check domoticz with monit and restart when check fails Topic is solved
Theedoek
Re: check domoticz with monit and restart when check fails
Post by Theedoek » Saturday 11 August 2018 14:32
That worked thanks. Finally solved it by checking the access rights. My monit control file now looks like this:
## Monit control file
SET DAEMON 300    # check services at 2-minute intervals
WITH START DELAY 240    # optional: delay the first check by 4-minutes (by default Monit check immediately after Monit start)
SET LOGFILE /var/ramdrive/monit.log
SET IDFILE /var/lib/monit/id
SET STATEFILE /var/lib/monit/state
SET EVENTQUEUE
    BASEDIR /var/lib/monit/events
    SLOTS 100
SET MAILSERVER
    <mailserver address> port 465
    USERNAME "<username>" PASSWORD "<password>"
SET HTTPD PORT 2812
ALLOW localhost
ALLOW 10.0.0.0/24       # allow local network
ALLOW admin:monit      # require user 'admin' with password 'monit'
ALLOW @monit              # allow users of group 'monit' to connect read/write
allow @users readonly     # allow users of group 'users' to connect readonly
CHECK PROCESS Domoticz WITH PIDFILE /var/run/domoticz.pid
START PROGRAM = "/etc/init.d/domoticz.sh start"
STOP PROGRAM = "/etc/init.d/domoticz.sh stop"
IF FAILED
    HOST 127.0.0.1 PORT 8080 PROTOCOL HTTP
    AND REQUEST "/json.htm?type=command&param=getversion"
    AND CONTENT = '"status" : "OK"'
    FOR 3 cycles
    THEN RESTART
IF 5 RESTARTS WITHIN 5 CYCLES THEN EXEC "/sbin/reboot"
Next step is to figure out why monit reboots my Raspberry Pi every exact 3 hours :S
Users browsing this forum: Gianni and 5 guests
