Python Plugin: Smart Virtual Thermostat
SzuR
Target OS: Raspberry Pi
Re: Python Plugin: Smart Virtual Thermostat
Post by SzuR » Monday 25 June 2018 7:48
Ok thanks so i have to try till it works. :-D
Are you using stable domoticz or beta?
Wysłane z mojego D6503 przy użyciu Tapatalka
Edit
So frozen domoticz was an issue with last domoticz update. Couple people have same issue and it is connected with mydomoticz allowed in settings...
pipiche
Post by pipiche » Thursday 05 July 2018 16:49
This is a pretty impressive plugin.
You mentioned that the plugin required 2 to 3 days to learn. What's happen in case of restart of domoticz or even the hosts system. Are we back to 2 to 3 days of learning ?
Logread
Post by Logread » Thursday 05 July 2018 17:00
The plugin saves the « learning » in a dedicated user variable that it creates. This survives a restart or a reboot (and is backed up as you make backups of domoticz). Only if you delete that user variable will learning be lost.
pipiche
Post by pipiche » Thursday 05 July 2018 18:20
Interesting, I'll have a look. I was not aware that a uservariable could be created .
jake
Post by jake » Friday 06 July 2018 22:31
You can't create it, but you can 'modify' it, if you know what you're dining. Worst case you simply delete the content and let the plugin recreate it.
