Problem with multiple 1-wire busses.
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
bopitje
Target OS: Raspberry Pi
Post by bopitje » Wednesday 27 September 2017 13:13
Hardware: Raspberry Pi 3
OS: Linux version 4.9.35-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 SMP Fri Jun 30 14:47:43 BST 2017
Domoticz branch: stable
Version number: 3.8153
Build hash: 494fff7
Problem: 1-Wire errors with multi busses
Steps already tried: Reboot, deactivate/activate 1-Wire different scrips.
Reproduce: permanent
Recently, I've connected 2 1-wire busses to the raspberry pi, I noticed that when I connected more than 8 divices (DS18S20) on 1-wire network, wrong values were displayed.
sudo leafpad /boot/config.txt
dtoverlay=w1-gpio
dtparam=gpiopin=4
dtoverlay=w1-gpio
dtparam=gpiopin=17
With the command below, all temperature meters are found and read well.
pi@raspberrypi:/sys/bus/w1/devices $ ls
28-0316b4e27fff 28-0416c13bbdff 28-0416c22449ff w1_bus_master1
28-0316b53e49ff 28-0416c2095eff 28-0516b57ee1ff w1_bus_master2
28-0416c10669ff 28-0416c21f15ff 28-0516c01120ff
But unfortunately not with domoticz, which reads only master1 and not both (Master1 & Master2).
I have already tried several tutorials, but without success. Does anyone have an idea how domoticz can show both w1_bus_masters?
bopitje
Re: Problem with multiple 1-wire busses.
Post by bopitje » Wednesday 04 October 2017 21:37
Does anyone have an idea?
With the terminal I can see/ read all the sensors. Unfortunately not with domoticz.
Domoticz only reads master1 and not both (Master1 & Master2).
fantom
Post by fantom » Sunday 15 October 2017 18:20
I see, that 1wire searching devices only in w1:
https://github.com/domoticz/domoticz/bl ... l.cpp#L189
Fantom
bopitje
Post by bopitje » Saturday 21 October 2017 20:06
Does anyone have an idea how to get this together?
zazoo
Post by zazoo » Saturday 15 September 2018 13:39
I see your post is 1 year old, so did you find a solution ?
I have exactly the same issue with my Raspberry (PI 2) running Domoticz: All sensors of both buses are identify at linux prompt. I can read all the temperatures using the "find" instruction :
pi@raspberrypi:/sys/bus/w1/devices $ find /sys/bus/w1/devices/ -name "28-*" -exec cat {}/w1_slave \; | grep "t=" | awk -F "t=" '{print $2/1000}'
21.375
19.625
21.25
19.812
21.812
21.062
24.812
But, it is impossible to have the sensors of both buses under Domoticz.
Only the first declared bus (in /boot/config.txt file) is used by the application software.
Thank a lot in advance if someone have a solution. I think it is very convenient to use multiple buses when number of sensors increase.
fantom
Post by fantom » Sunday 16 September 2018 11:05
1wire by kernel uses only w1
https://github.com/domoticz/domoticz/bl ... Kernel.cpp
You must rewrite this code, if You want use more buses.
Fantom
I may try change this, but I don't use kernel.
pgit
Post by pgit » Sunday 21 October 2018 0:55
I have exactly the same problem.
And I can't change the wiring to connect my (2) sensors in series, since they are to far apart and lead in different directions.
It would be great if the feature for reading multiple 1-wire busses is implemented.
I'm sorry, I do not have the skills to write / change the code...
fantom
Post by fantom » Tuesday 23 October 2018 18:36
Please show me what is in w1_bus_master1 and w1_bus_master2
Fantom
Users browsing this forum: No registered users and 4 guests
