New (beta) version library requirement (Arm/Debian)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
jvbussel
Target OS: Raspberry Pi
Re: New (beta) version library requirement (Arm/Debian)
Post by jvbussel » Monday 11 September 2017 17:20
I just started all over again using the Stretch Lite image
When trying to start Domoticz it generate the following message:
./domoticz: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
But search the repo it only finds:
libssl1.0-dev - Secure Sockets Layer toolkit - development files
libssl1.0.2 - Secure Sockets Layer toolkit - shared libraries
libssl1.1 - Secure Sockets Layer toolkit - shared libraries
and both libssl1.0.2 and libssl1.1 are installed
What to do let Domoticz use libssl1.0.2 instead of libssl.so.1.0.0 ?
vthinsel
Post by vthinsel » Monday 11 September 2017 22:30
Well, so far I couldn't find a good solution. I do not need https, but libssl looks to be mandatory for domoticz to start. Recompiling domoticz/openssl sound the only option left, but I fear that my rpi one would overheat !
Is there a way to revert to the "previous" beta while I look for another solution ?
I'm also thinkking of replacing my raspberry 1 model B for a rpi 3 model as domoticz + mqtt + node-red is a bit slow on this good old rpi (domoticz runs perfectly on it but node-red is much more demanding), but this will not solve the issue for other rpi 1 owners.
Lets see what we can do.
Cheers.
melgi
Post by melgi » Monday 11 September 2017 23:00
gizmocuz wrote:
Saturday 09 September 2017 12:28
For new (beta) versions it is required that libssl 1.0.0 is installed.
This might not be at your current system (for example a raspberry running rasbian jessy or older)
To install this, issue:
sudo apt-get install libssl1.0.0
Can I just login through SSH (using PuTTY) in my ASUStor NAS and issue the command as shown above or do I have to be in a specific directory? I'm not that experienced with SSH-PuTTY, but did login in the past and installed several packages from the command line.
I can't update the Beta version anymore since I returned from my holiday (2nd September), but do want to give it a shot if with this I can update to the newest beta version.
Piet
Domoticz version: 3.8153
Post by Piet » Thursday 14 September 2017 18:27
(beta) version upgrade keeps failing
after following the step, sudo apt-get install libsll.0.0
libssl is already on the latest version
installing the latest Beta version 8394 do get failed error
[....] Restarting Domoticz Home Automation System: domoticz/home/pi/domoticz/domoticz: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.15' not found (required by /home/pi/domoticz/domoticz)
tried to find a solution to this error but did not succeed.
QuasaR
Post by QuasaR » Thursday 14 September 2017 21:48
Upgraded from Jessie to Stretch also didn't solve my problem.
I keep getting to following error:
[email protected]:~/domoticz $ ./domoticz
Illegal instruction
This is on rPi 1
[email protected]:~/domoticz $ cat /proc/cpuinfo
processor       : 0
model name      : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS        : 697.95
Features        : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2835
Revision        : 100000e
Serial          : 000000004d6acc62
barbaar
Post by barbaar » Thursday 14 September 2017 22:36
For those running Domoticz on an Odroid C2 with Debian; you need to get libssl1.1 from the testing repository.
Involver
Domoticz version: 3.4834
Post by Involver » Saturday 16 September 2017 21:30
Hi Piet,
Any progress on this? Have the same issue after upgrade, looking for either a solution or how to roll back to previous beta...
Domoticz - RPi - RFXCom - KaKu - Synology - HikVision - Oregon Scientific - YouLess - Anna
ben53252642
Post by ben53252642 » Sunday 17 September 2017 3:11
I'm running 3.8300 on Debian 9 stretch AMD 64.
Every time I try to upgrade Domoticz starts then crashes immediately, output is:
(Always happens just after the even system enters its loop state).
2017-09-17 11:06:13.580  PluginSystem: Entering work loop.
