Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Target OS: Raspberry Pi
Post by Madgeni » Wednesday 13 June 2018 15:34
can you check your profile again also?
Like Controlicz? Want to help keep the lights on?
https://paypal.me/madgeni
https://www.patreon.com/madgeni
Native Alexa skill and Google app - register at https://www.controlicz.com
jpvaneijk
Domoticz version: V3.9564
Post by jpvaneijk » Wednesday 13 June 2018 16:17
Now I'm really flabbergasted...
Looked in my google home and my devices were no longer in a room. Put them in a room again of course.
Synced devices again en checked Controlicz. All of a sudden al the hub's activities are marked as Switch (and no longer as Light)
Checked out the configuration of course. 'Hey Google: turn on all lights' and only the lights responded! Great!
'Turn the TV on worked great to. Then 'Turn off all lights' en only the lights are of and the TV was stil working.
Did you do anything MedGeni or are there some gnomes working in my house I don't know about! :roll:
Thanx a million even though I don't know what happend? Can you explain?
Two questions remain:
In the devices tab: In room Mediacentre are all the switches for the Harmony Hub. In Room Lichten are no Milights and it's empty. Not even the dummy I've created. How can that be?
I'm still not able to change an icon or to upload any. Got a fix for that?
Thanx!
Madgeni
Post by Madgeni » Wednesday 13 June 2018 17:29
I fixed the Harmony for you :)
Re: Milights - these should be working now also - you'll need to "sync my devices" in Google
Charley
Domoticz version: V3.9030
Post by Charley » Thursday 14 June 2018 16:18
Since today the connection to controlicz is out again. (i did an unlink and link again)
The error message is:Couldn't update the setting. Check your connection.
With trace it seems that the server is hard to reach (From the Netherlands with the best provider XS4ALL)
It might be problems at AWS.
Madgeni
Post by Madgeni » Thursday 14 June 2018 18:27
Hey :)
Controlicz is definitely up - it was down for very short periods whilst I deployed some code changes. It's possible that coincided with your test (but downtime is <10 seconds per deployment).
if it's any consolation, I can't ping or traceroute to it either - frankly i'm happy about that.
Madgeni
Post by Madgeni » Thursday 14 June 2018 21:36
This was being caused by a specific device behaviour in Domoticz, so not "fixed" but isolated. Will work on it over the weekend (once we've celebrated our wedding anniversary!)
jpvaneijk
Post by jpvaneijk » Thursday 14 June 2018 21:50
Congrats Madgeni. Sure you've got the priority's straight? :D :lol:
EdwinK
Post by EdwinK » Thursday 14 June 2018 22:28
Looking into this now and then but still not sure about step 1
The https port is defined in /etc/init.d/domoticz.sh
DAEMON_ARGS="$DAEMON_ARGS -www 8080 -loglevel=normal"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"
So, is this something that needs added to the domoticz.sh? Isn't it overwritten bij a new update of Domoticz?
-sslwww port (for example, -sslwww 443). https runs by default. Set port to 0 to ensure https socket won't be open.
Or should I set port to '0'?
I'm a little hesitant to change this now, without being sure of it.
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
Madgeni
Post by Madgeni » Friday 15 June 2018 16:12
Hi - afaik, Domoticz is running on 443, so no reconfig needed. I would recommend a non-standard port for ssl, then it's just a port forwarding on your router.
deennoo
Post by deennoo » Sunday 17 June 2018 16:46
Hey :)
On my side ( and 4 friends of mine who got alexa/google home & domoticz) controlicz can't connect to domoticz.
We don't use regulare 433 port but routed on to our domoticz.
we all recieved the same error :
Controlicz is unable to connect. Please check your config.
I test all config for my and my friend and for every i can connect and drive domoticz using a mobile connection using Chrome.
Chrome give a warning message saying that this HTTPS website can be dangerous, and i have to clikc on "continu anyway".
Rfxtrxe / RFLink / Milight / Yeelight / ESP8266 / MQTT / BLE
http://domo-attitude.fr
Madgeni
Post by Madgeni » Sunday 17 June 2018 19:30
Hi -
Can you check the username/password - it's returning "unauthorized"
getdown
Post by getdown » Sunday 17 June 2018 20:20
Hello Madgeni,
I use controlicz since the begin and it gives me lot of joy ! I've add some new devices today (2 mysensors relays) to switch 2 lights. I've add them to the plan in domoticz, sync my devices in google home. They aren't recongnized as lights but as switchs so I can't controle them with the voice command "switch on the lights of the living room".
They are configured as lights in domoticz so I don't understand why controlicz don't recognize them as lights to.
Maybe I have made a mistake ?
Thank's a lot for the very good work and hope you have the solution of my issue !
Madgeni
Post by Madgeni » Monday 18 June 2018 9:11
Hi there - can you mail me from your Controlicz profile, and i'll take a look
Madgeni
Post by Madgeni » Monday 18 June 2018 15:47
Hi -
hi deenoo - did you fix this?
getdown
Post by getdown » Monday 18 June 2018 19:46
It's done !
Madgeni
Post by Madgeni » Monday 18 June 2018 23:07
it's fixed :)
lec668
Post by lec668 » Tuesday 19 June 2018 23:37
Hi Magdeni,
I was using Controlicz a few months ago, then changed of ISP.
I reconfigured my installation, nated the ssl port, I'm so able to access domoticz from outside with the credentials from my controlicz profile,
but the connect test fails from Controlicz.
I double checked user/password, entered them again, but it still fails.
Would it be possible to have a look ? And you can include me in the beta if still needed.
Thanks a lot
My Controlicz id : 5aaed24b655b955935620b35
miremi
Post by miremi » Wednesday 20 June 2018 19:46
i have little problem from last week controlicz is not working anymore. I see all devices in controlicz profile but still get the message "unable to connect"
Nothing is changed in my setup. When i push "test connection" then i see incoming connection from controlicz on my domoticz pc but again i get error from controlicz and also from google.
Any idea?
My ID: 5a37b10b72cffb747b5957be
Nevermind i found solution: remove controlicz from google account and add it again.
Ubuntu 16.04.3, Core i5 8GB RAM 120GB SSD, RFlink, ESPeasy, Z-Stick Gen5, 8 FIbaro, 17 Neo Coolcam
jpvaneijk
Post by jpvaneijk » Wednesday 20 June 2018 23:15
Also having problems now connecting to Controlicz. Something going on Madgeni?
Did a unlink/relink ofcourse. Had to put the devices in the rooms again and giving permissions. That gave troubles.
Website reported:
and:
Error: Failed to lookup view "error" in views directory "/opt/bitnami/apps/Controlicz/views"
    at EventEmitter.render (/opt/bitnami/apps/Controlicz/node_modules/express/lib/application.js:580:17)
    at ServerResponse.render (/opt/bitnami/apps/Controlicz/node_modules/express/lib/response.js:1008:7)
    at /opt/bitnami/apps/Controlicz/app.js:98:13
    at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:71:5)
    at trim_prefix (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:315:13)
    at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:284:7
    at Function.process_params (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:335:12)
    at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:275:10)
    at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:635:15
    at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:260:14)
    at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:127:14)
    at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:67:12)
    at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:135:13)
    at loaded (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:36:25)
Domotocz on port 443 is working ok. Devices are in rooms, etc.
Reset for Google Home app and my Google Home Mini gave no results either.
Can you advice please?
Thanx!
Madgeni
Post by Madgeni » Thursday 21 June 2018 14:42
Hi all, so the Test button is broken, I'm reworking the backend, so need it there, but it will return a failure no matter what.
If you see Devices in your profile, your connection is good.
