Selectplus doorchime
gwabber
Domoticz version: 3.8153
Post by gwabber » Saturday 02 September 2017 14:40
Hi!
I'm new at this forum, so i don't know if this is the right section to put this question, so correct me if i'm wrong.
I recently bought the RFXCOM433E transceiver for my windows 7 server with domoticz installed. It works like a charm with the Impuls and Domoticz switches and i recently connected a KaKu doorbell CDB-6500 successfully.
Now i bought the Selectplus 200689103 door chime at 'action' and i want to use the ringer to make a sound (i don't want to use the switch) but i can't get it to connect to domoticz. Does anyone have experience with this?
Thanks in advance!
mikeoo
Target OS: Raspberry Pi
Re: Selectplus doorchime
Post by mikeoo » Saturday 02 September 2017 15:26
Mabye this would help you
viewtopic.php?t=11952
gwabber
Post by gwabber » Saturday 02 September 2017 20:09
Hey Mikeoo,
thanks for your reply! i've already read the topic, but it seems that my rfxcom and/or domoticz won't see the devices. So far i had no problem connecting other devices.
mikeoo
Post by mikeoo » Sunday 03 September 2017 7:28
Did you activate the right protocol for the RFXCom (viewtopic.php?t=11952#p87821) .
When the protocol is not activated it would not find the devices for that type.
Read manual because you cant activate all protocols the same time.
Then in setting (Domotics) click on Accept new Hardware Devices (Allow for 5 min)
If that not working connect the RFXcom to your computer and run RFXmngr (Windows program) you can download on http://www.rfxcom.com/WebRoot/StoreNL2/ ... rSetup.exe
Try to play with the settings of RFXmngr to see if you see something when you press the doorbell.
Try to update the RFXCom to te latests firmware also.
If nothings works send an email to RFXCom. They have great support and the can help to see what's wrong.
gwabber
Post by gwabber » Sunday 03 September 2017 11:49
Thanks for your reply, i'm going to play with the settings. I'll let you know when i've got it to work!
gwabber
Post by gwabber » Sunday 03 September 2017 15:27
I've activated the select plus/ByronSX protocol in the RFXManager. I was able to connect the pushbutton, but i still can't connect the chime itself. It does not have a learning function and i can't figure out what to do.
Eddiever
Domoticz version: V4.9700
Post by Eddiever » Sunday 03 September 2017 16:13
It is the pushbutton which works with Domoticz. Not the chime itself. If you have the doorbell in Domoticz and activate that switch, if everything is fine the doorbell will ring.
RPi 2B with Domoticz and cam module RPi 3 with cam module
1 rftxtrx433E module 1 solar-edge SE-3500
1 Sonoff Touch 3 Sonoff wifi swithes 6 kaku modules
gwabber
Post by gwabber » Sunday 03 September 2017 16:44
Hi Eddiever,
I got it now. I've tested it and it works fine! Thank you!
sander815
Post by sander815 » Tuesday 25 September 2018 14:43
i bought this doorbell a year ago, and today i wanted to use it.
But my rfx433e doesn't recognize it. Doorbell is working normally, i saw the protocol appear once in rfxmngr, but that was only once.
Other 433 mhz devices work ok, but this one i cannot connect it to domoticz.
I have enabled both lighting 4 and byron, allowed new hardware, but nothing. Only timeout
