Python plugin: Xiaomi Mi Robot Vacuum Topic is solved
Geitje
Target OS: Raspberry Pi
Re: Python plugin: Xiaomi Mi Robot Vacuum
Post by Geitje » Thursday 01 March 2018 23:46
Hi, I have already reinstalled everything, but keep getting this error:
2018-03-01 22:37:48.027 Error: (xiaomi-mi-robot-vacuum) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/xiaomi-mirobot/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-03-01 22:37:48.027 Error: (Robotstofzuiger Xiaomi) Module Import failed, exception: 'ImportError'
2018-03-01 22:37:48.027 Error: (Robotstofzuiger Xiaomi) Module Import failed: ' Name: msgpack'
2018-03-01 22:37:48.027 Error: (Robotstofzuiger Xiaomi) Error Line details not available.
I know my Python path is different. I I type: "which python3" I get: /home/pi/domoticz/plugins/xiaomi-mirobot/.env/bin/python3
I pasted this path in miio_server.py. But I keep getting this error! Hop someone can help....
Any ideas? I'm on Stretch, Domoticz newest beta.
Domoticz latest beta, on Raspberry Pi
Geitje
Post by Geitje » Tuesday 06 March 2018 2:29
I already found out.
See this post: http://www.domoticz.com/forum/viewtopic ... ck#p163889.
Note: insert:
sys.path.append('/usr/local/lib/python3.5/site-packages')
after "import domoticz" in the plugin.py file.
so WITHOUT the and /b codes mentioned in the post, if you insert them too it does nog work I found out!
DAVIZINHO
Post by DAVIZINHO » Saturday 24 March 2018 22:46
its posible to obtain the map afther the vacuum finish the cleaning?
Whuzz
Post by Whuzz » Sunday 25 March 2018 16:03
I have two Mii Vacuums at home (and a Neato, but that's not a connected one). The server config in the plugin only allows for one set of IP + Token... Is there a way (other than me rewriting the code ;) ) to support two vacuums?
MarcE85
Post by MarcE85 » Monday 26 March 2018 11:33
Hey, i get the following error messages.
2018-03-26 11:30:09.214 (Staubsauger) Calling message handler 'onHeartbeat'.
2018-03-26 11:30:09.215 Error: (Staubsauger) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'Connecting''.
2018-03-26 11:30:09.215 Error: (Staubsauger) ----> Line 383 in /home/pi/domoticz/plugins/xiaomi-mirobot/plugin.py, function onHeartbeat
2018-03-26 11:30:09.215 Error: (Staubsauger) ----> Line 289 in /home/pi/domoticz/plugins/xiaomi-mirobot/plugin.py, function onHeartbeat
Any ideas on this?
Regards Marc
remb0
Post by remb0 » Tuesday 27 March 2018 11:59
how nice :) because of this great plugin!!
All Domoticz compatible products at shop: https://www.domoticz.com/wiki/Compatibl ... n_gearbest
StasDemydiuk
Post by StasDemydiuk » Saturday 14 April 2018 11:26
Guys, if anyone prefer using docker and its containers (such as me) I've created docker container with miio server for this plugin:
https://hub.docker.com/r/demydiuk/mirobot-miio-server/
Additionally have checked this plugin with Xiaomi Mi Robot, 2nd generation and it works well
gijsje
Domoticz version: Stable
Post by gijsje » Saturday 14 April 2018 16:16
I am trying to get this to work.
I have installed the latest beta domoticz on a pi
Did all the steps and it works, but only one time. :evil:
when i restart the pi the python script is gone from the list
when i test with sudo ./test.py i can still see the vacuum b but i can not select the vacuum from the hardware list.
It is still there from the first time it worked but the type is empty and the is no vacuum to select
The files are also still there
The deceives where created on the first try
After a reboot the type is not showing anymore
the files are still there
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
gijsje
Post by gijsje » Saturday 14 April 2018 16:20
This is the output i i run sudo ./test.py
pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ sudo ./test.py
test: python modules path: ././.env/lib/python3.5/site-packages
test: trying connect to 127.0.0.1:22222
test: sent request to server [status]
test: reading response...
test: got server reply {'error': None, 'state_code': 8, 'battery': 100, 'clean_seconds': 0, 'clean_area': 1.125, 'fan_level': 60, 'cmd': 'status'}
So it can see the vacuum only the plugin is not loading somehow
gijsje
Post by gijsje » Saturday 14 April 2018 17:19
Found it
There seems to be a function in settings to disable all plugins :D
whatisk
Domoticz version: 3.9224
Post by whatisk » Sunday 15 April 2018 10:13
I had the vacuum working fine in Domoticz on Ubuntu 16.04. I upgraded to Ubuntu 17.10 due to needing an updated version of Python for another app.
Everything is working fine except for the vacuum in Domoticz.
