Alexa, Google Home and Siri
Madgeni
Target OS: Raspberry Pi
Post by Madgeni » Friday 12 October 2018 15:19
Oh no - can you mail me from your Controlicz profile and i'll take a look right now
Native Alexa skill and Google app - register at https://www.controlicz.com
heggink
Domoticz version: V4.9999
Post by heggink » Saturday 13 October 2018 11:37
Right, so finally Dutch language on my home mini through some form of magical apparition. Nothing really worked so removed and reattached. What's weird is that in can ask Google to turn all lights on and off but not individual rooms and not individual lights. It recognises no lights by name. Maybe because I renamed all of them in the home app from English to Dutch. Will retry with the controlicz name in the description field. Bizarre. All worked fine in English .
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
Madgeni
Post by Madgeni » Saturday 13 October 2018 20:10
Several people seem to have issues so far with Dutch - scenes not being discovered is another. I'm hoping it's teething troubles, but have raised with Google Product owner
heggink
Post by heggink » Saturday 13 October 2018 20:14
Madgeni wrote:Several people seem to have issues so far with Dutch - scenes not being discovered is another. I'm hoping it's teething troubles, but have raised with Google Product owner
I noticed the scenes/groups thing. Bizarre that a language has any influence over how devices are treated...
Pi3, latest beta
Harmony hub, Nest
Madgeni
Post by Madgeni » Saturday 13 October 2018 20:15
It's discovering and returning them to Google, Google is just..ignoring them :(
heggink
Post by heggink » Saturday 13 October 2018 20:17
Probably because they are too busy meddling with stuff they should really ignore
Pi3, latest beta
Harmony hub, Nest
wardc
Post by wardc » Sunday 14 October 2018 15:56
gijsje wrote:
Thursday 11 October 2018 23:42
Now i can also see that all temp sensors are shown as a "thermostat", does google not support separate temp sensors?
And i can not yet control the thermostat from the new app it shows the ambient temp but this is actually the set point.
I have the same problem. Also noticed that RGB(W) are not recognized as such. They show as regular dimmable lights.
It's very annoying that scenes aren't showing in the app as I do almost everything in domoticz using scenes. What is strange is that they don't show in the home apps, but through the assistant app I was able to add the scenes to rooms. Haven't seen them anywhere since. I used this link to link the controlicz app to the Google assistant:https://assistant.google.com/services/a ... 8ba2?hl=nl
By first linking and then changing the settings (instellen) I was able to view the scenes. So Google probably knows about them but is ignoring them on purpose.
Madgeni
Post by Madgeni » Sunday 14 October 2018 18:19
So a few points there:
You're right - the Google Assistant doesn't allow RGBW controls yet - which is annoying, but this UI functionality is new, so hope it will improve soon
Sensors aren't available yet - they're coming soon, i have implemented them under the covers, but waiting for Google to release them. Until that point, I have to treat sensors as thermostats in order to query them (which is also annoying).
Scenes - i'm hoping this is just a short term issue as Dutch language has only just been implemented
wardc
Post by wardc » Sunday 14 October 2018 19:25
Found the Google documentation about RGB lights.
https://developers.google.com/actions/s ... ides/light
Apperantly the device type 'Light' has the traits 'brightness', 'colorspectrum' and 'colortemperature'. However no saturation. So RGB is supported RGBW not (fully). Maybe it is possible to use RGB value FFFFFF as white or something like that? I believe the Google Assistant also sends the detected color as string back in the request.
Madgeni
Post by Madgeni » Sunday 14 October 2018 19:27
You can set warm/cold white - is that what you mean?
wardc
Post by wardc » Sunday 14 October 2018 19:57
No with saturation I mean the mix between white and RGB(colorspectrum).
With colortemperature you can set the themperature of the color. For white that would be the range between cw/ww. Haven't seen it been used for other colors yet in consumer lighting.
Madgeni
Post by Madgeni » Sunday 14 October 2018 19:59
Gotcha
Maes
Post by Maes » Monday 15 October 2018 14:11
Integration with dutch Home Assistant seems to work perfectly if you use the buttons in the new Home app.
However, any and all voice commands that are different from "set thermostat to X" and "turn off/on lamps" simply result in google's ability to play a song on youtube that somehow relates to the command you gave.
Apparently there's a song called "In het Licht" from "Sela", quite religious I should tell you. Now Google is trying to force religion into my home.
So.. I'm guessing the dutch voice commands just suck donkey balls and we gotta wait more.
Also, no support for those "Shortcuts" in dutch language.
jpvaneijk
Domoticz version: V3.9564
Post by jpvaneijk » Tuesday 16 October 2018 22:57
:D :lol: :D :lol:
Same here. Frustrating Google responses like "Ik begrijp het niet" "Ik kan het niet" but it seems like Google simply doesn't want to.
24/10 is the new magical date then guys?
heggink
Post by heggink » Wednesday 17 October 2018 11:08
Not sure what triggered the change but giggle's assistant was completely ignoring me this morning (indicating she could not switch anything) so I disconnected controlicz, removed all non switchable devices from my room plans (pirs, contacts), reconnected controlicz and tadaa IT WORKS! I can switch devices in rooms again and it all works in Dutch. Yay. .
Pi3, latest beta
Harmony hub, Nest
landmer
Domoticz version: 3.5877
Post by landmer » Wednesday 17 October 2018 12:35
Are you able to connect controlicz to your google assistant while the phone is set to dutch? I'm on swedish and if i use swedish as language on the phone and search for "actions" in google assistant to add/link controlicz nothing shows up.
So to connect/link controlicz my phone must be on english.. How do you connect/link controlicz to your phone while on dutch?
Best regards.
heggink
Post by heggink » Wednesday 17 October 2018 13:05
Google assistant supports Dutch language these days so I can just select Dutch language. Is Swedish supported?
Pi3, latest beta
Harmony hub, Nest
jpvaneijk
Post by jpvaneijk » Wednesday 17 October 2018 14:35
Okay Madgeni en others. Good news for users on new released languages!
I unlinked Controlicz on my Google Home app, reconnected and got all devices back in rooms again.
All devices are working now (for me in Dutch) on my Google Home Mini. Great! I'm using (dutch) device friendly names.
So far so good Madgeni, but still testing! :ugeek:
Madgeni
Post by Madgeni » Wednesday 17 October 2018 14:38
Yes! Pleased it's improving
Maes
Post by Maes » Wednesday 17 October 2018 18:19
Seems to work better now.
I've deleted a device that was added to g home. Created a new device with the same name (diff idx ofc). Now every time I ask Google to sync my devices it says there was an error syncing devices with controlicz. Linking/unlinking doesn't help.
The old device also stays in g home. I know this because turning it on does nothing.
Users browsing this forum: Damsee, Google [Bot] and 1 guest