./domoticz(_ZN8CNetatmo5LoginEv+0x4cd)[0x8486ed]
./domoticz(_ZN8CNetatmo7Do_WorkEv+0x1b1)[0x84b0c1]
./domoticz[0xb3f17a]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x7494)[0x7f9155a03494]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)[0x7f9154da3aff]
======= Memory map: ========
00400000-00efd000 r-xp 00000000 00:13 87644                              /root/domoticz/domoticz
010fd000-01108000 r--p 00afd000 00:13 87644                              /root/domoticz/domoticz
01108000-0111d000 rw-p 00b08000 00:13 87644                              /root/domoticz/domoticz
0111d000-01140000 rw-p 00000000 00:00 0
02e9a000-03036000 rw-p 00000000 00:00 0                                  [heap]
7f910c000000-7f910c021000 rw-p 00000000 00:00 0
7f910c021000-7f9110000000 ---p 00000000 00:00 0
7f9110000000-7f9110021000 rw-p 00000000 00:00 0
7f9110021000-7f9114000000 ---p 00000000 00:00 0
7f9114000000-7f9114021000 rw-p 00000000 00:00 0
7f9114021000-7f9118000000 ---p 00000000 00:00 0
7f911b7ff000-7f911b800000 ---p 00000000 00:00 0
7f911b800000-7f911c000000 rw-p 00000000 00:00 0
7f911c000000-7f911c021000 rw-p 00000000 00:00 0
7f911c021000-7f9120000000 ---p 00000000 00:00 0
7f9120000000-7f9120021000 rw-p 00000000 00:00 0
7f9120021000-7f9124000000 ---p 00000000 00:00 0
7f9124000000-7f9124021000 rw-p 00000000 00:00 0
7f9124021000-7f9128000000 ---p 00000000 00:00 0
7f9128000000-7f9128021000 rw-p 00000000 00:00 0
7f9128021000-7f912c000000 ---p 00000000 00:00 0
7f912c000000-7f912c021000 rw-p 00000000 00:00 0
7f912c021000-7f9130000000 ---p 00000000 00:00 0
7f9130000000-7f913005a000 rw-p 00000000 00:00 0
7f913005a000-7f9134000000 ---p 00000000 00:00 0
7f9134000000-7f9134021000 rw-p 00000000 00:00 0
7f9134021000-7f9138000000 ---p 00000000 00:00 0
7f91385e2000-7f91385f8000 r-xp 00000000 00:13 7821                       /lib/x86_64-linux-gnu/libgcc_s.so.1
7f91385f8000-7f91387f7000 ---p 00016000 00:13 7821                       /lib/x86_64-linux-gnu/libgcc_s.so.1
7f91387f7000-7f91387f8000 r--p 00015000 00:13 7821                       /lib/x86_64-linux-gnu/libgcc_s.so.1
7f91387f8000-7f91387f9000 rw-p 00016000 00:13 7821                       /lib/x86_64-linux-gnu/libgcc_s.so.1
7f91387f9000-7f91387fa000 ---p 00000000 00:00 0
7f91387fa000-7f9138ffa000 rw-p 00000000 00:00 0
7f9138ffa000-7f9138ffb000 ---p 00000000 00:00 0
7f9138ffb000-7f91397fb000 rw-p 00000000 00:00 0
7f91397fb000-7f91397fc000 ---p 00000000 00:00 0
7f91397fc000-7f9139ffc000 rw-p 00000000 00:00 0
7f9139ffc000-7f9139ffd000 ---p 00000000 00:00 0
7f9139ffd000-7f913a7fd000 rw-p 00000000 00:00 0
7f913a7fd000-7f913a7fe000 ---p 00000000 00:00 0
7f913a7fe000-7f913affe000 rw-p 00000000 00:00 0
7f913affe000-7f913afff000 ---p 00000000 00:00 0
7f913afff000-7f913b7ff000 rw-p 00000000 00:00 0
7f913b7ff000-7f913b800000 ---p 00000000 00:00 0
7f913b800000-7f913c000000 rw-p 00000000 00:00 0
7f913c000000-7f913c055000 rw-p 00000000 00:00 0
7f913c055000-7f9140000000 ---p 00000000 00:00 0
7f9140000000-7f91400b2000 rw-p 00000000 00:00 0
7f91400b2000-7f9144000000 ---p 00000000 00:00 0
7f9144000000-7f9144021000 rw-p 00000000 00:00 0
7f9144021000-7f9148000000 ---p 00000000 00:00 0
7f9148085000-7f9148145000 rw-p 00000000 00:00 0
7f9148145000-7f914814a000 r-xp 00000000 00:13 7856                       /lib/x86_64-linux-gnu/libnss_dns-2.24.so
7f914814a000-7f9148349000 ---p 00005000 00:13 7856                       /lib/x86_64-linux-gnu/libnss_dns-2.24.so
7f9148349000-7f914834a000 r--p 00004000 00:13 7856                       /lib/x86_64-linux-gnu/libnss_dns-2.24.so
7f914834a000-7f914834b000 rw-p 00005000 00:13 7856                       /lib/x86_64-linux-gnu/libnss_dns-2.24.so
7f914834b000-7f9148355000 r-xp 00000000 00:13 7857                       /lib/x86_64-linux-gnu/libnss_files-2.24.so
