Darksky http-error after update?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Lichtschilder
Target OS: Raspberry Pi
Post by Lichtschilder » Saturday 26 August 2017 18:03
Version: 3.8367
Build Hash: 7885798f
Compile Date: 2017-08-26 08:26:46
Uptime: 1 Uren, 28 Minuten, 40 Seconden
hardware Raspberry PI 3
hi all,
i updated my Domoticz to the latest version, since then my darksky seems to reject reading http information:
from the promblem log:
2017-08-26 16:29:08.687 Error: DarkSky: Error getting http data!.
2017-08-26 16:34:08.805 Error: DarkSky: Error getting http data!.
2017-08-26 16:39:08.912 Error: DarkSky: Error getting http data!.
2017-08-26 16:44:09.027 Error: DarkSky: Error getting http data!.
2017-08-26 16:49:09.145 Error: DarkSky: Error getting http data!.
2017-08-26 16:54:09.263 Error: DarkSky: Error getting http data!.
2017-08-26 16:59:09.374 Error: DarkSky: Error getting http data!.
2017-08-26 17:04:09.496 Error: DarkSky: Error getting http data!.
2017-08-26 17:09:09.612 Error: DarkSky: Error getting http data!.
2017-08-26 17:14:09.733 Error: DarkSky: Error getting http data!.
2017-08-26 17:19:09.868 Error: DarkSky: Error getting http data!.
2017-08-26 17:24:09.975 Error: DarkSky: Error getting http data!.
2017-08-26 17:29:10.084 Error: DarkSky: Error getting http data!.
2017-08-26 17:34:10.204 Error: DarkSky: Error getting http data!.
2017-08-26 17:39:10.313 Error: DarkSky: Error getting http data!.
2017-08-26 17:39:25.419 Error: DarkSky: Error getting http data!.
2017-08-26 17:40:50.514 Error: DarkSky: Error getting http data!.
2017-08-26 17:45:50.623 Error: DarkSky: Error getting http data!.
2017-08-26 17:50:50.743 Error: DarkSky: Error getting http data!.
2017-08-26 17:54:08.848 Error: DarkSky: Error getting http data!.
Done:
restarted my domoticz
logged in in darksky website: checked the status: all ok
used the test-page under the API-key, got a response with the data
changed the darksky-api key
tested the link from darksky directly: i get a working response again, however my domoticz still complains the http data is in error.
tips to do some more tests are welcome.
Lichtschilder
Re: Darksky http-error after update?
Post by Lichtschilder » Saturday 26 August 2017 18:10
oops.. i thought i updated to a stable release..
used the ./updaterelease all worked again.
@mods please do close this one
niki_lauda
Post by niki_lauda » Saturday 26 August 2017 19:17
Version: 3.8367
Platform: RPI
Same error here since previous beta release.
SweetPants
Domoticz version: V4.9999
Post by SweetPants » Saturday 26 August 2017 19:38
Version: 3.8367
Platform: RPI
This has been reported already many times, there is something wrong with HTTP requests if you use image updates. If you compile from source all works.
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
niki_lauda
Post by niki_lauda » Saturday 26 August 2017 20:18
If I issue ./updaterelease there is no error.
If I issue a ./updatebata
2017-08-26 20:13:23.233 Incoming connection from: 10.0.0.3
2017-08-26 20:13:31.141 Error: DarkSky: Error getting http data!.
2017-08-26 20:13:34.292 (Zonnecellen) General/Percentage (Rendement)
2017-08-26 20:13:34.425 (Wunderground Bossebaan) Temp + Humidity + Baro (Baro Bossebaan )
2017-08-26 20:13:34.523 (Zonnecellen) General/Voltage (Voltage)
2017-08-26 20:13:34.588 (Wunderground Bossebaan) Wind (Temp Bossebaan)
So back to stable
chatainsim
Domoticz version: v3.9439
Post by chatainsim » Tuesday 29 August 2017 16:02
Same error with beta v3.8341
2017-08-28 17:37:22.779 Error: DarkSky: Error getting http data!.
2017-08-28 23:48:06.496 Error: DarkSky: Error getting http data!.
2017-08-29 10:34:28.771 Error: DarkSky: Error getting http data!.
2017-08-29 12:19:43.194 Error: DarkSky: Error getting http data!.
2017-08-29 13:44:54.281 Error: DarkSky: Error getting http data!.
