Python plugin: Presence detection from wireless router
mvzut
Target OS: Raspberry Pi
Post by mvzut » Friday 12 October 2018 8:22
hjzwiers wrote:With Asus AImesh putting in both IP addresses does not work, still only sees the main router.
=arp fails, =brctl works
Just giving the info, I'll stick to brctl thnx
Is it easy/possible to temporarily switch off this AImesh feature? I suspect this is causing your problem.
On my system I have two routers (Asus and Linksys) just using the same SSID (but another channel), so no AImesh or anything. The plugin perfectly finds the correct HW methods on both routers, I don't need to force anything.
Raspberry Pi 3 - RFXtrx433 - Aeon Z-Stick gen5 - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - Xiaomi Gateway - Sonos - IP cameras - Wall mounted tablet + Imperihome - MANY switches/sensors
vamp
Re: Python plugin: Presence detection from wireless router
Post by vamp » Friday 12 October 2018 12:53
Hello there,
i would like to use this plugin to Vyos Router.
it show arp table to "show arp" command
If i try to add it to pre configured command i get this:
2018-10-12 12:51:05.898 Error: (teszt) Unsupported command (pre)configured for 192.168.31.1: show
2018-10-12 12:52:47.549 Error: (teszt) Failed 3 times to get capabilities for 192.168.31.1. Retry interval automatically reduced for this router
How to use your plugin it this router?
mikeoo
Post by mikeoo » Friday 12 October 2018 15:01
Hello there,
It is better when you give the info you use in the plug-in.
Is SSH working to your router?
Try to use it like
Wifi router IP Address: <ip router>:<port number>=arp
Different SSH port
example: 192.168.31.1:8325=arp
Default SSH port
example: 192.168.31.1=arp
You only need to add the port number when you use a different port number for SSH to the router.
When it is not working make a screenshot of the plugin settings en mask the username and password ;)
vamp
Post by vamp » Friday 12 October 2018 15:19
I found a other way :)
My Vyos VM run in a host (proxmox, Debian based) so i SSH to Proxmox and check brtcl. It working, but need some changes in python script.
I replace this line
 generic['brctl']=";brctl showmacs br0 | grep '..:..:..:..:..:..' | awk '{print $ 2}'"
to:
generic['brctl']=";brctl showmacs vmbr0 | grep '..:..:..:..:..:..' | awk '{print $ 2}'"
It need, because Proxmox rename the normal bridge interface.
vmbr0 is the "LAN" virtual switch on Proxmox.
AurelioF
Post by AurelioF » Monday 15 October 2018 10:26
mikeoo wrote:
Friday 12 October 2018 7:20
AurelioF wrote:
Thursday 11 October 2018 15:10
I confirm that it works with Unifi AP Pro :D
Thanks for sharing
Do you use ARP with the Unifi. I use also Unifi and interesting how you use it.
My installation has two unifi devices, with a single ssid but two IP addresses.
the plugin is working on raspberry. I'm only using this plugin, I do not perform other ARP queries.
I have to say that sometimes I experience repeated reconnections on an iphone for no apparent reason, I am still investigating.
mikeoo
Post by mikeoo » Monday 15 October 2018 10:38
Thanks for sharing
I have an Edgerouter X and 3 Unifi AP but i can only use the Edgerouter for scanning the ip and app. Can you scan the AP directly for an ip ?
For 95% the plugin is working great. But sometimes a phone (android) is not at home but system still think it is, even after a few hours.
Reconnection i have also sometimes. Some day it is working great an then suddenly it disconnects for a few minutes and the comes back again.
Would Be nice if there was a better option then ARP with Unifi so we could kill this sort of problems.
AurelioF
Post by AurelioF » Monday 15 October 2018 12:16
I access the unifi by IP and ssh using the plugin, I guess your unifi team must allow access by ssh, my unifi is "unifi ap pro"
mikeoo
Post by mikeoo » Monday 15 October 2018 12:45
I have one UniFi AP-AC-LR and two UniFi AP-AC-Lite but as fas as i know iu can only be managed with Unify Controller or with the Android App but nut directly. I can SSH to the Edgerouter with putty but i need to sort out how to create SSH key for it. That part i have no experience in so but difficult for the moment. And don't know if that part gowning to work and if it fix the problem.
So if you one a share some info for how you did it :mrgreen: But maby the Pro works different.
AurelioF
Post by AurelioF » Monday 15 October 2018 13:18
unifi ap pro has native SSH access, it is only necessary to configure user and password, it seems that unifi AP-AC-Lite and AP-AC-LR do not have ssh access, I did not know this difference, this can be a problem for your solution.
I do not know how to manage Edgerouter, if possible create a plain text key in your Edgerouter, using certificates is safer, but it is much more difficult.
if you can use a plain text password, make sure you have installed sshpass (sudo apt-get install sshpass). in Domoticz
mikeoo
Post by mikeoo » Monday 15 October 2018 14:27
tnx that is different indeed. For now i am working with just the password and sshpass indeed and that is working but with sometimes a problem. But wil search for hopefully other option witch works better in the future.
jackjhon
Post by jackjhon » Tuesday 16 October 2018 13:03
How do we use asp plugin to Optus router?
Optus Technical Support Number
jackjhon
Post by jackjhon » Tuesday 16 October 2018 13:37
how do we use asp plugging to my republic broadband?
Myrepublic internet support
EscApe
Domoticz version: v3+beta
Post by EscApe » Tuesday 16 October 2018 17:22
@jackjhon
Ik you can supply a router make and model, then maybe someone can help you.
In general: if the router supports ssh just follow the instructions on GitHub. If it doesn't the plugin will not work with your router.
Users browsing this forum: No registered users and 3 guests