7f9148355000-7f9148555000 ---p 0000a000 00:13 7857                       /lib/x86_64-linux-gnu/libnss_files-2.24.so
7f9148555000-7f9148556000 r--p 0000a000 00:13 7857                       /lib/x86_64-linux-gnu/libnss_files-2.24.so
7f9148556000-7f9148557000 rw-p 0000b000 00:13 7857                       /lib/x86_64-linux-gnu/libnss_files-2.24.so
7f9148557000-7f914855d000 rw-p 00000000 00:00 0
7f914855d000-7f914855e000 ---p 00000000 00:00 0
7f914855e000-7f9148d5e000 rw-p 00000000 00:00 0
7f9148d5e000-7f9148d5f000 ---p 00000000 00:00 0
7f9148d5f000-7f914955f000 rw-p 00000000 00:00 0
7f914955f000-7f9149560000 ---p 00000000 00:00 0
7f9149560000-7f9149d60000 rw-p 00000000 00:00 0
7f9149d60000-7f9149d61000 ---p 00000000 00:00 0
7f9149d61000-7f914a561000 rw-p 00000000 00:00 0
7f914a561000-7f914a562000 ---p 00000000 00:00 0
7f914a562000-7f914ad62000 rw-p 00000000 00:00 0
7f914ad62000-7f914ad63000 ---p 00000000 00:00 0
7f914ad63000-7f914b563000 rw-p 00000000 00:00 0
7f914b563000-7f914b564000 ---p 00000000 00:00 0
7f914b564000-7f914bd64000 rw-p 00000000 00:00 0
7f914bd64000-7f914bd65000 ---p 00000000 00:00 0
7f914bd65000-7f914c565000 rw-p 00000000 00:00 0
7f914c565000-7f914c566000 ---p 00000000 00:00 0
7f914c566000-7f914cd66000 rw-p 00000000 00:00 0
7f914cd66000-7f914cd67000 ---p 00000000 00:00 0
7f914cd67000-7f914d567000 rw-p 00000000 00:00 0
7f914d567000-7f914d568000 ---p 00000000 00:00 0
7f914d568000-7f914dd68000 rw-p 00000000 00:00 0
7f914dd68000-7f914dd69000 ---p 00000000 00:00 0
7f914dd69000-7f914e569000 rw-p 00000000 00:00 0
7f914e569000-7f914e56a000 ---p 00000000 00:00 0
7f914e56a000-7f914ef1b000 rw-p 00000000 00:00 0
7f914ef1b000-7f914ef1c000 ---p 00000000 00:00 0
7f914ef1c000-7f914f71c000 rw-p 00000000 00:00 0
7f914f71c000-7f914f71d000 ---p 00000000 00:00 0
7f914f71d000-7f914ff1d000 rw-p 00000000 00:00 0
7f914ff1d000-7f914ff1f000 r-xp 00000000 00:13 7866                       /lib/x86_64-linux-gnu/libutil-2.24.so
7f914ff1f000-7f915011e000 ---p 00002000 00:13 7866                       /lib/x86_64-linux-gnu/libutil-2.24.so
7f915011e000-7f915011f000 r--p 00001000 00:13 7866                       /lib/x86_64-linux-gnu/libutil-2.24.so
7f915011f000-7f9150120000 rw-p 00002000 00:13 7866                       /lib/x86_64-linux-gnu/libutil-2.24.so
7f9150120000-7f9150147000 r-xp 00000000 00:13 34306                      /lib/x86_64-linux-gnu/libexpat.so.1.6.2
7f9150147000-7f9150347000 ---p 00027000 00:13 34306                      /lib/x86_64-linux-gnu/libexpat.so.1.6.2
7f9150347000-7f9150349000 r--p 00027000 00:13 34306                      /lib/x86_64-linux-gnu/libexpat.so.1.6.2
7f9150349000-7f915034a000 rw-p 00029000 00:13 34306                      /lib/x86_64-linux-gnu/libexpat.so.1.6.2
7f915034a000-7f915070f000 r-xp 00000000 00:13 57898                      /usr/lib/x86_64-linux-gnu/libpython3.5m.so.1.0
7f915070f000-7f915090f000 ---p 003c5000 00:13 57898                      /usr/lib/x86_64-linux-gnu/libpython3.5m.so.1.0
7f915090f000-7f9150911000 r--p 003c5000 00:13 57898                      /usr/lib/x86_64-linux-gnu/libpython3.5m.so.1.0
7f9150911000-7f91509a8000 rw-p 003c7000 00:13 57898                      /usr/lib/x86_64-linux-gnu/libpython3.5m.so.1.0
7f91509a8000-7f91509d9000 rw-p 00000000 00:00 0
7f91509d9000-7f91509e0000 r-xp 00000000 00:13 17480                      /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7f91509e0000-7f9150be0000 ---p 00007000 00:13 17480                      /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7f9150be0000-7f9150be1000 r--p 00007000 00:13 17480                      /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7f912017-09-17 11:06:13.595  Python EventSystem: Module not found - Trying to initialize.
