Python plugin: Xiaomi Mi Robot Vacuum Topic is solved
DAVIZINHO
Target OS: Raspberry Pi
Re: Python plugin: Xiaomi Mi Robot Vacuum
Post by DAVIZINHO » Monday 27 August 2018 11:51
dlefol wrote:
Monday 27 August 2018 11:40
As far as I know there is no sensor in the dustbin of the vacuum cleaner so it s not possible to get the information of how full the dustbin is.
i thing so.
the mihome app send notificacion with a "timer" no more :-(
dagasoft
Post by dagasoft » Tuesday 28 August 2018 17:51
So how does Mi Home notify about cleaning the dust bin?
I get notifications that say "you have to empty the dust bin".
dagasoft
Post by dagasoft » Tuesday 28 August 2018 20:50
i thing so.
Thank you for your reply. So I think I will implement notifications through a timer in domoticz to remember to clean the dust bin after some hours of use. I see in the python script that there is an option to get all time cleaned, do you know if we are able to read it from domoticz?
Thanks.
scriptedbackdoor
Domoticz version: Stable
Post by scriptedbackdoor » Tuesday 02 October 2018 6:49
How can it be used with iRoomba robocouum?
wouterlet
Post by wouterlet » Thursday 18 October 2018 14:26
Philos31 wrote:
Monday 13 August 2018 12:23
Is there someone who has this plugin working in domoticz on Synology Nas?
I have tried but am missing to many things, maybe someone could help?
I'm looking for this also. I found the manuals but there is no "apt-get" available on my synology. It seemed Debian Chroot did this in the past, but isn't available anymore. Who knows a solution?
misko903
Domoticz version: Latest
Post by misko903 » Thursday 08 November 2018 14:33
I got closer with your posts, but I have ended here:
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mi-robot-vacuum $ pip3 install -r pip_req.txt
after few installs come this message:
Using cached https://files.pythonhosted.org/packages/6b/88/48dbe88b10098f98acef33218763c5630b0081c7fd0849ab4793b1e9b6d3/zeroconf-0.19.1-py2.py3-none-any.whl
Installing collected packages: android-backup, asn1crypto, attrs, pycparser, cffi, click, construct, six, idna, cryptography, enum-compat, greenlet, gevent, msgpack-python, netifaces, pretty-cron, pycrypto, pytz, typing, zeroconf, python-miio
Could not install packages due to an EnvironmentError: [Errno 13] Prístup odmietnutý: '/home/pi/domoticz/plugins/xiaomi-mi-robot-vacuum/.env/lib/python3.5/site-packages/android_backup-0.1.0.dist-info'
Consider using the `--user` option or check the permissions.
then i was trying
pi@raspberrypi:~/domoticz/plugins/xiaomi-mi-robot-vacuum/.env/lib/python3.5/site-packages $ ls
and saw that the files your shell listed is much smaller than yours:
easy_install.py  pip-18.1.dist-info  __pycache__  setuptools-40.5.0.dist-info  wheel-0.32.2.dist-info
pip              pkg_resources       setuptools   wheel
what i am doing wrong?
Thanks for replies!
Jheronymus wrote:
Saturday 02 June 2018 15:09
Jheronymus wrote:
Thursday 17 May 2018 16:56
Geitje wrote:
Tuesday 06 March 2018 2:29
I already found out.
See this post: http://www.domoticz.com/forum/viewtopic ... ck#p163889.
Note: insert:
sys.path.append('/usr/local/lib/python3.5/site-packages')
after "import domoticz" in the plugin.py file.
so WITHOUT the and /b codes mentioned in the post, if you insert them too it does nog work I found out!
Hi, I have a similar problem, but the solution didn't work for me.
