Persistent data as a variable
wizzard72
Target OS: Raspberry Pi
Post by wizzard72 » Thursday 07 December 2017 21:35
I'm building a general script. The script stores persistent data.
In the first part of the script I have defined the persistent data:
    active = true,
    logging = {
		level = domoticz.LOG_INFO, -- Uncomment to override the dzVents global logging setting
		marker = 'TEST '
		devices  = {
			'Wasmachine (W)',
			'Wasmachine',
			'Slaapkamer Paul Schakelaar',
			'Slaapkamer Paul Schakelaar (W)',
			'Dimmer WC 1ste',
			'Dimmer WC 1ste (W)',
			'Dimmer WC BG',
			'Dimmer WC BG (W)',
			'Espressomachine',
			'Espressomachine (W)'
	data = {
        WattWasmachine = { history = true, maxMinutes = 6 },
        WattSlaapkamerPaulSchakelaar = { history = true, maxMinutes = 10 },
        WattDimmerWC1ste = { history = true, maxMinutes = 10 },
        WattDimmerWCBG = { history = true, maxMinutes = 10 },
        WattEspressomachine = { history = true, maxMinutes = 10 }
The main part of the script contains code to store the actual KwH:
domoticz.data.WattWasmachine.add(sensor.WhActual)
This works. But I want more flexibility.
The part 'WattWasmachine' in 'domoticz.data.WattWasmachine.add(sensor.WhActual)' is the part that changes. So for my 5 persistent data entries I have to create 5 lines of code:
domoticz.data.WattSlaapkamerPaulSchakelaar.add(sensor.WhActual)
domoticz.data.WattDimmerWC1ste.add(sensor.WhActual)
domoticz.data.WattDimmerWCBG.add(sensor.WhActual)
domoticz.data.WattEspressomachine.add(sensor.WhActual)
I would rather have something like this:
domoticz.data.persistentdata(WattWasmachine).add(sensor.WhActual)
So 'WattWasmachine' becomes more like a variable. With variables I can do cool stuff. Like:
WattDevice = "Watt" .. string.gsub(device.name, "%s+", "")
domoticz.data.persistentdata(WattDevice).add(sensor.WhActual)
Is something like this possible? Or over time in a new version?
dannybloe
Re: Persistent data as a variable
Post by dannybloe » Thursday 07 December 2017 21:55
There’s no need actually. Just create a table with all your data and put that in your persistent variable. ...data.myvar.add({ a=1, b=2 })
You can access it like: ...data.myVar.a or data.myVar.b.
dannybloe
Post by dannybloe » Thursday 07 December 2017 22:02
Well, it's not entirely correct what I wrote. You are using historical data so that's a bit different:
Adding:
domoticz.data.myVar.add({ a=1, b=2, c=3})
Using:
local latest = domoticz.data.myVar.getLatest()
print(latest.b)
-- update
latest.b = latest.b + 1
domoticz.data.myVar.add( latest ) -- add a new table to the history.
But, you only have one history chain for myVar. Not per item in the table. So if you need the historical data then you do need separate variables.
wizzard72
Post by wizzard72 » Thursday 07 December 2017 23:02
I have a little trouble understanding it.
My code:
    active = true,
    logging = {
		marker = 'TEST '
		devices  = {
			'Wasmachine (W)',
			'Wasmachine',
			'Dimmer WC 1ste',
			'Dimmer WC BG',
			'Dimmer WC BG (W)',
			'Espressomachine',
	data = {
	-- actual event code
	-- in case of a timer event or security event, device == nil
	    -- Variables to customize ------------------------------------------------
        -- Variables -------------------------------------------------------------
        local CurrentTime = os.time()
        -- Function --------------------------------------------------------------
        -- MAIN ------------------------------------------------------------------
        if (device.state == "On") then
            domoticz.notify("ACTIVATE",device.name .. " activated#I let you know when device " .. device.name .. " is turned off",2,SOUND_SIREN)
        elseif (device.state == "Off") then
            domoticz.notify("DEACTIVATED",device.name .. " is deactivated",2,SOUND_SIREN)
        domoticz.changedDevices().forEach(function(device)
            if (device.name == "Wasmachine (W)") then
                -- Store KwH in persistent data
                domoticz.data.WattWasmachine.add(device.WhActual)
                -- calculate average
                local average = domoticz.data.WattWasmachine.avg()
                -- if last 10 reading Watt is 0, then switchoff the device
                if (average == 0) then
                    domoticz.devices('Wasmachine').switchOff().checkFirst()
            elseif (device.name == "Slaapkamer Paul Schakelaar (W)") then
