Cheap 433MHz door sensor (with open and close)
oasisnl
Target OS: Raspberry Pi
Re: Cheap 433MHz door sensor (with open and close)
Post by oasisnl » Friday 01 December 2017 2:55
these are dzvents scripts.
they should be placed in /path/to/domoticz/scripts/dzVents/scripts . Just activated the first contact and works great.
BarnaM7
Post by BarnaM7 » Sunday 07 January 2018 20:21
I'm going to buy same of this sensor.
I have some mysensor nodes and sonoff switches with ESPurna firmware, but I'm not familiar with 433Mhz based sensors. I would like to buy an sonoff 433 bridge for the 433mhz door sensors and replace the firmware too.
I think this could be a good setup, am I right ? Or build a RFLINK gateway ?
Do you have any tip for 433Mhz based temp sensor?
thanks
Barna
marhar
Post by marhar » Saturday 13 January 2018 16:08
Hello, I orderd a few at aliexpress.
When I add one in domoticz (v3.8153 on synology with RFXtrx44e) as mentioned in the movie I only get one device and not 2.
The device is added as a "x10 security" motion detector.
How can I get 2 devices so that I can see on or off ?
Can someone helpme out??
cheers Marc
bjacobse
Post by bjacobse » Saturday 13 January 2018 19:41
How long batterylifetime have you experienced?
marhar
Post by marhar » Saturday 13 January 2018 20:15
I just got them so I don't know.
JelteV
Post by JelteV » Wednesday 14 February 2018 15:43
Still running on the original battery.
d4nh
Post by d4nh » Wednesday 28 March 2018 9:59
sadly mine are not being detected by domoticz, might be a faulty one :(
weird... turned the magnet, now it worked for the open detection.
no closing device turned up in the list
nope.. no luck. not updating realtime. think i have a faulty product :(
plampix
Post by plampix » Wednesday 11 April 2018 21:02
Even simpler would be this generic solution (follow JelteV's instructions, just call the on/off devices $device/close and $device/open, and the main device $device). This will work for all your */close and */open devices!
	active = true, -- set to false to disable this script
		devices = {
			'*/close',
			'*/open'
	-- in case of a timer event or security event, device == nil
		if (device.changed) then
		    target, action = string.match(device.name, '(.+)/(.+)');
		    if (action == 'close') then
			    domoticz.devices(target).close();
			elseif (action == 'open') then
			    domoticz.devices(target).open();
harolds
Post by harolds » Monday 10 September 2018 9:10
Super cool script! Working like a charm 8-)
lucdc
Post by lucdc » Wednesday 26 September 2018 18:15
Great script plampix, thank you! The only inconvenience that I found is that, when you hide the on/off devices by starting their name with a "$" sign, the name of the main device will also have to start with a "$" sign, and will be hidden as well. I solved it by slightly modifying one line in your script: I changed
into
target, action = string.match(device.name, '$?(.+)/(.+)');
and now the name of the main device can, but does not have to start with a "$".
cherowley
Post by cherowley » Saturday 03 November 2018 15:02
Thanks for the heads-up on these, modded them to monitor locked status on all my uPVC doors.
Surprisingly easy, just moved the reed switch to behind the dead bolt recess and glued a tiny magnet on the end of the dead bolt.
Simples! Now Alexa warns me when going out or to bed if any door is unlocked 😁
Jubbes
Post by Jubbes » Tuesday 06 November 2018 5:36
Hallo, where must i write in the script the 2 names from the devices front door open/close (event) and the name from the virtual button front door?
cherowley
Post by cherowley » Wednesday 07 November 2018 16:30
I used a lua script (setup/more options/events):
if devicechanged["$Open3"] and devicechanged["$Open3"]=='On' then
commandArray['Front Door'] = "Off"
if devicechanged["$Close3"] and devicechanged["$Close3"]=='On' then
commandArray['Front Door'] = "On"
Dave21w
Post by Dave21w » Wednesday 07 November 2018 21:43
I have a couple of these :-
https://www.ebay.co.uk/itm/KERUI-D026-W ... 2394768280
That I am using on my doors, not quite as cheap but you see them as one X10 Security device, status is shown as Normal when closed and Alarm when open, I'm fairly new to Domoticz so not sure if the status could be changed to Open and Closed instead, either way they seem reliable, if used with the kerui alarm system they apparently report low battery too but not had mine long enough to see if thats the case with Domoticz too. Also if you don't like the blue writing on the side a little rubbing with isopropanol alcohol removes its so just plain white goes well with UPC.
Also the D026 model is the newer one, the previous D025 only report an open not a close so don't get that one.
Not tried the below yet but I assume they will work too.
https://www.ebay.co.uk/itm/KERUI-433Mh- ... 3457750875
Hope the info helps
P.S A search for Kerui D026 on amazon will get you some too
renerene
Post by renerene » Thursday 08 November 2018 8:20
Those KERU D026 don't last a year with a battery. I'm guessing more like 8 months. I use 3 of them, indoors. Because they use the expensive A23 battery, I was hoping for better.
brjhaverkamp
Post by brjhaverkamp » Thursday 15 November 2018 22:01
I recently got a bunch of D026 as well.
I operate domoticz on a Rpi with an RFlink gateway attached. This is probably different than your Rfxcon setup.
in my case rflink detects 3 independent switches on the device.
Switch 00 emits off when the door opens
Switch 02 is the tamperswitch on the back and ends an On signal when pressed
Switch 03 emits on when the door closes
There is probably a signal for low battery, but I havent gotten that far.
My question now is, what does it exactly look like when using an Rfxcon? I would rather have one single device. Is this something that is should be done on the rflink/rfxcon side, or is that a config file for the device in domoticz itself?
I have a similar issue with the Keriu P829 PIRs. They show up as 1 switch where the motion is an off signal and the tamper the on signal. Very handy. I solved that for now with 2 dummy devices and some json magic.
But I now have 3 devices in domoticz for each physical one. I would like to clean that up a bit.
Bert
Joep123
Post by Joep123 » Thursday 15 November 2018 23:15
With a RFXCom the D026 sensor shows up as just 1 device.
Users browsing this forum: Google [Bot] and 4 guests
