Energy measurement with espeasy and pzem-004t
Alitoy
Target OS: Raspberry Pi
Re: Energy measurement with espeasy and pzem-004t
Post by Alitoy » Wednesday 14 March 2018 21:03
More information about the connection PZEM-004T :
tontze
Post by tontze » Wednesday 14 March 2018 21:08
Yeah ok, so this is not ideal for computing one devices energy usage(without braking its cable), shame :/
But, i would still prefer clamp. Using clamp i wouldnt need to take wire off from main electric box to fit it in to wire.
Rpi 3 / Razberry 2
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
ESP82xx
Alitoy
Post by Alitoy » Friday 23 March 2018 16:31
aleph0 wrote:
Tuesday 13 March 2018 22:44
Hi ! The PZEM-004T is in the "testing" mode, and I'm pretty sure we didn't port it to the 2018-03-13 version. I might try to compile it for this version on week-end, but won't have any hardware to test it anymore :/ Or you can use our development version here https://www.letscontrolit.com/forum/vie ... =30#p21383
Hi, aleph0
Did you have time to compile a newer version? ))
tontze
Post by tontze » Saturday 24 March 2018 13:50
gajotnt wrote:
Monday 18 December 2017 13:19
Officially supported in Tasmota 5.10.0b :D
On which device name ? Just did install latest sonoff-tasmota, but cannot find pzem under devices ?
I can see it enabled in config.user, but its not in devices list ? Is it supported only through sonoff device ?
Rpi 3 / Razberry 2
Mi Light
ESP82xx
aleph0
Domoticz version: 4.9728
Post by aleph0 » Monday 26 March 2018 16:18
Alitoy wrote:
Tuesday 13 March 2018 23:19
No problems ! I can test the new version.
And report the results. )))
I would be happy if you trust me to test the new 2018-03-13 version. )
Ok then ! Here it is in version 2018-03-26, tell us what ;-)
http://88.121.39.75/photos/domoticz/ESP ... re.bin.zip
I expect some problems because I recompiled it against the ESPeasySoftwareSerial provided in the 2018-03-26 to avoid duplicating the libraries, but it's not the version recommended by the original author of the plugin. So let's try and see !
tontze
Post by tontze » Friday 30 March 2018 13:25
JST 2.5 XH 4-Pin Connector Plug
That seems to be the connector that fits to white 4pin connector on pzem.
Rpi 3 / Razberry 2
Mi Light
ESP82xx
lyubomir
Post by lyubomir » Sunday 01 April 2018 19:05
Today I tried to setup PZEM-004t with domoticz but without success.
I received this error in domoticz log:
2018-04-01 20:00:49.208 Error: EventSystem: in pzem1: [string "--[[Script to read infos from espeasy/pzem-00..."]:42: bad argument #1 to 'match' (string expected, got nil)
Can you please tell me how can solve the issue?
PS. I solved the issue with domoticz update.
Dim33
Post by Dim33 » Wednesday 29 August 2018 0:14
Hello everybody,
My energy measurement is operationnal by following this post and this one https://www.letscontrolit.com/forum/vie ... f=5&t=2595.
I use an ESP8266_4096.
But I have a problem :
- if I boot my ESP connected to the PZEM. My ESP doesn't start (no effect if I push on RESET button),
- If I boot my ESP (not connected to the PZEM), this one start normaly and after i can connect the PZEM to the ESP and the Energy measurement is OK.
This problem is painful because if i have a power cut, my Energy measurement does not restart.
Can you help me ?
Thanks in advance.
corederoma82
Post by corederoma82 » Wednesday 29 August 2018 13:25
Thanks for this great job,
but I don't understand how link pzem004 to the power (I mean physical connection).
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826
Dim33
Post by Dim33 » Thursday 30 August 2018 22:52
Hello everybody,
Can you help me ?
Thanks in advance.
I modified the GPIO pin : GPIO-12 and 13 instead of GPIO-14 and 15 and all is OK.
ayasystems
Post by ayasystems » Wednesday 19 September 2018 14:25
Could be better use ESPEASY rules to split and send data to Domoticz
on Energy#Current do
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=30&nvalue=0&svalue=[Energy#Voltage]
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=31&nvalue=0&svalue=[Energy#Current]
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=32&nvalue=0&svalue=[Energy#ActivePower]
endon
aleph0
Post by aleph0 » Friday 21 September 2018 10:35
Right ! Much better solution :-) Thanks for pointing this out
sincze
Domoticz version: 4.9700
Post by sincze » Sunday 23 September 2018 13:18
I started with this pzem-004t as well, but due to some posts regarding it's safety I switched to POW R2, however some nice things to know.
To avoid 'spamming' domoticz you could add a virtual device as well.. store the 'on change' values in that device.. and send the data (if changed) to domoticz every 30 sec or so. Great examples on the website: https://www.letscontrolit.com/forum/vie ... =50#p30912
Examples:
On System#Boot do
	TaskValueSet 5,1,0
	TaskValueSet 5,2,0
	TaskValueSet 5,3,0
	TaskValueSet 5,4,0
	TimerSet,1,30
EndOn
on Rules#Timer=1 do
	if [Calculation#Voltage]!=[Energy#Voltage]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=600&nvalue=0&svalue=[Energy#Voltage] // Voltage
		TaskValueSet 5,1,[Energy#Voltage]
	endif
	if [Calculation#Power]!=[Energy#Power]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=603&nvalue=0&svalue=[Energy#Power] // KwH.
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=608&nvalue=0&svalue=[Energy#Power] // Watt
		TaskValueSet 5,2,[Energy#Power]
	endif
	if [Calculation#Current]!=[Energy#Current]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=604&nvalue=0&svalue=[Energy#Current] // Amp
		TaskValueSet 5,3,[Energy#Current]
	endif
	TaskValueSet 5,4,[Energy#Pulses]
	TimerSet,1,30
endon
on Clock#Time=All,**:*0 do
endon
Using Pass2php since 2016-12
LAN: RFLink, P1-Port, OTGW, MySensors
USB: RFXCom, ZWave
WIFI: Mi-light Wifi-Bridge, Sonoff, ESP8266, Xiaomi Gateway
Solar: Omnik Inverter, PVOutput
Video: Kodi clients with Harmony HUB
Sensors: You name it I probably got 1.
Piacco
Post by Piacco » Saturday 20 October 2018 22:46
I want to push the data of the pzem script into influxdb, but this doesn't work.
After som reading on the wiki I found out that i should use JSON API to update my Dummy sensors in stead of ['UpdateDevice'], how can i change this?
Domoticz wiki:
Note to Virtual / Dummy sensors: If the HTTP link or MQTT is not sending any values to the database, check the update method of your virtual sensors in your scripts. If using the ['UpdateDevice'] method, you will directly write the value to the internal database without triggering an HTTPlink or MQTT update for this sensor. Better is to use the JSON API of Domoticz and update your virtual sensors this way.
An alternative is to use ESPEASY but i don´t no how to do this :(
endon
Users browsing this forum: herscotty and 0 guests