50be1000-7f9150be2000 rw-p 00008000 00:13 17480                      /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7f9150be2000-7f9150bf5000 r-xp 00000000 00:13 8884                       /lib/x86_64-linux-gnu/libgpg-error.so.0.21.0
7f9150bf5000-7f9150df4000 ---p 00013000 00:13 8884                       /lib/x86_64-linux-gnu/libgpg-error.so.0.21.0
7f9150df4000-7f9150df5000 r--p 00012000 00:13 8884                       /lib/x86_64-linux-gnu/libgpg-error.so.0.21.0
7f9150df5000-7f9150df6000 rw-p 00013000 00:13 8884                       /lib/x86_64-linux-gnu/libgpg-error.so.0.21.0
7f9150df6000-7f9150e07000 r-xp 00000000 00:13 18622                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.3
7f9150e07000-7f9151007000 ---p 00011000 00:13 18622                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.3
7f9151007000-7f9151008000 r--p 00011000 00:13 18622                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.3
7f9151008000-7f9151009000 rw-p 00012000 00:13 18622                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.3
7f9151009000-7f915103b000 r-xp 00000000 00:13 15456                      /lib/x86_64-linux-gnu/libidn.so.11.6.16
7f915103b000-7f915123b000 ---p 00032000 00:13 15456                      /lib/x86_64-linux-gnu/libidn.so.11.6.16
7f915123b000-7f915123c000 r--p 00032000 00:13 15456                      /lib/x86_64-linux-gnu/libidn.so.11.6.16
7f915123c000-7f915123d000 rw-p 00033000 00:13 15456                      /lib/x86_64-linux-gnu/libidn.so.11.6.16
7f915123d000-7f9151297000 r-xp 00000000 00:13 17495                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.2.0
7f9151297000-7f9151496000 ---p 0005a000 00:13 17495                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.2.0
7f9151496000-7f91514a0000 r--p 00059000 00:13 17495                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.2.0
7f91514a0000-7f91514a2000 rw-p 00063000 00:13 17495                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.2.0
7f91514a2000-7f91514bc000 r-xp 00000000 00:13 41341                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
7f91514bc000-7f91516bb000 ---p 0001a000 00:13 41341                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
7f91516bb000-7f91516bc000 r--p 00019000 00:13 41341                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
7f91516bc000-7f91516bd000 rw-p 0001a000 00:13 41341                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
7f91516bd000-7f91516d1000 r-xp 00000000 00:13 7863                       /lib/x86_64-linux-gnu/libresolv-2.24.so
7f91516d1000-7f91518d0000 ---p 00014000 00:13 7863                       /lib/x86_64-linux-gnu/libresolv-2.24.so
7f91518d0000-7f91518d1000 r--p 00013000 00:13 7863                       /lib/x86_64-linux-gnu/libresolv-2.24.so
7f91518d1000-7f91518d2000 rw-p 00014000 00:13 7863                       /lib/x86_64-linux-gnu/libresolv-2.24.so
7f91518d2000-7f91518d4000 rw-p 00000000 00:00 0
7f91518d4000-7f91518d7000 r-xp 00000000 00:13 40636                      /lib/x86_64-linux-gnu/libkeyutils.so.1.5
7f91518d7000-7f9151ad6000 ---p 00003000 00:13 40636                      /lib/x86_64-linux-gnu/libkeyutils.so.1.5
7f9151ad6000-7f9151ad7000 r--p 00002000 00:13 40636                      /lib/x86_64-linux-gnu/libkeyutils.so.1.5
7f9151ad7000-7f9151ad8000 rw-p 00003000 00:13 40636                      /lib/x86_64-linux-gnu/libkeyutils.so.1.5
7f9151ad8000-7f9151ae3000 r-xp 00000000 00:13 40648                      /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
7f9151ae3000-7f9151ce2000 ---p 0000b000 00:13 40648                      /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
7f9151ce2000-7f9151ce3000 r--p 0000a000 00:13 40648                      /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
7f9151ce3000-7f9151ce4000 rw-p 0000b000 00:13 40648                      /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
7f9151ce4000-7f9151deb000 r-xp 00000000 00:13 29780                      /lib/x86_64-linux-gnu/libgcrypt.so.20.1.6
7f9151deb000-7f9151feb000 ---p 00107000 00:13 29780                      /lib/x86_64-linux-gnu/libgcrypt.so.20.1.6
7f9151feb000-7f9151fed000 r--p 00107000 00:13 29780                      /lib/x86_64-linux-gnu/libgcrypt.so.20.1.6
7f9151fed000-7f9151ff4000 rw-p 00109000 00:13 29780                      /lib/x86_64-linux-gnu/libgcrypt.so.20.1.6