2017-08-29 15:00:03.397 Error: DarkSky: Error getting http data!.
2017-08-29 15:05:04.449 Error: DarkSky: Error getting http data!.
2017-08-29 15:25:07.626 Error: DarkSky: Error getting http data!.
chatainsim
Post by chatainsim » Friday 15 September 2017 9:44
Still a lots of errors:
Edit: Forget about it, Darksky API seems down ...
Last edited by chatainsim on Friday 15 September 2017 12:02, edited 1 time in total.
emme
Domoticz version: latest
Post by emme » Friday 15 September 2017 10:00
update to leatest beta (8394) but consider that python framework is disabled... that means no events, no plugins ;)
or move to stable with ./updaterelease
"We always done this way"
jannl
Post by jannl » Friday 15 September 2017 10:50
You mean no python events, 'normal' events still work. At least for me
alexbi
Post by alexbi » Friday 15 September 2017 14:18
same thing for me ! help please
2017-09-15 05:55:02.826 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 05:55:13.370 Error: DarkSky: Error getting http data!.
2017-09-15 06:11:30.259 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 06:11:44.688 Error: DarkSky: Error getting http data!.
2017-09-15 06:24:00.422 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 06:24:15.322 Error: DarkSky: Error getting http data!.
2017-09-15 06:30:30.539 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 06:30:45.353 Error: DarkSky: Error getting http data!.
2017-09-15 06:37:00.772 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 06:37:15.383 Error: DarkSky: Error getting http data!.
2017-09-15 06:43:30.899 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 06:43:45.423 Error: DarkSky: Error getting http data!.
2017-09-15 06:50:02.267 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 06:50:15.465 Error: DarkSky: Error getting http data!.
2017-09-15 06:56:30.259 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 06:56:45.497 Error: DarkSky: Error getting http data!.
2017-09-15 07:03:00.286 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:03:15.530 Error: DarkSky: Error getting http data!.
2017-09-15 07:09:30.371 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:09:45.563 Error: DarkSky: Error getting http data!.
2017-09-15 07:16:00.435 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:16:15.598 Error: DarkSky: Error getting http data!.
2017-09-15 07:22:30.606 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:22:45.629 Error: DarkSky: Error getting http data!.
2017-09-15 07:29:00.686 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:29:15.660 Error: DarkSky: Error getting http data!.
2017-09-15 07:35:30.816 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:35:45.694 Error: DarkSky: Error getting http data!.
2017-09-15 07:42:00.128 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:42:15.724 Error: DarkSky: Error getting http data!.
2017-09-15 07:48:30.912 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:48:45.755 Error: DarkSky: Error getting http data!.
2017-09-15 07:55:02.971 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 07:55:15.786 Error: DarkSky: Error getting http data!.
2017-09-15 08:01:30.192 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 08:01:45.817 Error: DarkSky: Error getting http data!.
2017-09-15 08:06:46.376 Error: DarkSky: Error getting http data!.
2017-09-15 08:12:46.934 Error: DarkSky: Error getting http data!.
2017-09-15 08:17:47.508 Error: DarkSky: Error getting http data!.
2017-09-15 08:22:48.073 Error: DarkSky: Error getting http data!.
2017-09-15 08:28:48.659 Error: DarkSky: Error getting http data!.
2017-09-15 08:29:00.124 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 08:34:49.214 Error: DarkSky: Error getting http data!.
2017-09-15 08:39:49.769 Error: DarkSky: Error getting http data!.
2017-09-15 08:45:50.334 Error: DarkSky: Error getting http data!.
2017-09-15 08:46:00.624 Error: meteo hardware (6) thread seems to have ended unexpectedly
2017-09-15 08:50:50.890 Error: DarkSky: Error getting http data!.
2017-09-15 08:55:51.456 Error: DarkSky: Error getting http data!.
2017-09-15 09:00:52.031 Error: DarkSky: Error getting http data!.
2017-09-15 09:05:52.591 Error: DarkSky: Error getting http data!.
2017-09-15 09:10:53.152 Error: DarkSky: Error getting http data!.
2017-09-15 09:15:53.736 Error: DarkSky: Error getting http data!.
2017-09-15 09:20:54.309 Error: DarkSky: Error getting http data!.
2017-09-15 09:25:54.882 Error: DarkSky: Error getting http data!.
2017-09-15 09:30:55.447 Error: DarkSky: Error getting http data!.
