Energy measurement with espeasy and pzem-004t
Alitoy
Target OS: Raspberry Pi
Re: Energy measurement with espeasy and pzem-004t
Post by Alitoy » Wednesday 14 March 2018 21:03
More information about the connection PZEM-004T :
tontze
Post by tontze » Wednesday 14 March 2018 21:08
Yeah ok, so this is not ideal for computing one devices energy usage(without braking its cable), shame :/
But, i would still prefer clamp. Using clamp i wouldnt need to take wire off from main electric box to fit it in to wire.
Rpi 3 / Razberry 2
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
ESP82xx
Alitoy
Post by Alitoy » Friday 23 March 2018 16:31
aleph0 wrote:
Tuesday 13 March 2018 22:44
Hi ! The PZEM-004T is in the "testing" mode, and I'm pretty sure we didn't port it to the 2018-03-13 version. I might try to compile it for this version on week-end, but won't have any hardware to test it anymore :/ Or you can use our development version here https://www.letscontrolit.com/forum/vie ... =30#p21383
Hi, aleph0
Did you have time to compile a newer version? ))
tontze
Post by tontze » Saturday 24 March 2018 13:50
gajotnt wrote:
Monday 18 December 2017 13:19
Officially supported in Tasmota 5.10.0b :D
On which device name ? Just did install latest sonoff-tasmota, but cannot find pzem under devices ?
I can see it enabled in config.user, but its not in devices list ? Is it supported only through sonoff device ?
Rpi 3 / Razberry 2
Mi Light
ESP82xx
aleph0
Domoticz version: 4.9728
Post by aleph0 » Monday 26 March 2018 16:18
Alitoy wrote:
Tuesday 13 March 2018 23:19
No problems ! I can test the new version.
And report the results. )))
I would be happy if you trust me to test the new 2018-03-13 version. )
Ok then ! Here it is in version 2018-03-26, tell us what ;-)
http://88.121.39.75/photos/domoticz/ESP ... re.bin.zip
I expect some problems because I recompiled it against the ESPeasySoftwareSerial provided in the 2018-03-26 to avoid duplicating the libraries, but it's not the version recommended by the original author of the plugin. So let's try and see !
tontze
Post by tontze » Friday 30 March 2018 13:25
JST 2.5 XH 4-Pin Connector Plug
That seems to be the connector that fits to white 4pin connector on pzem.
Rpi 3 / Razberry 2
Mi Light
ESP82xx
lyubomir
Post by lyubomir » Sunday 01 April 2018 19:05
Today I tried to setup PZEM-004t with domoticz but without success.
I received this error in domoticz log:
2018-04-01 20:00:49.208 Error: EventSystem: in pzem1: [string "--[[Script to read infos from espeasy/pzem-00..."]:42: bad argument #1 to 'match' (string expected, got nil)
Can you please tell me how can solve the issue?
PS. I solved the issue with domoticz update.
Dim33
Post by Dim33 » Wednesday 29 August 2018 0:14
Hello everybody,
My energy measurement is operationnal by following this post and this one https://www.letscontrolit.com/forum/vie ... f=5&t=2595.
I use an ESP8266_4096.
But I have a problem :
- if I boot my ESP connected to the PZEM. My ESP doesn't start (no effect if I push on RESET button),
- If I boot my ESP (not connected to the PZEM), this one start normaly and after i can connect the PZEM to the ESP and the Energy measurement is OK.
This problem is painful because if i have a power cut, my Energy measurement does not restart.
Can you help me ?
Thanks in advance.
corederoma82
Post by corederoma82 » Wednesday 29 August 2018 13:25
Thanks for this great job,
but I don't understand how link pzem004 to the power (I mean physical connection).
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826
Dim33
Post by Dim33 » Thursday 30 August 2018 22:52
Hello everybody,
Can you help me ?
Thanks in advance.
I modified the GPIO pin : GPIO-12 and 13 instead of GPIO-14 and 15 and all is OK.
ayasystems
Post by ayasystems » Wednesday 19 September 2018 14:25
Could be better use ESPEASY rules to split and send data to Domoticz
on Energy#Current do
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=30&nvalue=0&svalue=[Energy#Voltage]
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=31&nvalue=0&svalue=[Energy#Current]
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=32&nvalue=0&svalue=[Energy#ActivePower]
endon
aleph0
Post by aleph0 » Friday 21 September 2018 10:35
Right ! Much better solution :-) Thanks for pointing this out
sincze
Domoticz version: 4.9700
Post by sincze » Sunday 23 September 2018 13:18
I started with this pzem-004t as well, but due to some posts regarding it's safety I switched to POW R2, however some nice things to know.
To avoid 'spamming' domoticz you could add a virtual device as well.. store the 'on change' values in that device.. and send the data (if changed) to domoticz every 30 sec or so. Great examples on the website: https://www.letscontrolit.com/forum/vie ... =50#p30912
Examples:
On System#Boot do
	TaskValueSet 5,1,0
	TaskValueSet 5,2,0
	TaskValueSet 5,3,0
	TaskValueSet 5,4,0
	TimerSet,1,30
EndOn
on Rules#Timer=1 do
	if [Calculation#Voltage]!=[Energy#Voltage]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=600&nvalue=0&svalue=[Energy#Voltage] // Voltage
		TaskValueSet 5,1,[Energy#Voltage]
	endif
	if [Calculation#Power]!=[Energy#Power]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=603&nvalue=0&svalue=[Energy#Power] // KwH.
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=608&nvalue=0&svalue=[Energy#Power] // Watt
		TaskValueSet 5,2,[Energy#Power]
	endif
	if [Calculation#Current]!=[Energy#Current]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=604&nvalue=0&svalue=[Energy#Current] // Amp
		TaskValueSet 5,3,[Energy#Current]
	endif
	TaskValueSet 5,4,[Energy#Pulses]
	TimerSet,1,30
endon
on Clock#Time=All,**:*0 do
endon
Using Pass2php since 2016-12
LAN: RFLink, P1-Port, OTGW, MySensors
USB: RFXCom, ZWave
WIFI: Mi-light Wifi-Bridge, Sonoff, ESP8266, Xiaomi Gateway
Solar: Omnik Inverter, PVOutput
Video: Kodi clients with Harmony HUB
Sensors: You name it I probably got 1.