7f9151ff4000-7f9152075000 r-xp 00000000 00:13 17434                      /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.2
7f9152075000-7f9152275000 ---p 00081000 00:13 17434                      /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.2
7f9152275000-7f9152276000 r--p 00081000 00:13 17434                      /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.2
7f9152276000-7f9152277000 rw-p 00082000 00:13 17434                      /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.2
7f9152277000-7f91522ac000 r-xp 00000000 00:13 17450                      /usr/lib/x86_64-linux-gnu/libnettle.so.6.3
7f91522ac000-7f91524ab000 ---p 00035000 00:13 17450                      /usr/lib/x86_64-linux-gnu/libnettle.so.6.3
7f91524ab000-7f91524ad000 r--p 00034000 00:13 17450                      /usr/lib/x86_64-linux-gnu/libnettle.so.6.3
7f91524ad000-7f91524ae000 rw-p 00036000 00:13 17450                      /usr/lib/x86_64-linux-gnu/libnettle.so.6.3
7f91524ae000-7f91524e1000 r-xp 00000000 00:13 17467                      /usr/lib/x86_64-linux-gnu/libhogweed.so.4.3
7f91524e1000-7f91526e1000 ---p 00033000 00:13 17467                      /usr/lib/x86_64-linux-gnu/libhogweed.so.4.3
7f91526e1000-7f91526e2000 r--p 00033000 00:13 17467                      /usr/lib/x86_64-linux-gnu/libhogweed.so.4.3
7f91526e2000-7f91526e3000 rw-p 00034000 00:13 17467                      /usr/lib/x86_64-linux-gnu/libhogweed.so.4.3
7f91526e3000-7f915286d000 r-xp 00000000 00:13 17513                      /usr/lib/x86_64-linux-gnu/libgnutls.so.30.13.1
7f915286d000-7f9152a6d000 ---p 0018a000 00:13 17513                      /usr/lib/x86_64-linux-gnu/libgnutls.so.30.13.1
7f9152a6d000-7f9152a7a000 r--p 0018a000 00:13 17513                      /usr/lib/x86_64-linux-gnu/libgnutls.so.30.13.1
7f9152a7a000-7f9152a7b000 rw-p 00197000 00:13 17513                      /usr/lib/x86_64-linux-gnu/libgnutls.so.30.13.1
7f9152a7b000-7f9152a7c000 rw-p 00000000 00:00 0
7f9152a7c000-7f9152b8f000 r-xp 00000000 00:13 18742                      /usr/lib/x86_64-linux-gnu/libunistring.so.0.1.2
7f9152b8f000-7f9152d8e000 ---p 00113000 00:13 18742                      /usr/lib/x86_64-linux-gnu/libunistring.so.0.1.2
7f9152d8e000-7f9152d91000 r--p 00112000 00:13 18742                      /usr/lib/x86_64-linux-gnu/libunistring.so.0.1.2
7f9152d91000-7f9152d92000 rw-p 00115000 00:13 18742                      /usr/lib/x86_64-linux-gnu/libunistring.so.0.1.2
7f9152d92000-7f9152d93000 rw-p 00000000 00:00 0
7f9152d93000-7f9152de0000 r-xp 00000000 00:13 41376                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.7
7f9152de0000-7f9152fdf000 ---p 0004d000 00:13 41376                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.7
7f9152fdf000-7f9152fe1000 r--p 0004c000 00:13 41376                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.7
7f9152fe1000-7f9152fe2000 rw-p 0004e000 00:13 41376                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.7
7f9152fe2000-7f9152fe4000 rw-p 00000000 00:00 0
7f9152fe4000-7f9152ff1000 r-xp 00000000 00:13 41375                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.7
7f9152ff1000-7f91531f1000 ---p 0000d000 00:13 41375                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.7
7f91531f1000-7f91531f2000 r--p 0000d000 00:13 41375                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.7
7f91531f2000-7f91531f3000 rw-p 0000e000 00:13 41375                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.7
7f91531f3000-7f91531f6000 r-xp 00000000 00:13 9578                       /lib/x86_64-linux-gnu/libcom_err.so.2.1
7f91531f6000-7f91533f5000 ---p 00003000 00:13 9578                       /lib/x86_64-linux-gnu/libcom_err.so.2.1
7f91533f5000-7f91533f6000 r--p 00002000 00:13 9578                       /lib/x86_64-linux-gnu/libcom_err.so.2.1
7f91533f6000-7f91533f7000 rw-p 00003000 00:13 9578                       /lib/x86_64-linux-gnu/libcom_err.so.2.1
7f91533f7000-7f9153426000 r-xp 00000000 00:13 40664                      /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
7f9153426000-7f9153626000 ---p 0002f000 00:13 40664                      /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
7f9153626000-7f9153628000 r--p 0002f000 00:13 40664                      /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
7f9153628000-7f9153629000 rw-p 00031000 00:13 40664                      /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
7f9153629000-7f915362a000 rw-p 00000000 00:00 0
