error while loading shared libraries: libudev.so.1:
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
marcel_dj
Target OS: Raspberry Pi
Post by marcel_dj » Wednesday 30 August 2017 9:32
I have the following error after installing the latest beta:
[....] Restarting Domoticz Home Automation System: domoticz/home/pi/domoticz/domoticz: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
I can see that in 2016 the same issue occured but the sollutions then mentioned did not help.
Version : latest Beta
Platform : Raspberry / Jessy
Plugin/Hardware : RFXCOM and MySensors
jackisidore
Re: error while loading shared libraries: libudev.so.1:
Post by jackisidore » Wednesday 30 August 2017 10:52
I have the same issue after upgrading yesterday
jackisidore
Post by jackisidore » Wednesday 30 August 2017 11:11
./updaterelease worked for me. I'll wait with a new beta until this is solved.
Oxyd
Post by Oxyd » Wednesday 30 August 2017 11:33
Same problem for me.
Backswitch to release and working again :roll:
marcel_dj
Post by marcel_dj » Wednesday 30 August 2017 14:30
It works after ./updaterelease for now I'm up and running.
bickel
Post by bickel » Wednesday 30 August 2017 15:44
Today i upgraded to 8373 and got the same issue which brought me to this article.
Same workaround also works for me..thanks for that.
roblom
Post by roblom » Thursday 31 August 2017 8:26
Same error here. Got 100+ mails from monit....
niki_lauda
Post by niki_lauda » Thursday 31 August 2017 16:43
+1
Platform : Raspberry / Wheezy
Last edited by niki_lauda on Friday 01 September 2017 11:48, edited 1 time in total.
danjardmathieu
Post by danjardmathieu » Thursday 31 August 2017 18:53
+1
Same issue
Hope the new beta will fix the problem soon ... :-| :roll:
kurniawan77
Post by kurniawan77 » Friday 01 September 2017 10:33
The same here....
pi@raspberrypi ~ $ sudo service domoticz.sh status
[FAIL] domoticz is not running ... failed!
pi@raspberrypi ~ $ sudo service domoticz.sh start
pi@raspberrypi ~ $ ^C
pi@raspberrypi ~ $ sudo find / -name "libudev.so*"
/lib/arm-linux-gnueabihf/libudev.so.0
/lib/arm-linux-gnueabihf/libudev.so.0.13.0
pi@raspberrypi ~ $  sudo find / -name "libudev.so.1"
pi@raspberrypi ~ $
When searching for libudev.so.1, it doesn't seem to exist.
kurniawan77
Post by kurniawan77 » Friday 01 September 2017 14:54
gordonb3 wrote:Are you sure you are running Jessie?
This libudev version seems rather old - like Wheezy old. I think Jessie should have libudev1 package installed which will provide the correct library.
Yes, running wheezy indeed. Do you have any advice? Running on a pi2 b+. Installed Domoticz 2 or 3 years ago from an SD image provided on the Domoticz website. Once in a while I do update and upgrade and have always updated Domoticz.
Sent from my Nexus 6P using Tapatalk
danjardmathieu
Post by danjardmathieu » Friday 01 September 2017 14:56
I was under Wheezzy wih the issue then i update/upgrade to jessie, no more problem now.
Solution, upgrade to jessie :D
kurniawan77
Post by kurniawan77 » Friday 01 September 2017 16:11
gordonb3 wrote:Yes, or as this appears to be bound to zwave support: build from source without it (provided you do not need zwave support)
I need zwave. So I have to upgrade to Jessy seems to be the solution. Any tips on that?
niki_lauda
Post by niki_lauda » Friday 01 September 2017 18:38
Which steps to upgrade Wheezy-> Jessie? Have you a link that worked for your Domoticz sD?
kurniawan77
Post by kurniawan77 » Friday 01 September 2017 19:27
gordonb3 wrote:May still try. Of course in that case you will need to get the openzwave library as well. Can't tell if there are any version dependencies though, but otherwise it should compile okay with the older libraries ( run cmake with `-DUSE_STATIC_OPENZWAVE=NO` )
Hmmmm, I'm not so familiar with that. Could you guide me? Or someone else?
jvdz
Domoticz version: Stable
Post by jvdz » Friday 01 September 2017 19:54
I have followed this upgrade process on both an RPI2 and RPI3 with an original Domoticz SD image after making n full image of the SDCARD before the upgrade process: https://raspberrypi.stackexchange.com/q ... ssie#27859
Both are working fine for a couple of months.
Jos
roblom
Post by roblom » Saturday 02 September 2017 13:03
Can someone of the dev team confirm that the latest beta will not be running on wheezy anymore. And if so, is this temporary or is it mandatory to update to Jessie?
Derik
Post by Derik » Sunday 03 September 2017 9:47
do have the same error to....
grrrr
Only go back to a release version from a Beta, can corrupt you DB...
So i hope there is a solution ....
Anyone?
a3vd
Post by a3vd » Sunday 03 September 2017 20:11
Same problem here on my pi's with domoticz latest beta crashed all systems.
Raspberry B / Raspberry B+ / Raspberry 2 / Raspberry 3 / Raspberry 3+
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12
Several Kaku switches/ Weather Underground / Razberry / 2 Everspring 142 dimmers
cyberclwn
Post by cyberclwn » Monday 04 September 2017 18:02
I had the same error after updating the beta to the latest.
But didn't want to go back to the stable so this is how i fixed it:
cd /lib/arm-linux-gnueabihf/
sudo cp libudev.so.0 libudev.so.1
btw: USE AT OWN RISK!!
And remember to remove the file after it is fixed in the beta.
This is only a temporary fix, and i am not sure if there are other problems this may introduce.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
Users browsing this forum: Google [Bot] and 5 guests
