New (beta) version library requirement (Arm/Debian)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
Jan Jansen
Target OS: Raspberry Pi
Re: New (beta) version library requirement (Arm/Debian)
Post by Jan Jansen » Monday 04 December 2017 21:04
Yesterday i did a fresh install (RPI 1B BCM2835), cause I wanted get rid of the libssl1.0.0.
After curl -L install.domoticz.com | sudo bash, I did:
cd domoticz
./updatebeta
Domoticz works as desired.
jankeeso
Domoticz version: 3.8833
Post by jankeeso » Friday 19 January 2018 14:49
@Jan Jansen: You are my hero.....domoticz starts....at last.....thnx
Jan Jansen
Post by Jan Jansen » Saturday 20 January 2018 8:51
Gizmocuz deserves your compliments (see start of this topic).
Derik
Post by Derik » Sunday 21 January 2018 14:27
Dear All:
domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; bad; vendor preset: enabled)
   Active: active (exited) since Sun 2018-01-21 13:23:04 CET; 38s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 32470 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
  Process: 32561 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Jan 21 13:23:04 odroidxu4 systemd[1]: Starting LSB: Home Automation System...
Jan 21 13:23:04 odroidxu4 domoticz.sh[32561]: 2018-01-21 13:23:04.919  Domoticz V3.8833 (c)2012-2018 GizMoCuz
Jan 21 13:23:04 odroidxu4 domoticz.sh[32561]: 2018-01-21 13:23:04.919  Build Hash: 60050638, Date: 2018-01-19 13:22:13
Jan 21 13:23:04 odroidxu4 domoticz.sh[32561]: 2018-01-21 13:23:04.919  Startup Path: /home/root/domoticz/
Jan 21 13:23:04 odroidxu4 domoticz.sh[32561]: domoticz: Domoticz is starting up....
Jan 21 13:23:04 odroidxu4 domoticz[32566]: Domoticz is starting up....
Jan 21 13:23:04 odroidxu4 domoticz[32567]: Domoticz running...
Jan 21 13:23:04 odroidxu4 systemd[1]: Started LSB: Home Automation System.
root@odroidxu4:~#
I do have the great problem....
When i run the latest release no problem..
When ir run the latest beta grrr get this error and not working domoticz
Did all the thing here
Only every time the error...
root@odroidxu4:~# cat /etc/os-release
NAME="Ubuntu"
VERSION="16.04.3 LTS (Xenial Xerus)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 16.04.3 LTS"
VERSION_ID="16.04"
HOME_URL="http://www.ubuntu.com/"
SUPPORT_URL="http://help.ubuntu.com/"
BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
VERSION_CODENAME=xenial
UBUNTU_CODENAME=xenial
root@odroidxu4:~#
Help or something..:-)
Schorschi
Post by Schorschi » Wednesday 24 January 2018 11:37
I hope we get an new running beta today :)
Schorschi
Post by Schorschi » Wednesday 24 January 2018 15:45
News...
I can't wait until next beta so i compiled last source files by my self and now domoticz running again.
:D ;)
Post by waaren » Wednesday 24 January 2018 16:14
Is this on Jessie or on Stretch ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave , dzVents 2.4.n, Amazon echo
Schorschi
Post by Schorschi » Wednesday 24 January 2018 22:22
I use Raspi-Stretch.
Post by waaren » Thursday 25 January 2018 1:05
Just finished compiling version 3.8841 on my development Raspberry PI3 . Unfortunately it still stops with fatal signal 11
2018-01-24 23:23:48.183 Error: Domoticz received fatal signal 11 !...
2018-01-24 23:23:48.185 Error: /opt/domoticz/domoticz() [0x243b50]
2018-01-24 23:23:48.186 Error: /opt/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x243c08]
2018-01-24 23:23:48.186 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c476b0]
Both production and development Debian stretch and Python 3.5.3
several Python plugins (Sonos, Buienradar amonigst others)
Derik
Post by Derik » Thursday 25 January 2018 9:20
try to remove the plugins first...
then again..
My setup fuckup with buienradar plugin remove from plugin map the buienradar.
Then reboot the board..
For me without buienradar everything works great..
Post by waaren » Thursday 25 January 2018 10:06
then again..
Thanks for your answer.
When I remove Buienradar, Sonos and Homewizard plugin (leaving NUT_UPS, PI-monitor and batterylevel plugins) ./updatebeta (V3.8841) works.
When I remove Buienradar, Sonos plugin (leaving Homewizard, NUT_UPS, PI-monitor and batterylevel plugins) my compiled from source with option -DUSE_OPENSSL_STATIC="NO" works.
With my compiled from source (V3.9032 from Dannybloe's GIT) with option -DUSE_OPENSSL_STATIC="NO" everything works.
Thing is; I kind of like all of my plugins to work and I am a big fan of dzVents but also like the idea of simple updates. But hé that's life, you don't always get what you want :D
SteGe
Post by SteGe » Thursday 25 January 2018 11:52
+1 for me Derik...
Raspberry pi 3b
RFXtrx433E
Sompfy sunscreen
Cresta weatherstation
4 elro power switches
Doorbell/chime
Letterbox "reader"
Eneco Toon (also for reading smartmeter by P1)
MySensors (Humidity, Temperature, Lux)
Derik
Post by Derik » Thursday 08 February 2018 23:10
Is there perhaps a solution for the older version raspberry model b..
Running only see:
Active: active (exited) since xxx
grr
root@DietPi:~# cat /etc/*-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
root@DietPi:~#
Calzor Suzay
Domoticz version: 3.9629
Post by Calzor Suzay » Sunday 10 June 2018 20:17
Running a Vero4k (Arm64 I think) but having the same issue...
Vero4K domoticz.sh[1791]: /home/osmc/domoticz/domoticz: error while loading shared libraries: libusb-0.1.so.4: cannot open shared object file: No such file or directory
Tried the fix wget http://mirrordirector.raspbian.org/rasp ... _armhf.deb
but I get a 404
root@Vero4K:/home/osmc/domoticz# wget http://mirrordirector.raspbian.org/rasp ... _armhf.deb
--2018-06-10 19:16:25-- http://mirrordirector.raspbian.org/rasp ... _armhf.deb
Resolving mirrordirector.raspbian.org (mirrordirector.raspbian.org)... 93.93.128.193, 2a00:1098:0:80:1000:75:0:3
Connecting to mirrordirector.raspbian.org (mirrordirector.raspbian.org)|93.93.128.193|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2018-06-10 19:16:25 ERROR 404: Not Found.
Is this the right fix and where is the file now?
Calzor Suzay
Post by Calzor Suzay » Sunday 10 June 2018 20:51
For anyone else using a Vero4k this is down to the type of Architecture detected by the install script, it was detecting Aarch64 and should of been Arm7l.
In the end I run the easy method install script, then updated to Beta, then downloading the arm7l beta version and extracted this over the top.
It now works.
Users browsing this forum: No registered users and 3 guests