When I try to add the line, domoticz won't boot (ie. the browser keeps indicating domoticz is offline or not available)
The error in the domoticz log (without the line)
Error: (xiaomi-mi-robot-vacuum) failed to load 'plugin.py', Python Path used was '/home/jeroen/domoticz/plugins/xiaomi-robot/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
Error: (Robottest) Module Import failed, exception: 'ImportError'
Error: (Robottest) Module Import failed: ' Name: msgpack'
I've added this:
sys.path.append('/usr/local/lib/python3.4/dist-packages')
FYI:
I get this response for searching for msgpack:
jeroen@Domoticz:~ $ sudo find / -name msgpack*
[sudo] password for jeroen:
/home/jeroen/domoticz/plugins/xiaomi-robot/.env/lib/python3.4/site-packages/pip/_vendor/msgpack
/home/jeroen/.cache/pip/wheels/62/f3/0d/f77f20fce259496b053d6c0dc0eea7114527cf0a7da115a980/msgpack_python-0.4.8-cp34-cp34m-linux_armv6l.whl
/usr/local/lib/python3.4/dist-packages/msgpack_python-0.4.8-py3.4.egg-info
I've no idea how to debug this at this point. When I run the test script:
jeroen@Domoticz:~/domoticz/plugins/xiaomi-robot $ sudo ./test.py
test: python modules path: ././.env/lib/python3.4/site-packages
test: trying connect to 127.0.0.1:22222
File "./test.py", line 22, in <module>
client = socket.create_connection((args.host, args.port))
File "/usr/lib/python3.4/socket.py", line 509, in create_connection
raise err
File "/usr/lib/python3.4/socket.py", line 500, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
But if I start the server from the command line and run the test.py from another console, I can get valid output.
sudo python3 miio_server.py 192.168.1.43 token
server: Starting server on 127.0.0.1 22222
server: connected ('127.0.0.1', 42656)
server: got socket msg: ['status']
server: vac result {'clean_area': 62.4725, 'error': None, 'battery': 100, 'cmd': 'status', 'state_code': 8, 'clean_seconds': 4418, 'fan_level': 60}
server: send reply ('127.0.0.1', 42656)
server: closed connection ('127.0.0.1', 42656)
So, I fixed my earlier problem. I noticed I was using sudo a lot. And you have to be carefull with that while in the virtualenv. As you can see in the logs posted before, the msgpack was installed, but outside the virtual env. /usr/local/lib/python3.4/dist-packages/msgpack
You can test it like this:
> which python
/usr/bin/python
> which pip3
/usr/bin/pip3
>source .env/bin/activate
>which python3
/home/jeroen/domoticz/plugins/xiaomi-mirobot/.env/bin/python3
>which pip3
/home/jeroen/domoticz/plugins/xiaomi-mirobot/.env/bin/pip3
>sudo which pip3
/usr/bin/pip3                <= sudo points outside the virtualenv
You might also upgrade setuptools in the virtualenv.
then just run the pip3 install -r pip_req.txt command
All should be fine. Close the virtualenv with
>deactivate
Now you can actualy see the packages in the virtualenv:
>~/domoticz/plugins/xiaomi-mirobot/.env/lib/python3.5/site-packages $ ls
Crypto                                            msgpack
__pycache__                                       msgpack_python-0.4.8.dist-info
_cffi_backend.cpython-35m-arm-linux-gnueabihf.so  netifaces-0.10.6.dist-info
android_backup                                    netifaces.cpython-35m-arm-linux-gnueabihf.so
android_backup-0.1.0.dist-info                    pip
asn1crypto                                        pip-10.0.1.dist-info
asn1crypto-0.23.0.dist-info                       pkg_resources
attr                                              pretty_cron
attrs-17.2.0.dist-info                            pretty_cron-1.0.2.dist-info
cffi                                              psutil
cffi-1.11.2.dist-info                             psutil-5.4.5.dist-info
click                                             pycparser
click-6.7.dist-info                               pycparser-2.18.dist-info
construct                                         pycrypto-2.6.1.dist-info
construct-2.8.16.dist-info                        python_miio-0.3.1.dist-info
cryptography                                      pytz
cryptography-2.1.3.dist-info                      pytz-2017.3.dist-info
easy_install.py                                   setuptools
enum_compat-0.0.2.dist-info                       setuptools-39.2.0.dist-info
