Python Plugin: Smart Virtual Thermostat
SzuR
Target OS: Raspberry Pi
Re: Python Plugin: Smart Virtual Thermostat
Post by SzuR » Monday 25 June 2018 7:48
Ok thanks so i have to try till it works. :-D
Are you using stable domoticz or beta?
Wysłane z mojego D6503 przy użyciu Tapatalka
Edit
So frozen domoticz was an issue with last domoticz update. Couple people have same issue and it is connected with mydomoticz allowed in settings...
pipiche
Post by pipiche » Thursday 05 July 2018 16:49
This is a pretty impressive plugin.
You mentioned that the plugin required 2 to 3 days to learn. What's happen in case of restart of domoticz or even the hosts system. Are we back to 2 to 3 days of learning ?
Logread
Post by Logread » Thursday 05 July 2018 17:00
The plugin saves the « learning » in a dedicated user variable that it creates. This survives a restart or a reboot (and is backed up as you make backups of domoticz). Only if you delete that user variable will learning be lost.
pipiche
Post by pipiche » Thursday 05 July 2018 18:20
Interesting, I'll have a look. I was not aware that a uservariable could be created .
jake
Post by jake » Friday 06 July 2018 22:31
You can't create it, but you can 'modify' it, if you know what you're dining. Worst case you simply delete the content and let the plugin recreate it.
HvdW
Post by HvdW » Tuesday 24 July 2018 11:48
Still having problems with Domoticz crashing.
Pity.
Just by reading about it it seems the easyest and best solution to create modulation on my 19 years old boiler.
Waiting for a version without bugs.
Anyway: Thanks for all efforts you have put and still put into it.
Great job @Logread!
PS
What is the most gracefull way of deleting Smart Virtual Thermostat from RPI.
I do it by deleting SVT directory and a restart.
I have the impression there is more to delete.
pacioc193
Post by pacioc193 » Thursday 30 August 2018 14:30
What about this error?
2018-08-30 14:29:07.288 Error: (Termostato) Error calling 'http://localhost:8080/json.htm?type=dev ... order=Name'
2018-08-30 14:29:07.288 Error: (Termostato) No Inside Temperature found... Switching Thermostat Off
2018-08-30 14:29:07.303 Error: (Termostato) Error calling 'http://localhost:8080/json.htm?type=dev ... order=Name'
2018-08-30 14:29:07.304 Error: (Termostato) 'onHeartbeat' failed 'KeyError'.
2018-08-30 14:29:07.304 Error: (Termostato) ----> Line 599 in /home/pi/domoticz/plugins/SVT/plugin.py, function onHeartbeat
2018-08-30 14:29:07.304 Error: (Termostato) ----> Line 352 in /home/pi/domoticz/plugins/SVT/plugin.py, function onHeartbeat
2018-08-30 14:29:07.304 Error: (Termostato) ----> Line 469 in /home/pi/domoticz/plugins/SVT/plugin.py, function switchHeat
I've set as internal sensor idx 9
attach a photo!
This is the webpage!
"ActTime" : 1535632419,
"AstrTwilightEnd" : "21:55",
"AstrTwilightStart" : "04:55",
"CivTwilightEnd" : "20:38",
"CivTwilightStart" : "06:12",
"DayLength" : "13:24",
"NautTwilightEnd" : "21:15",
"NautTwilightStart" : "05:35",
"ServerTime" : "2018-08-30 14:33:39",
"SunAtSouth" : "13:05",
"Sunrise" : "06:43",
"Sunset" : "20:07",
"app_version" : "4.9700",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"DimmerType" : "none",
"Favorite" : 0,
"HardwareID" : 3,
"HardwareName" : "GPIO",
"HardwareType" : "Raspberry's GPIO port",
"HardwareTypeVal" : 32,
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "0",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2018-08-29 21:55:13",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 0,
"Name" : "Relè",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Impuls",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Lighting 1",
"TypeImg" : "lightbulb",
"Unit" : 21,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "2"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 15,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"HardwareName" : "Termostato",
"HardwareType" : "Smart Virtual Thermostat",
"HardwareTypeVal" : 94,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"ID" : "00040001",
"Image" : "Heating",
"LastUpdate" : "2018-08-30 14:33:05",
"Level" : 0,
"LevelActions" : "fHw=",
"LevelInt" : 0,
"LevelNames" : "T2ZmfEF1dG98Rm9yY2Vk",
"LevelOffHidden" : false,
"MaxDimLevel" : 100,
"Name" : "OFF / Auto / Force",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SelectorStyle" : 0,
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Selector Switch",
"SwitchType" : "Selector",
"SwitchTypeVal" : 18,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "Light",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "3"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 15,
"Data" : "On",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"ID" : "00040002",
"LastUpdate" : "2018-08-30 07:21:04",
"Level" : 10,
"LevelInt" : 10,
"LevelNames" : "T2ZmfE5vcm1hbHxFY29ub215",
"LevelOffHidden" : true,
"Name" : "Economy/Normale",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "On",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 2,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "4"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 9,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 4,
"ID" : "00040003",
"Image" : "Generic",
"LastUpdate" : "2018-08-29 21:45:38",
"Level" : 0,
"LevelInt" : 0,
"Name" : "Pausa Termostato",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"Timers" : "false",
"Unit" : 3,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "5"
"status" : "OK",
"title" : "Devices"
Logread
Post by Logread » Thursday 30 August 2018 15:47
Do not use « localhost » as IP in the plugin configuration page... use 127.0.0.1
And yes your dummy temp sensor with idx 9 should be ok then
renerene
Post by renerene » Sunday 23 September 2018 11:04
same error here:
2018-09-23 10:58:25.410 Error: (thermostaat) 'onHeartbeat' failed 'KeyError'.
2018-09-23 10:58:25.410 Error: (thermostaat) ----> Line 596 in '/home/pi/domoticz/plugins/SVT/plugin.py', function onHeartbeat
2018-09-23 10:58:25.410 Error: (thermostaat) ----> Line 279 in '/home/pi/domoticz/plugins/SVT/plugin.py', function onHeartbeat
Following is not succesfull
- using 127.0.0.1 instead of localhost in hardware settings of SVT
- removing login info in hardware settings of SVT
- removing login of both domoticz and SVT
update:
error is probably because no devices are added bij Domoticz after adding a SVT hardware item
Logread
Post by Logread » Tuesday 25 September 2018 8:47
same error here:
update:
You are correct, domoticz does not create the devices if you so not allow it to: see the settings page and allow new devices to be created. This should resolve your issue.
elgarne
Post by elgarne » Tuesday 25 September 2018 10:47
Similar question: what happens if the target temperature changes over day? Does the learning persist?
Thanks.