I have re-done the installation steps at: https://github.com/mrin/domoticz-mirobot-plugin
When running the test script I get the following:
test: python modules path: ././.env/lib/python3.6/site-packages
Traceback (most recent call last)
File "./test.py", line 22, in
client = socket.create_connection((args.host, args.port))
File "/usr/lib/python3.6/socket.py", line 724, in create_connection
raise err
File "/usr/lib/python3.6/socket.py", line 713, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
I saw a couple of pages back someone had a similar issue and so did what they suggested. Uninstall and reinstall python-miio. When I went to uninstall I got a message saying it wasn't installed. Once installed I then went through the steps again from the github page and received the same error as above.
If I do the manual test: sudo ./miio_server.py 192.168.1.15 xxxxxxxxxxxxxxxxxxxxxxxxxx --host 127.0.0.1 --port 22222 I get the following:
server: Starting server on 127.0.0.1 22222
server: connected ('127.0.0.1', 35486)
server: got socket msg: ['status']
server: vac result {'error': None, 'state_code': 8, 'battery': 100, 'fan_level': 60, 'clean_seconds': 0, 'clean_area': 0.0, 'cmd': 'status'}
server: send reply ('127.0.0.1', 35486)
Which seems to indicate the manual test is working without issue?
Hoping someone may be able to assist.
joostnl
Post by joostnl » Monday 16 April 2018 19:50
I try to install the plugin only after the following command i get two error i think:
Raspberry 2B
Wich python is really recommend? (I did all command from beginning and have allready 3.5 running if i'm correct)
virtualenv -p python3 .env
Error 1:
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ virtualenv -p python3 .env
Running virtualenv with interpreter /home/pi/domoticz/plugins/xiaomi-mirobot/.env/bin/python3
Please use the *system* python to run this script
  File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 2349, in <module>
    main()
  File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 712, in main
    symlink=options.symlink)
  File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 927, in create_environment
    site_packages=site_packages, clear=clear, symlink=symlink))
  File "/home/pi/domoticz/plugins/xiaomi-mirobot/.env/lib/python3.5/posixpath.py", line 357, in abspath
    if not isabs(path):
  File "/home/pi/domoticz/plugins/xiaomi-mirobot/.env/lib/python3.5/posixpath.py", line 64, in isabs
    return s.startswith(sep)
AttributeError: 'NoneType' object has no attribute 'startswith'
I'm not sure if a both is really an error but the next command gives an error. (I think because of above failing)
Tried:
pip3 install -r pip_req.txt
And
pip3 install gevent msgpack-python python-miio==0.3.1
Can someone point me the good direction im not an linux expert
Error:
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ pip3 install gevent msgpack-python python-miio==0.3.1
pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
Collecting gevent
  Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
  Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
  Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
  Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
  Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
  Could not fetch URL https://pypi.python.org/simple/gevent/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host='pypi.python.org', port=443): Max retries exceeded with url: /simple/gevent/ (Caused by SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)) - skipping
  Could not fetch URL https://www.piwheels.hostedpi.com/simple/gevent/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host='www.piwheels.hostedpi.com', port=443): Max retries exceeded with url: /simple/gevent/ (Caused by SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)) - skipping
  Could not find a version that satisfies the requirement gevent (from versions: )
No matching distribution found for gevent
andreaburlizzi
Domoticz version: 3.9389
Post by andreaburlizzi » Thursday 03 May 2018 21:41
Sorry for the noob question, but there is a way to use this plugin with a Windows 10 installation of domoticz?
corederoma82
Post by corederoma82 » Friday 11 May 2018 9:39
can you say me how are the compatible vacuum cleaner model?
molnaratti
Post by molnaratti » Friday 11 May 2018 22:01
RichardBokker wrote:
Wednesday 14 February 2018 11:37
I got the script working, but had to convert the Robot - state with tostring().
Here is my case-construction that i'm using.
-- Using TimeBetween script in main LUA script folder
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/script_time_TimeBetween.lua'
local TimeBetween = require('timebetween')
time = os.date("*t")
-- Possible state's of Robot Vacuum:  Charging / Paused / Cleaning / Waiting / Back to home / Sleeping
-- Selector witch Robot Vacuum:       Clean(10) / Home(20) / Spot(30) / Pauze(40) / Stop(50) / Find(60)
---- Variabele to use
-- StoffieState      (uservariable)
-- AtHome            (uservariable)
-- Stoffie - Control (device)
-- Stoffie - Status  (device)
local stoffie 			= 'Stoffie - Status'
--    print(otherdevices_svalues[stoffie] .. " dit is de actuele status")
-- Required to convert State to Stringvalue
StoffieStatus = tostring(otherdevices_svalues[stoffie]);
-- IDLE
if (uservariables['StoffieState'] == 'IDLE') then
    print ("Stoffie is idle");
    if timebetween("08:00","16:00") then   -- Run's only during day hours.
