Aurora theme
devros
Re: Aurora theme
Post by devros » Friday 08 June 2018 10:04
Im playing with theme css, and have idea about custom image (PNG with transparency) on bottom page backgrounds for each Room (different energy monitoring ,tv, irrigation, security...).
For whole theme it works pretty well (i can post screenshots and css). But looks like, i cant change it individualy because rooms are not using any css identifiers.... Any idea how to solve this?
rhendriks
Target OS: Raspberry Pi
Domoticz version: Newest
Re: Aurora theme
Post by rhendriks » Monday 11 June 2018 19:29
Theme button is gone.
I have update several times but there is no button.
How can I fix this?
Xztraz
Re: Aurora theme
Post by Xztraz » Tuesday 12 June 2018 12:12
How can I fix this?
Running beta?
Test other browser with clean cache and files
SweetPants
Domoticz version: V4.9701
Re: Aurora theme
Post by SweetPants » Tuesday 12 June 2018 12:35
How can I fix this?
No problem on V3.9629
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
rhendriks
Re: Aurora theme
Post by rhendriks » Tuesday 12 June 2018 16:52
How can I fix this?
I mean this , normally stay under " Backup/Herstel" the theme button.
SweetPants
Re: Aurora theme
Post by SweetPants » Tuesday 12 June 2018 19:17
You mean like this?
rhendriks
Re: Aurora theme
Post by rhendriks » Tuesday 12 June 2018 22:14
You mean like this?
Yes
SweetPants
Re: Aurora theme
Post by SweetPants » Tuesday 12 June 2018 22:18
You mean like this?
Yes
Well, as you can see it's still there in V3.9629 :mrgreen: :mrgreen: :mrgreen:
Xztraz
Re: Aurora theme
Post by Xztraz » Wednesday 13 June 2018 16:30
I'm on latest beta and i see the theme button.
looking at the code for that
// actually adding the settings tab.
    if (typeof(Storage) !== "undefined") { // Do we even have theme settings?
        if (!$('#tabtheme').length){
            // modifying settings menu
            $('#tabs .pull-right').before('<li id="themeTabButton"><a data-target="#tabtheme" data-toggle="tab" data-i18n="Theme">Theme</a></li>');
            // If were on a mobile phone, make the settingsmenu a dropdown.
            $('#tabs li:not(.pull-right)').click(function() {
                if ($(window).width() < 480) {
                    $(this).parent().toggleClass('menuopen');
                    if( !$(this).parent().hasClass('menuopen') ){
                        $(this).siblings('li:not(.pull-right)').slideUp("fast");
                    }else{
                        $(this).siblings('li:not(.pull-right)').slideDown("fast");
                }else{
                    $(this).siblings().show(); //safety, if user scaled/rotated the screen.
                    $(this).parent().removeClass('menuopen');
            // inserting the themesettings.html
            $('#my-tab-content').append('<div class="tab-pane" id="tabtheme"><section id="theme">Loading..</section></div>');
            $('#my-tab-content #theme').load("acttheme/themesettings.html",loadedSettingsHTML);
            // loadedSettingsHTML() was here
    } else {
        // No Web Storage support.. hmm.
one fault condition could be no web storage. so have you blocked web pages to store local files or something in your browser? did you try with another browser?
Maes
Re: Aurora theme
Post by Maes » Thursday 14 June 2018 13:01
When I change any settings and press save, all settings are reverted to default.
I'm using a baseURL in my domoticz, perhaps this needs special configuration with aurora?
I've tried using the parameter baseURL in custom.js but it doesn't do anything..
devros
Re: Aurora theme
Post by devros » Thursday 14 June 2018 13:54
Setting in aurora is saved afaik localy, so it looks like problem with you browser (cookies disabled or private browsing enabled :) )
Maes
Re: Aurora theme
Post by Maes » Thursday 14 June 2018 14:23
Thanks for the help.
I checked and my chrome browser was still in pornhub mode.
I turned it off and the settings are "saved". However, the menu bar keeps going back to the top (but the setting clearly states that it should be a side bar)
devros
Re: Aurora theme
Post by devros » Thursday 14 June 2018 14:28
try reset theme to default setting and reset app-cache
Maes
Re: Aurora theme
Post by Maes » Thursday 14 June 2018 14:36
I tried this just now but it doesn't work.
If I uncheck the setting "Main menu as a sidebar" and check it again then the menu goes to the side. However, once I press "APPLY SETTINGS" the menu bar goes back to the top. The setting is still saved as checked, though.
jannnfe
Re: Aurora theme
Post by jannnfe » Thursday 14 June 2018 23:46
i love the Aurora Theme but i'm not able to get the Camera Live Stream in Dashboard.
It looks like this:
The attachment Bildschirmfoto 2018-06-14 um 23.43.04.png is no longer available
and my Camera is linked to this devices:
Bildschirmfoto 2018-06-14 um 23.43.04.png (118.1 KiB) Viewed 299 times
In the Settings the Camera Option of Aurora is enabled.
What to do?
Thanks! :)
devros
Re: Aurora theme
Post by devros » Friday 15 June 2018 8:42
It looks like this:
What to do?
Thanks! :)
Switch Dashboard mode from compact to normal...
then it should work
jannnfe
Re: Aurora theme
Post by jannnfe » Friday 15 June 2018 11:23
It looks like this:
What to do?
Thanks! :)
then it should work
No sorry also in Normal mode there is no preview of the camera live feed.
Cleared cache and browser history.
