) Viewed 478 times
- I made sure that the "camera preview in Dashboard" is set to ON in the Aurora theme settings
- I read something about a bug in domoticz where the link may have to be changed but I am unable to find the escaping characters to do so...
-- Domoticz V4.9797
-- Aurora version (most recent)
Anyone else have an idea how to get the cameras into an iFrame on the Dashboard?
blauwebuis
Target OS: Raspberry Pi
Domoticz version: current
Re: Aurora theme
Post by blauwebuis » Tuesday 07 August 2018 9:41
The Aurora theme actually has a special mode for getting camera preview images on the dashboard. But that doesn't use the iFrame feature. Instead, you attach a camera to a switch, and then place the switch on the dashboard.
step
Re: Aurora theme
Post by step » Wednesday 08 August 2018 11:16
Please do explain. I've connected the camera's to a virtual switch, an existing switch, a group and a group scene (all lights and blinds) and put them on the Dashboard to no avail. Am I missing something here? What kind of switch?
The camera works if I click on the camera on the Dashboard while it pops up... however no preview image on the Dashboard.
Type of switches I just tried:
blauwebuis
Re: Aurora theme
Post by blauwebuis » Wednesday 08 August 2018 11:54
You're doing it correctly.
Are you in compact mode perhaps?
step
Re: Aurora theme
Post by step » Wednesday 08 August 2018 23:37
I was, but changing it to Normal mode doesn't change anything. Except for the larger columns etc.
- Checked to see if camera was still connected to the switch
- Popup camera mode works (clicking the small icon to enlarge)
- Switched browser (Safari to Firefox)
- Cleared cache etc
blauwebuis
Re: Aurora theme
Post by blauwebuis » Saturday 11 August 2018 19:51
And you've enabled showing the 3 highlighted items? And it's in those 3?
step
Re: Aurora theme
Post by step » Sunday 12 August 2018 22:41
Yes:
Screen Shot 2018-08-12 at 22.40.54.png (42.1 KiB) Viewed 161 times
dpui7736
Domoticz version: 4.9700
Re: Aurora theme
Post by dpui7736 » Tuesday 14 August 2018 9:49
I have some problems.
I only see Room selector in Temperature page. Not in utility neither Switches page.
Utility page have different style (Black letters not white,...)
Thanks,