7f915362a000-7f91536f3000 r-xp 00000000 00:13 40683                      /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
7f91536f3000-7f91538f3000 ---p 000c9000 00:13 40683                      /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
7f91538f3000-7f9153901000 r--p 000c9000 00:13 40683                      /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
7f9153901000-7f9153904000 rw-p 000d7000 00:13 40683                      /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
7f9153904000-7f915394c000 r-xp 00000000 00:13 40707                      /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
7f915394c000-7f9153b4b000 ---p 00048000 00:13 40707                      /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
7f9153b4b000-7f9153b4d000 r--p 00047000 00:13 40707                      /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
7f9153b4d000-7f9153b4f000 rw-p 00049000 00:13 40707                      /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
7f9153b4f000-7f9153d84000 r-xp 00000000 00:13 18712                      /usr/lib/x86_64-linux-gnu/libcrypto.so.1.0.2
7f9153d84000-7f9153f84000 ---p 00235000 00:13 18712                      /usr/lib/x86_64-linux-gnu/libcrypto.so.1.0.2
7f9153f84000-7f9153fa0000 r--p 00235000 00:13 18712                      /usr/lib/x86_64-linux-gnu/libcrypto.so.1.0.2
7f9153fa0000-7f9153faf000 rw-p 00251000 00:13 18712                      /usr/lib/x86_64-linux-gnu/libcrypto.so.1.0.2
7f9153faf000-7f9153fb3000 rw-p 00000000 00:00 0
7f9153fb3000-7f9154012000 r-xp 00000000 00:13 18713                      /usr/lib/x86_64-linux-gnu/libssl.so.1.0.2
7f9154012000-7f9154212000 ---p 0005f000 00:13 18713                      /usr/lib/x86_64-linux-gnu/libssl.so.1.0.2
7f9154212000-7f9154216000 r--p 0005f000 00:13 18713                      /usr/lib/x86_64-linux-gnu/libssl.so.1.0.2
7f9154216000-7f915421c000 rw-p 00063000 00:13 18713                      /usr/lib/x86_64-linux-gnu/libssl.so.1.0.2
7f915421c000-7f9154228000 r-xp 00000000 00:13 18852                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.1.1
7f9154228000-7f9154428000 ---p 0000c000 00:13 18852                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.1.1
7f9154428000-7f9154429000 r--p 0000c000 00:13 18852                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.1.1
7f9154429000-7f915442a000 rw-p 0000d000 00:13 18852                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.1.1
7f915442a000-7f9154455000 r-xp 00000000 00:13 45167                      /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
7f9154455000-7f9154654000 ---p 0002b000 00:13 45167                      /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
7f9154654000-7f9154655000 r--p 0002a000 00:13 45167                      /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
7f9154655000-7f9154656000 rw-p 0002b000 00:13 45167                      /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
7f9154656000-7f9154671000 r-xp 00000000 00:13 45151                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
7f9154671000-7f9154871000 ---p 0001b000 00:13 45151                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
7f9154871000-7f9154872000 r--p 0001b000 00:13 45151                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
7f9154872000-7f9154873000 rw-p 0001c000 00:13 45151                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
7f9154873000-7f9154894000 r-xp 00000000 00:13 18335                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.1.4
7f9154894000-7f9154a93000 ---p 00021000 00:13 18335                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.1.4
7f9154a93000-7f9154a94000 r--p 00020000 00:13 18335                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.1.4
7f9154a94000-7f9154a95000 rw-p 00021000 00:13 18335                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.1.4
7f9154a95000-7f9154ab8000 r-xp 00000000 00:13 45133                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.12.3
7f9154ab8000-7f9154cb7000 ---p 00023000 00:13 45133                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.12.3
7f9154cb7000-7f9154cb8000 r--p 00022000 00:13 45133                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.12.3
7f9154cb8000-7f9154cbb000 rw-p 00023000 00:13 45133                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.12.3
