Sunrise-sunset blocky not working
niclasc
Target OS: Raspberry Pi
Domoticz version: 4.9700
Post by niclasc » Monday 04 September 2017 19:55
I have 2 blocky scripts for setting a dummy switch on or off depending on if sun is up or down.
But it never switches on or off
Can anyone tell me why its not working?
Screenshot from 2017-09-04 19-50-59.png (23 KiB) Viewed 1554 times
Screenshot from 2017-09-04 19-50-34.png (24.28 KiB) Viewed 1554 times
Andree
Post by Andree » Monday 04 September 2017 21:53
Becouse you have to set "OR" instead of "AND".
Time > Sunset OR time < Sunrise
bldewit
Re: Sunrise-sunset blocky not working
Post by bldewit » Saturday 25 August 2018 9:55
I think these scripts are cancelling each other. All items in the IF-section are triggers, so if the first script turns it on, the second script is triggerred and switches it off...
Maybe switching the blockly category from ALL to TIME will solve it, but I have found LUA to be much more accurate in controlling which switches are used for triggering and which for reference. Also you have the benefit of nested IF's in LUA, which also gives more control.
Looking at the date of this post I sincerely hope you have already solved this problem though 😁
Prutsium
Post by Prutsium » Saturday 25 August 2018 11:02
Had a similar issue check here: http://www.domoticz.com/forum/viewtopic ... 42#p188942
In my case it was If/Or issue.
