Winddelen error connecting
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Derik
Target OS: Raspberry Pi
Re: Winddelen error connecting
Post by Derik » Sunday 29 July 2018 11:26
antwan wrote:
Saturday 28 July 2018 19:02
Contact windcentrale...
Why?
The api they use is working on my app..
So i think it is in Domoticz:
https://github.com/domoticz/domoticz/is ... -408616096
moi427
Domoticz version: 3.8975
Post by moi427 » Monday 30 July 2018 17:21
Same problem here after updating Domoticz.
2018-07-30 17:20:23.544 Error: Winddelen: Error connecting to: http://backend.windcentrale.nl/windcent ... ctie?id=31
And here also the API is working OK on my PC.
Nibe F1255-6 PC heatpump, SolarEdge SE7K inverter + 16 x Solarwatt panels (in-roof 275Wp) + optimizers, EtaSunPro vacuum collector (40 tubes)
moi427
Post by moi427 » Monday 30 July 2018 18:20
Installed the Python plugin as made and mentioned by Xorfor, that works. Thx for remark Xorfor :lol:
gizmocuz
Post by gizmocuz » Sunday 12 August 2018 12:22
Probably the API has changed. Using the python plugin might work, but gives you a bunch of new sensors, not so good for your old logs
So the best is that someone looks at the current c++ implementation, adopt the new API, and also add the new additional fields
Derik
Post by Derik » Sunday 12 August 2018 12:25
Strange that the api is working with the plugin..
Only when i try to use a plugin my pi is crashing..
gizmocuz
Post by gizmocuz » Sunday 12 August 2018 12:53
Why strange ? You did noticed the different url paths ?
Derik
Post by Derik » Sunday 12 August 2018 12:56
Sorry yes is see..
Only change the path is not enough i think....
gizmocuz
Post by gizmocuz » Sunday 12 August 2018 13:04
Nope... as the response is different... working out what fields to use
gizmocuz
Post by gizmocuz » Sunday 12 August 2018 13:09
@Derik, send you a PM
mschut
Domoticz version: V3.5613
Post by mschut » Sunday 12 August 2018 13:21
Is there a way to get it working again?
Verstuurd vanaf mijn SM-G930F met Tapatalk
gizmocuz
Post by gizmocuz » Sunday 12 August 2018 13:27
@mschut, maybe... hence the PM to Derik
mschut
Post by mschut » Sunday 12 August 2018 13:33
Very much interested. Available to test if needed
gizmocuz
Post by gizmocuz » Monday 13 August 2018 16:49
I think i implemented the new api/calling method in the latest beta.
Don't forget to enable 'accept new devices' in the settings as you get some other sensors as well now
Users browsing this forum: WillemK and 4 guests