7f9154cbb000-7f9154e50000 r-xp 00000000 00:13 7847                       /lib/x86_64-linux-gnu/libc-2.24.so
7f9154e50000-7f9155050000 ---p 00195000 00:13 7847                       /lib/x86_64-linux-gnu/libc-2.24.so
7f9155050000-7f9155054000 r--p 00195000 00:13 7847                       /lib/x86_64-linux-gnu/libc-2.24.so
7f9155054000-7f9155056000 rw-p 00199000 00:13 7847                       /lib/x86_64-linux-gnu/libc-2.24.so
7f9155056000-7f915505a000 rw-p 00000000 00:00 0
7f915505a000-7f915515d000 r-xp 00000000 00:13 7851                       /lib/x86_64-linux-gnu/libm-2.24.so
7f915515d000-7f915535c000 ---p 00103000 00:13 7851                       /lib/x86_64-linux-gnu/libm-2.24.so
7f915535c000-7f915535d000 r--p 00102000 00:13 7851                       /lib/x86_64-linux-gnu/libm-2.24.so
7f915535d000-7f915535e000 rw-p 00103000 00:13 7851                       /lib/x86_64-linux-gnu/libm-2.24.so
7f915535e000-7f9155361000 r-xp 00000000 00:13 7850                       /lib/x86_64-linux-gnu/libdl-2.24.so
7f9155361000-7f9155560000 ---p 00003000 00:13 7850                       /lib/x86_64-linux-gnu/libdl-2.24.so
7f9155560000-7f9155561000 r--p 00002000 00:13 7850                       /lib/x86_64-linux-gnu/libdl-2.24.so
7f9155561000-7f9155562000 rw-p 00003000 00:13 7850                       /lib/x86_64-linux-gnu/libdl-2.24.so
7f9155562000-7f91555df000 r-xp 00000000 00:13 53862                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.4.0
7f91555df000-7f91557de000 ---p 0007d000 00:13 53862                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.4.0
7f91557de000-7f91557e1000 r--p 0007c000 00:13 53862                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.4.0
7f91557e1000-7f91557e2000 rw-p 0007f000 00:13 53862                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.4.0
7f91557e2000-7f91557fb000 r-xp 00000000 00:13 10262                      /lib/x86_64-linux-gnu/libz.so.1.2.8
7f91557fb000-7f91559fa000 ---p 00019000 00:13 10262                      /lib/x86_64-linux-gnu/libz.so.1.2.8
7f91559fa000-7f91559fb000 r--p 00018000 00:13 10262                      /lib/x86_64-linux-gnu/libz.so.1.2.8
7f91559fb000-7f91559fc000 rw-p 00019000 00:13 10262                      /lib/x86_64-linux-gnu/libz.so.1.2.8
7f91559fc000-7f9155a14000 r-xp 00000000 00:13 7862                       /lib/x86_64-linux-gnu/libpthread-2.24.so
7f9155a14000-7f9155c13000 ---p 00018000 00:13 7862                       /lib/x86_64-linux-gnu/libpthread-2.24.so
7f9155c13000-7f9155c14000 r--p 00017000 00:13 7862                       /lib/x86_64-linux-gnu/libpthread-2.24.so
7f9155c14000-7f9155c15000 rw-p 00018000 00:13 7862                       /lib/x86_64-linux-gnu/libpthread-2.24.so
7f9155c15000-7f9155c19000 rw-p 00000000 00:00 0
7f9155c19000-7f9155c20000 r-xp 00000000 00:13 7864                       /lib/x86_64-linux-gnu/librt-2.24.so
7f9155c20000-7f9155e1f000 ---p 00007000 00:13 7864                       /lib/x86_64-linux-gnu/librt-2.24.so
7f9155e1f000-7f9155e20000 r--p 00006000 00:13 7864                       /lib/x86_64-linux-gnu/librt-2.24.so
7f9155e20000-7f9155e21000 rw-p 00007000 00:13 7864                       /lib/x86_64-linux-gnu/librt-2.24.so
7f9155e21000-7f9155e28000 r-xp 00000000 00:13 34324                      /lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4
7f9155e28000-7f9156027000 ---p 00007000 00:13 34324                      /lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4
7f9156027000-7f9156028000 r--p 00006000 00:13 34324                      /lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4
7f9156028000-7f9156029000 rw-p 00007000 00:13 34324                      /lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4
7f9156029000-7f915602a000 rw-p 00000000 00:00 0
7f915602a000-7f915604d000 r-xp 00000000 00:13 7843                       /lib/x86_64-linux-gnu/ld-2.24.so
7f915606d000-7f915606e000 rw-p 00000000 00:00 0
7f915606e000-7f9156075000 r--s 00000000 00:13 8115                       /usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache
7f9156075000-7f9156210000 r--p 00000000 00:13 20771                      /usr/lib/locale/locale-archive
7f9156210000-7f9156221000 rw-p 00000000 00:00 0
7f9156221000-7f9156240000 r-xp 00000000 00:13 11345                      /lib/x86_64-linux-gnu/libudev.so.1.6.5Aborted
libssl1.0.0 is installed (this package):
http://ftp.us.debian.org/debian/pool/ma ... _amd64.deb
I've tried disabling Domoticz SSL etc... I can't get it to run.
