Python plugin: Presence detection from wireless router
sapnho
Target OS: Raspberry Pi
Domoticz version: V4.9962
Re: Python plugin: Presence detection from wireless router
Post by sapnho » Sunday 09 September 2018 18:15
Thanks escApe, your release frequency is most impressive! ;)
Seems to work fine, no errors so far in the (now very exhaustive) log.
wizzard72
Post by wizzard72 » Sunday 09 September 2018 21:26
EscApe wrote:
Friday 07 September 2018 17:11
@wizzard72
The override button could be disabled in the plugin settings. What is your current 'override mode'?
It was "Do not allow override". Changed it. Thanks for pointing out.
wizzard72
Post by wizzard72 » Sunday 09 September 2018 21:39
EscApe wrote:
Sunday 09 September 2018 16:36
Now new features or fixes, but i have tweaked the logging a bit
**version 0.6.6**
- Improved: Debug logging for the ssh session now hides the ssh password.
- Improved: Presence changes are now logged (without needing debug mode), so you can see something is going on.
- Improved: Some more log tweaking (removed some redundancies and changed log levels for some messages)
Looking good. No more errors in the log. Keep up the good work!
sapnho
Post by sapnho » Monday 10 September 2018 21:15
What is actually the best way to transfer the iDetect settings to another Domoticz installation? Or is it saved in the Domoticz settings when you do a backup?
EscApe
Domoticz version: v3+beta
Post by EscApe » Monday 10 September 2018 22:20
All settings are stored in the database and should be included in your Domoticz backup. Just put the plugin.py and .zip files on the new installation.
sapnho
Post by sapnho » Monday 10 September 2018 22:25
Ok, perfect, thanks.
I am having trouble with the restore function in Domoticz (4.9999) at the moment but I guess that will be resolved soon.
sapnho
Post by sapnho » Wednesday 12 September 2018 8:31
Two new error message at start up after a soft reboot. No problem otherwise.
2018-09-12 08:26:40.238 Error: iDetect iPhones hardware (5) thread seems to have ended unexpectedly
2018-09-12 08:26:40.238 Error: iDetect RPi Fnatenrahmen hardware (6) thread seems to have ended unexpectedly
EscApe
Post by EscApe » Wednesday 12 September 2018 20:29
@saphno
Can't really tell something by just these messages, but my guess is that either domoticz or its python plugin framework got stuck/overloaded. That could be explained if you poll many routers and your network, router of domoticz slows down. If timeouts start occurring every poll will take max 2 seconds * number of routers. So 6 seconds with your three routers. If you poll every 10 seconds and maybe have some other python plugins installed things might get ugly. It should recover though, and hopefully not happen frequently.
All this is pure speculation on my part, but for now i see no reason to be alarmed.
sapnho
Post by sapnho » Wednesday 12 September 2018 21:23
Ok, good, thanks!
EscApe
Post by EscApe » Friday 14 September 2018 20:21
version 0.7.0 is available on GitHub - some major changes under the hood
Added: option to preconfigure the router commands (skipping auto detection) and a way to easily find out what to ‘preconfigure’. See github for instructions.
Fixed: Router capability detection (compatibility with some firmwares that limit the ssh argument size).
Important: Please TEST the new version (watch te log) and leave a message on the forum if it fails where the previous version succeeded. There are changes in this version that i simply cannot test, because i don’t own every brand and model of router.
This release introduces a completely rewritten function to detect the router capabilities. Why fix something that doesn’t seem broken? Well, it turns out the original router (shell) part of the script was to long for some routers. In that case the ssh session would fail because the script was longer than the maximum length allowed for an ssh argument. So i used a shorter notation and broke it up into de detection of available commands and the detection of the interfaces to query. The new approach is also a bit easier to maintain (add or modify chipset support). Using separate sessions for capabilities detection introduces some additional overhead, but only when the plugin/domoticz starts. It has zero impact on the poll times, since it generates the same poll commands as before.