        if (uservariables['AtHome'] == 'NO') then -- Run's only when nobody is at home
        commandArray['SendNotification']='Stoffie is Starting'
        commandArray['Variable:StoffieState']='STARTING'
        -- Start Robot command, command send once.
        commandArray['Stoffie - Control'] = 'Set Level 10'
-- STARTING
if (uservariables['StoffieState'] == 'STARTING') then
    if StoffieStatus == 'Cleaning' then  -- If robot is cleaning, continu to next step
        commandArray['SendNotification']='Stoffie is Running'
        commandArray['Variable:StoffieState']='RUNNING'
    if timebetween("16:00","08:00") then  -- is program hangs, to executed state
        commandArray['Variable:StoffieState']='EXECUTED'
-- RUNNING
if (uservariables['StoffieState'] == 'RUNNING') then
    if StoffieStatus == 'Back to home' then  -- If robot is going back to home, continu to next step
        commandArray['SendNotification']='Stoffie is Stopping'
        commandArray['Variable:StoffieState']='STOPPING'
-- STOPPING
if (uservariables['StoffieState'] == 'STOPPING') then
    if StoffieStatus == 'Charging' then  -- if robot is Charging, continu to next step
        commandArray['SendNotification']='Stoffie is Executed'
        -- Stop Robot command, command send once.
        commandArray['Stoffie - Control'] = 'Set Level 50'
-- EXECUTED
if (uservariables['StoffieState'] == 'EXECUTED') then
    if timebetween("23:55","23:56") then   -- Runs only once a day. Reset at end of day.
        commandArray['SendNotification']='Stoffie going to Idle'
        commandArray['Variable:StoffieState']='IDLE'
Very good, thanks. You would share the time between.lua script?
Peggy
Post by Peggy » Saturday 12 May 2018 0:08
Same question here.
Furthermore I'd like to know if python-miio would work under windows.
corederoma82
Post by corederoma82 » Wednesday 16 May 2018 11:16
Somebody can answer me?
Jheronymus
Post by Jheronymus » Thursday 17 May 2018 16:56
Note: insert:
Hi, I have a similar problem, but the solution didn't work for me.
When I try to add the line, domoticz won't boot (ie. the browser keeps indicating domoticz is offline or not available)
The error in the domoticz log (without the line)
Error: (xiaomi-mi-robot-vacuum) failed to load 'plugin.py', Python Path used was '/home/jeroen/domoticz/plugins/xiaomi-robot/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
Error: (Robottest) Module Import failed, exception: 'ImportError'
Error: (Robottest) Module Import failed: ' Name: msgpack'
I've added this:
sys.path.append('/usr/local/lib/python3.4/dist-packages')
FYI:
I get this response for searching for msgpack:
jeroen@Domoticz:~ $ sudo find / -name msgpack*
[sudo] password for jeroen:
/home/jeroen/domoticz/plugins/xiaomi-robot/.env/lib/python3.4/site-packages/pip/_vendor/msgpack
/home/jeroen/.cache/pip/wheels/62/f3/0d/f77f20fce259496b053d6c0dc0eea7114527cf0a7da115a980/msgpack_python-0.4.8-cp34-cp34m-linux_armv6l.whl
/usr/local/lib/python3.4/dist-packages/msgpack_python-0.4.8-py3.4.egg-info
I've no idea how to debug this at this point. When I run the test script:
jeroen@Domoticz:~/domoticz/plugins/xiaomi-robot $ sudo ./test.py
test: python modules path: ././.env/lib/python3.4/site-packages
File "./test.py", line 22, in <module>
File "/usr/lib/python3.4/socket.py", line 509, in create_connection
raise err
File "/usr/lib/python3.4/socket.py", line 500, in create_connection
sock.connect(sa)
But if I start the server from the command line and run the test.py from another console, I can get valid output.
sudo python3 miio_server.py 192.168.1.43 token
server: connected ('127.0.0.1', 42656)
server: vac result {'clean_area': 62.4725, 'error': None, 'battery': 100, 'cmd': 'status', 'state_code': 8, 'clean_seconds': 4418, 'fan_level': 60}
server: send reply ('127.0.0.1', 42656)
server: closed connection ('127.0.0.1', 42656)
corederoma82
Post by corederoma82 » Saturday 19 May 2018 12:34
This message is invisible :D
Nice.
Jheronymus
Post by Jheronymus » Sunday 20 May 2018 12:11
Nice.
No it's not.
As the name of the topic suggest and you can read on the linked github in the first post; it's for the Xiaomi Mi Robot Vacuum.
http://www.mi.com/roomrobot/
The only question you can ask next is if the newer V2 model is compatible. I think no one reported using that one yet and nothing is mentioned on the python-miio page, but I from the looks of it, it is using the same miio interface and i would guess it will work.
Users browsing this forum: No registered users and 4 guests