I've gone back to 3.8300 for now.
sach
Post by sach » Monday 18 September 2017 9:22
Exactly the same issue here. Ubuntu 16.04.3.
I think it has something to do with notifications. If I disable them and upgrade then its ok, until I try to test any of the 3 notification systems I use (GCM, Pushbullet or Email).
I note from other threads that notifications are not an issue if built from source, but I'm a proper Linux NOOB so haven't attempted that yet.
Back to stable for now.
ben53252642
Post by ben53252642 » Thursday 21 September 2017 17:34
Has anyone found a solution for this? I just tried to upgrade to 3.8356 and still the same issue.
I haven't been able to upgrade my Domoticz installation for about the last month without it breaking.
It always crashes during startup with the same error...
Gizmocuz? :cry:
ben53252642
Post by ben53252642 » Thursday 21 September 2017 21:33
Update:
I solved the problem by backing up the database in Domoticz, compiling the latest version 3.8423 from scratch and restoring the backup.
Now my system works on the latest version. :D
roblom
Post by roblom » Thursday 21 September 2017 21:36
But not everybody is able to compile... Like me for example...
Therefore I'm also not able to update for a while.
krisha
Post by krisha » Friday 29 September 2017 13:51
I'm using a Pi 1 Model B and also get "Illegal instruction".
Inside the update script the architecture armv61 gets overwritten by armv7.
All Pi 1 and Zero models have the same SoC.
LibSSL did not solve it for me.
Maybe it's really using an instruction/opcode that is just available to ARMv7 and later?
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen » Friday 29 September 2017 13:56
krisha
Post by krisha » Friday 29 September 2017 14:12
take a look at
viewtopic.php?f=6&t=19619#p152231
do you use a Pi 1(BCM2835) or Pi 2 (>=BCM2836)?
Jan Jansen
Post by Jan Jansen » Friday 29 September 2017 15:15
As far as I know, I use a raspberry pi B rev 2.0. I do not know how to find the answer to your question.
krisha
Post by krisha » Friday 29 September 2017 15:26
ok thx, You can find out by typing
cat /proc/cpuinfo
Under Hardware you see the SoC used.
If you have a Pi 2 (BCM2836 or higher) I don't think that your solution will work on Pi 1 or Zero.
Jan Jansen
Post by Jan Jansen » Friday 29 September 2017 15:52
cat /proc/cpuinfo >>> Hardware: BCM2835.
As I said, my system works again. Fortunately, my pifaces also do what they need to do.
joebar
Post by joebar » Saturday 30 September 2017 18:08
Same as some others:
Newly installed stretch on a pi zero.
Clean install release version: libssl cannot be found, despite the 1.0.0.2 and 1.1 are installed by default.
installed the direct download of 1.0.0.1, running release version
Update to beta: error
Removed the 1.0.0.1 and reinstalled 1.0.0.2 : libssl cannot be found.
Hope anyone has an solution because for now it seems that you cannot upgrade beyond the September 6 version or stable release and that is no option with all the xiaomi devices
ben53252642
Post by ben53252642 » Saturday 30 September 2017 21:00
Have you tried removing SSL from the Domoticz startup? I put a # in my /etc/init.d/domoticz file: #DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
If you want SSL my suggestion is to simply put an Apache or Nginx reverse proxy in front of Domoticz.
Users browsing this forum: No registered users and 4 guests
