Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Target OS: Raspberry Pi
Post by Madgeni » Wednesday 07 November 2018 18:52
Yes! Glad it's working
Native Alexa skill and Google app - register at https://www.controlicz.com
Madgeni
Post by Madgeni » Thursday 08 November 2018 11:20
Milenko wrote:
Tuesday 06 November 2018 15:07
It does work for me on my other devices. Just not on the lenovo smart display.
What version of the google home app does the google home hub run? the lenovo has 3.63.43.
I'll try again when I get home and will let you know.
The versioning is different (1.3.x), so no help there.
If you create a dummy temp sensor in domoticz and add that, does it crash also?
Milenko
Post by Milenko » Thursday 08 November 2018 20:52
I tried what you suggested. Made a dummy button, just a temperature sensor. It has the same issue.
Madgeni
Post by Madgeni » Saturday 10 November 2018 20:40
I'm coming round to the idea that there is an issue with timing between the calls Google makes on Controlicz.
I can kind of reproduce this (the Google hub doesn't crash, but shows an error saying the device isn't connected).
Before any request gets executed, Google insists on querying the device. *Then* it make the request to Controlicz to execute any temp change.
There's a timing issue in play here, which I think is causing the issue (certainly on the Hub) - will investigate if I can code round it.
Milenko
Post by Milenko » Sunday 11 November 2018 12:49
Thanks for trying. Let me know if you need me to test anything.
Madgeni
Post by Madgeni » Sunday 11 November 2018 13:22
Will do - i've asked Google also. I genuinely think it's a bug with the Home display sw - it's not waiting for the execute response, and the delay isn't that long - potentially 1-2 seconds from initial testing. Be aware this is based on my Hub, and may not be the Lenovo issue (but i think it is)