An indication of the changed startup performance: The old detection function would take one session, which took 0.35 seconds on my Asus AC86. It will now take 2 sessions = 0.7 seconds. A router with two chipsets, like the AC87 will take 1+2 sessions = around 1 seconds. A mesh setup with three AC87’s will take 3 + 3x2 sessions, which translates into a little over 3 seconds. With the old function that same mesh setup would take around one second. If timeouts occur the wait time will quickly add up, so i lowered them to two seconds (per ssh session). That should not be a problem if your network, router and Domoticz host are in good shape, but please let me know if it proofs a little to close to the edge.
Thanks to mvzut for testing and for investigating why the capabilities detection was failing on his router!
QSKONE
Post by QSKONE » Sunday 23 September 2018 0:05
Hi , it is my router Xiaomi Router 3 poor device for this?
Error: (iDetect) Failed 30 times to get capabilities for 192.168.31.1. Retry interval automatically reduced for this router.
mvzut
Post by mvzut » Sunday 23 September 2018 2:23
Is ssh enabled on your router and do you know the ssh login name and password?
It's difficult to tell what the problem is from this log message only, if you turn on debugging we can probably give more relevant feedback.
Raspberry Pi 2B - RFXtrx433 - Aeon Z-Stick gen5 - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - Sonos Connect & PLAY:1 - Kodi - Wall mounted tablet + Imperihome - MANY switches/sensors
QSKONE
Post by QSKONE » Sunday 23 September 2018 10:59
Thanks debugging helps me. Plugin works but phones are not connected.
Full log
(iDetect) Started.
(iDetect) Entering work loop.
(iDetect) Initialized version 0.7.0, author 'ESCape'
(iDetect) Using generic brctl command on router 192.168.31.1. Will respond slower and on some routers a little less reliable to absence
(iDetect) Awaiting confirmation on absence of 2 devices
(iDetect) Connection restored for 192.168.31.1
(iDetect) SSH command on 192.168.31.1 took 776 milliseconds.
(iDetect) Found these devices connected:[]
(iDetect) Considered absent: Phone2
(iDetect) Considered absent: Phone1
(iDetect) Polling presense data from 192.168.31.1
(iDetect) Using password instead of ssh public key authentication for 192.168.31.1 (less secure!)
(iDetect) Fetching data from 192.168.31.1 using: sshpass -p **secret** ssh -o StrictHostKeyChecking=no -o ConnectTimeout=2 root@192.168.31.1 export PATH=/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:$PATH;brctl showmacs br0 | grep '..:..:..:..:..:..' | awk '{print $ 2}';exit
(iDetect) ssh command on 192.168.31.1 returned:b''
(iDetect) SSH command on 192.168.31.1 took 780 milliseconds.
EscApe
Post by EscApe » Sunday 23 September 2018 19:34
I have no experience with the Xiaomi router. It seems to be based on a Ralink MT7620A chipset. Is anyone else on this forum using the plugin with a chipset like that? does it return anything on the brctl command?
Seems weird that it isn't returning anything on the xiaomi. Brctl should even return wired devices.
@QSKONE
Do you know your way around the command line? Could you check if the following commands return anything if you run them on the router yourself?
brctl showmacs br0
(try different names if br0 is not the right name for the xiaomi. You can find the names using: brctl show)
arp -a
QSKONE
Post by QSKONE » Sunday 23 September 2018 20:32
Brctl cannot work
root@XiaoQiang:~# brctl showmacs br0
brctl: invalid argument 'showmacs' to 'brctl'
root@XiaoQiang:~#  brcl show
-ash: brcl: not found
Comand arp -a shows my connected devices with ip and mac adress.
? (192.168.31.11) at mac adress [ether]  on br-lan
EscApe
Post by EscApe » Sunday 23 September 2018 20:48
@QSKONE
you could try configuring the router in the plugin settings as: 192.168.31.1=arp
This will force the plugin to use arp on the router. I do not see any Mac addresses in the output you shared. If that was the real output, then that is not going to work either.
Brctl is behaving differtly on your router, so that’s not an option. (The command is available, but you left out the letter ‘t’ on you second attempt)