                domoticz.data.WattSlaapkamerPaulSchakelaar.add(device.WhActual)
                local average = domoticz.data.WattSlaapkamerPaulSchakelaar.avg()
                    domoticz.devices('Slaapkamer Paul Schakelaar').switchOff().checkFirst()
            elseif (device.name == "Dimmer WC 1ste (W)") then
                domoticz.data.WattDimmerWC1ste.add(device.WhActual)
                local average = domoticz.data.WattDimmerWC1ste.avg()
                    domoticz.devices('Dimmer WC 1ste').switchOff().checkFirst()
            elseif (device.name == "Dimmer WC BG (W)") then
                domoticz.data.WattDimmerWCBG.add(device.WhActual)
                local average = domoticz.data.WattDimmerWCBG.avg()
                    domoticz.devices("Dimmer WC BG").switchOff().checkFirst()
            elseif (device.name == "Espressomachine (W)") then
                domoticz.data.WattEspressomachine.add(device.WhActual)
                local average = domoticz.data.WattEspressomachine.avg()
                    domoticz.devices('Espressomachine').switchOff().checkFirst()
        end)
I want to simplify my code. I have a lot of 'elseif' statements. Every 'elseif' statement is almost the same, except the device/sensor name. My logic says that it can be made easyer :-)
dannybloe
Post by dannybloe » Friday 08 December 2017 9:46
Ok, here is my simplified version (for dzVents 2.3.0). Couple of comments. You don't have to use the changed devices collection anymore (I'm removing it from the documentation for 2.4.0) as there is always only one device in that collection and that's the device that was changed (second parameter of your execute function). So, I created a lookup table to match the energy device to the switch and made sure the persistent variables exactly match the name of the energy device (and removed some unnecessary code and corrected some errors):
-- create a lookup table that matches a usage
-- device to the accompanying switch
local USAGE_DEVICES = {
	['Wasmachine (W)'] ='Wasmachine',
	['Slaapkamer Paul Schakelaar (W)']= 'Slaapkamer Paul Schakelaar',
	['Dimmer WC 1ste (W)'] = 'Dimmer WC 1ste',
	['Dimmer WC BG (W)'] = 'Dimmer WC BG',
	['Espressomachine (W)'] = 'Espressomachine'
	logging = {
		marker = 'TEST '
		devices = {
			'Wasmachine (W)',
			'Wasmachine',
			'Dimmer WC 1ste',
			'Dimmer WC BG',
			'Dimmer WC BG (W)',
			'Espressomachine',
	data = { -- use exact device names to match USAGE_DEVICES
		['Wasmachine (W)'] = { history = true, maxMinutes = 6 },
		['Slaapkamer Paul Schakelaar (W)'] = { history = true, maxMinutes = 10 },
		['Dimmer WC 1ste (W)'] = { history = true, maxMinutes = 10 },
		['Dimmer WC BG (W)'] = { history = true, maxMinutes = 10 },
		['Espressomachine (W)'] = { history = true, maxMinutes = 10 }
		if (USAGE_DEVICES[device.name] ~= nil) then
			-- we have a usage sensor here
			local switch = domoticz.devices(USAGE_DEVICES[device.name])
			local history = domoticz.data[device.name]
			history.add(device)
			if (switch.active and history.avg() == 0) then
			 	switch.switchOff()
			-- device is a switch
			if (device.active) then
				domoticz.notify(
					"ACTIVATE",
					domoticz.PRIORITY_EMERGENCY,
					domoticz.SOUND_SIREN
				domoticz.notify(
					"DEACTIVATED",
Disclaimer: this is untested code ;)
Side note: I'm wondering what the logic is for this script. If there's no energy usage for a device in the past 10 minutes isn't the device then also switched off? Or doesn't the switch report back to Domoticz its current state (like a Kaku switch)?
wizzard72
Post by wizzard72 » Friday 08 December 2017 11:05
Thanks for the simplified version. I'm going to analyse your code.
The purpose of the script is to disable devices that don't use any energy. For example: when my washing machine is finished and it uses 0 watt for 6 minutes, the the device is turned off and I get a message when ready. So I can never forget to hang my clothes to dry. I can't assume that one 0 watt means that the washing machine is finished. Sometimes the machine doesn't do anything, the zwave device measure 0 watt, but its not finished yet. Thats why I want a few minutes 0 watt. Then I know for sure its finished.
dannybloe
Post by dannybloe » Friday 08 December 2017 11:13
Interesting. I can do the same for my washing machine.
wizzard72
Post by wizzard72 » Friday 08 December 2017 13:11
dannybloe wrote:Interesting. I can do the same for my washing machine.
Glad I could help :-)