Egregius
Post by Egregius » Friday 15 September 2017 14:24
This is not a Domoticz issue. There are problems at Darksky.
I pull the data myself with PHP and about half of my request result in error.
gerardosamara
Domoticz version: 4.9701
Post by gerardosamara » Tuesday 23 January 2018 19:31
Beta 8823
RPI3
Description : Still the issue
Doc used to setup ... https://www.domoticz.com/wiki/Weather_f ... n_Domoticz
2018-01-23 16:04:40.177 DarkSky: Started...
2018-01-23 16:04:47.847 DarkSky: Worker stopped...
2018-01-23 16:04:55.609 DarkSky: Worker stopped...
2018-01-23 16:04:56.414 Error: DarkSky: Error getting http data!.
2018-01-23 16:10:02.746 Error: DarkSky: Error getting http data!.
2018-01-23 16:15:09.069 Error: DarkSky: Error getting http data!.
2018-01-23 16:20:15.584 Error: DarkSky: Error getting http data!.
2018-01-23 16:25:22.901 Error: DarkSky: Error getting http data!.
Using the Forecast request " https://api.darksky.net/forecast/[key]/ ... [longitude] " , I see that DarkSky answers correctly.
Is it a known issue ?
Thank you
Last edited by gerardosamara on Sunday 10 June 2018 18:02, edited 1 time in total.
Domoticz Remote server RPi3B+ & WD PI Drive Beta V4.9701 , Domoticz Slave Beta RPI3B V4.9701 + App Android Domoticz Lite V0.1.452 & Imperihome Pro V40107
Zwave+ Z Stick Z90 USB dongle + USB300 Ocean GW dongle
gerardosamara
Post by gerardosamara » Sunday 10 June 2018 18:00
Beta 8823
RPI3
Thank you
I came back on this problem ( Beta 8342 ) and setup the Darsky hardware again
Same problem "Error: DarkSky: Error getting http data!."
2018-06-10 09:46:19.370 New sensors allowed for 5 minutes...
2018-06-10 09:47:11.211 DarkSky: Started...
2018-06-10 09:47:21.749 Error: DarkSky: Error getting http data!.
I noticed that the Darksky devices are not created ( Accept new hardware during 5 minutes = ON )
Any known issue on the devices creation ?
Thank you
SweetPants
Post by SweetPants » Monday 11 June 2018 12:41
Thank you
I see you are on Beta? Then upgrade to the latest Beta version. I just tested this with V3.9625 and works fine.
gerardosamara
Post by gerardosamara » Monday 11 June 2018 20:04
Thank you for your reply
I have upgraded to V3.9625 and then :
- suppressed the hardware device Darksky
- Turn on "Accept new hardware during 5 minutes"
- Create again the Darksky hardware with the API key and location
But unfortunaltely the same issue : No devives created and folowing errors
2018-06-11 11:55:57.942 Status: New sensors allowed for 5 minutes...
2018-06-11 11:56:11.671 Status: DarkSky: Worker stopped...
2018-06-11 11:56:22.891 Status: DarkSky: Started...
2018-06-11 11:56:33.398 Error: DarkSky: Error getting http data!.
2018-06-11 12:00:58.467 Status: Receiving of new sensors disabled!...
2018-06-11 12:01:33.923 Error: DarkSky: Error getting http data!.
=> I do not know what i am doing wrong
Last edited by gerardosamara on Monday 11 June 2018 20:21, edited 1 time in total.
SweetPants
Post by SweetPants » Monday 11 June 2018 20:18
Have you tested your API key and location using a direct API call like:
https://api.darksky.net/forecast/<apikey>/<lon,lat>
gerardosamara
Post by gerardosamara » Tuesday 12 June 2018 0:40
The Darsky API test worked and then following the Darsky hardware creation , the Darsky devices have been created and everything worked.
No explaination of the issue !
point closed
SweetPants
Post by SweetPants » Monday 18 June 2018 18:47
point closed
Can you mark it closed?
gerardosamara
CLOSED : Darksky http-error after update?
Post by gerardosamara » Tuesday 19 June 2018 17:30
Hi ,
I cannot close the thread as I have not created it.
SweetPants
Post by SweetPants » Wednesday 20 June 2018 11:10
Version: 3.8367
hi all,
Done:
Users browsing this forum: No registered users and 6 guests
