Domoboard - Windows installation
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderator: wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
JvdBosch
Post by JvdBosch » Friday 25 August 2017 9:17
Could anybody give me some pointers on installing domoboard on a Windows based Domoticz installation?
Henrik
Re: Domoboard - Windows installation
Post by Henrik » Tuesday 12 December 2017 14:39
I would like to know too.
Latest stable v.3.8153 on Windows 10
squandor
Target OS: Raspberry Pi
Domoticz version: 3.5837
Post by squandor » Friday 23 March 2018 11:29
Hi Henrik,
Sorry for the late reply, but its pretty straight forward.
You can clone the github page and edit de config and set de domoticz url in the config.
When that has been done you can run domoboard by the command: python server.py -c configuration.conf -d
It should work like that
moengiant
Post by moengiant » Friday 19 October 2018 18:04
If you want it to be windowless - no command line window open - rename the script to server.pyw and then run it. Use the cd command to go into the directory where you have the script and then run python server.pyw -c configuration.conf -d
This all assumes you already have installed python on your Windows box - hope this helps.
I'd rather have a bottle in front of me than a frontal lobotomy
