Weekly programming
elgarne
Target OS: Raspberry Pi
Re: Weekly programming
Post by elgarne » Friday 03 August 2018 11:09
Unfortunately, I don't think so. I'm under 4.9701 and those functions do not exist.
syrhus
Domoticz version: 4.9700
Post by syrhus » Friday 03 August 2018 11:15
I didn't work on my domoticz for a while.
I will try to upgrade to the latest version and modify this tool on septembre.
syrhus
Post by syrhus » Wednesday 19 September 2018 9:49
I have updated the source code to work with the latest version v4.9700
https://gist.github.com/syrhus/8fbb01fb ... be210993c8
elgarne
Post by elgarne » Thursday 20 September 2018 13:59
I checked two days ago and thought you forgot about it. Merci beaucoup.
syrhus
Post by syrhus » Thursday 20 September 2018 14:11
Hi elgarne
You're welcome and thank you for the french reply (are your french?) ;)
I'm working on a new functionality, showing 2 weeks (odd & even) because some people suggest that as they are living with 2 different kind of weeks,1 with child and the other without.
elgarne
Post by elgarne » Thursday 20 September 2018 14:59
I'm absolument french and living in Paris (area) ;)
And I'm exactly in the same situation as people asking for odd and even weeks.
I needed to empty the browser cache to have it working.
syrhus
Post by syrhus » Thursday 20 September 2018 15:42
Good news, I've updated the code on Github to see Odd&Even week numbers
planning.css and planning.js file have changed.
Remove the application cache of the web navigator.
Let me know if it is working fine with this new version on 2 weeks (and if it is still working on 1 week)
elgarne
Post by elgarne » Thursday 20 September 2018 15:46
Seems working fine. Could not find how to empty cache on Safari (the menu command does not seem to work) but using the private mode works fine.
syrhus
Post by syrhus » Thursday 20 September 2018 16:00
Great!
You can force to reload all cached files by changing the ref in the html5.appcache file on the www folder
CACHE MANIFEST
# ref 2
CACHE:
Patricen
Domoticz version: Beta rel
Post by Patricen » Thursday 20 September 2018 21:55
This feature is really great!
What about requesting that it enters in the mainstream of Domoticz source code?
Patrice
garethhowell
Domoticz version: 3.9317
Post by garethhowell » Wednesday 10 October 2018 18:43
I'm obviously not getting something here.
I'm running 4.9700. I've downloaded the latest from github, copied the files to the necessary places and updated html5.appcache to force the browser cache to update. However, I see no change in the UI. I just see the original timer screen. I even tried restarting the domoticz service.
I see no errors in the console, but I also don't see the new js file.
One thing, despite having added new css and js files, there is no instruction to add them to the appcache. I take it this means they don't get cached.
Gareth
syrhus
Post by syrhus » Monday 29 October 2018 16:42
Hi gareth
This is really not easy to clear the application cache. Are you using Chrome?
About the application cache, keep it mind this is a absolutely useless! Application cache is used for offline application; how Domoticz could work offline? You see a screen with wrong state and wrong values!
So, the manifest should be adjust to cache only the web page for the offline alert. That's all.
About your concern, have you tried to open your web site in private mode? Is it working fine?
garethhowell
Post by garethhowell » Tuesday 30 October 2018 9:22
Thanks for coming back to me.
I’d been having a number of UI display-related issues that affected the display of devices: not just this module.
Eventually, I did a clean install of Domoticz and those problems went away. I’ve not got around to trying this module again, but I will soon.
syrhus
Post by syrhus » Tuesday 30 October 2018 15:40
Oups!!!
I'm sorry, I thought i fixed a bug on table header and I left a bug on it.
So, pleae, download the new fixed planning.js file from github
Apologized for this.