gevent                                            six-1.11.0.dist-info
gevent-1.2.2.dist-info                            six.py
greenlet-0.4.12.dist-info                         typing-3.6.2.dist-info
greenlet.cpython-35m-arm-linux-gnueabihf.so       typing.py
idna                                              wheel
idna-2.6.dist-info                                wheel-0.31.1.dist-info
miio                                              zeroconf-0.19.1.dist-info
mirobo                                            zeroconf.py
misko903
Post by misko903 » Friday 09 November 2018 23:17
update:
firing:
pi@raspberrypi:~/domoticz/plugins/xiaomi-mi-robot-vacuum $ virtualenv -p python3 .env
caused:
Already using interpreter /usr/bin/python3
Using base prefix '/usr'
New python executable in /home/pi/domoticz/plugins/xiaomi-mi-robot-vacuum/.env/bin/python3
  File "/usr/local/bin/virtualenv", line 11, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 762, in main
    symlink=options.symlink,
  File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 998, in create_environment
    install_python(home_dir, lib_dir, inc_dir, bin_dir, site_packages=site_packages, clear=clear, symlink=symlink)
  File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 1318, in install_python
    make_exe(py_executable)
  File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 449, in make_exe
    os.chmod(fn, newmode)
PermissionError: [Errno 1] Operation not permitted: '/home/pi/domoticz/plugins/xiaomi-mi-robot-vacuum/.env/bin/python3'
tried to uninstall virtual env with
sudo pip uninstall virtualenv
and installed it back
but result is the same.
>sudo which pip3
/usr/bin/pip3
should I and if yes, how I can uninstall pip3 from usr/bin?
EDIT:
i have made something:
> sudo which pip3
/usr/local/bin/pip3
nothing else is changed, still the same virtualenv errors.
misko903
Post by misko903 » Sunday 11 November 2018 0:02
installed it new from scratch.
everything works, except:
pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ sudo ./test.py
test: python modules path: ././.env/lib/python3.5/site-packages
  File "/usr/lib/python3.5/socket.py", line 712, in create_connection
    raise err
  File "/usr/lib/python3.5/socket.py", line 703, in create_connection
    sock.connect(sa)
after that,
pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ sudo service miio_server stop
pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ sudo ./miio_server.py IP token --host 127.0.0.1 --port 22222
  File "./miio_server.py", line 18, in <module>
    from miio import Vacuum, DeviceException
  File "/usr/local/lib/python3.5/dist-packages/miio/__init__.py", line 2, in <module>
    from miio.airconditioningcompanion import AirConditioningCompanion
  File "/usr/local/lib/python3.5/dist-packages/miio/airconditioningcompanion.py", line 8, in <module>
    from .device import Device, DeviceException
  File "/usr/local/lib/python3.5/dist-packages/miio/device.py", line 16, in <module>
    from .protocol import Message
  File "/usr/local/lib/python3.5/dist-packages/miio/protocol.py", line 190, in <module>
    Const(0x2131, Int16ub),
  File "/usr/local/lib/python3.5/dist-packages/construct/core.py", line 1930, in __init__
    super(Const, self).__init__(subcon)
  File "/usr/local/lib/python3.5/dist-packages/construct/core.py", line 288, in __init__
    raise TypeError("subcon should be a Construct field")
TypeError: subcon should be a Construct field
and there I have ended.
Stimpy68
Post by Stimpy68 » Monday 19 November 2018 11:37
Can't seem to find it anywhere, how do you update the miirobo part?
misko903
Post by misko903 » Thursday 29 November 2018 22:44
Stimpy68 wrote:Can't seem to find it anywhere, how do you update the miirobo part?
I am just testing by the sequence given in the manual...
What should I try to do?
Stimpy68
Post by Stimpy68 » Sunday 02 December 2018 15:04
I already found it, just execute
sudo pip3 install python-miio
It updates the python miio part if you already installed it earlier. I was missing a few commands in the older version.
blackmart12
Post by blackmart12 » Friday 14 December 2018 14:12
:arrow: I think deebot is far better than Xiaomi Mi Robot Vacuum :!:
Users browsing this forum: midomot, rgroothuis and 3 guests
