Aquarium Monitoring
MasterCATZ
Target OS: Raspberry Pi
Aquarium Monitoring
Post by MasterCATZ » Friday 04 August 2017 8:20
anyone willing to accept the challenge to add code for PH / EC / DO / NH4 & NO3 Probes ?
ie) https://www.sparkfun.com/categories/146
as I am sure most homes have Aquariums end users might want to data log and have alert notifications for ?
willing to donate
ben53252642
Re: Aquarium Monitoring
Post by ben53252642 » Friday 04 August 2017 10:25
Already wrote code to support the Seneye Aquarium monitor
https://www.domoticz.com/forum/viewtopi ... 63&t=17544
MasterCATZ
Post by MasterCATZ » Friday 04 August 2017 18:06
thanks but I consider those as a fake system
its a spectrometer that guesses based on colour / temp formula I looked into those a few years ago
most of the digital probes use I2C interface but the code does not seem to have many of the devices added
it does seem to support 8bit expanders but my probes are 12 bit
tlpeter
Post by tlpeter » Friday 04 August 2017 18:43
I did (untill this week) monitored the temperature with a waterproof temp sensor connected to MYSensors.
I also have a DHT22 in the bathroom which i am going to replace with a Sonoff th16 with a AM2301 which is also a DHT hum and temp sensor.
I just ordered another Sonoff TH16 with the waterproof temp sensor.
This one is going in to the water again.
manutremo
Post by manutremo » Friday 04 August 2017 18:51
I already have mysensors temp and pH probes in my aquariums. Would he very interested on NH4 and NO3. Do appropriate probes and sensors exist that can be hooked to an Arduino (at a reasonable price of course) ?
MasterCATZ
Post by MasterCATZ » Sunday 06 August 2017 0:03
the NH4 and NO3 probes I know of are over $1k ea
their are short term ones for $100 , but not for long term submersion
ideally looking for something that can be built using Spectrometry but that is a project on another forum
https://community.particle.io/t/sensors ... ite/6379/9
just a matter of finding opensource
http://hackaday.com/2015/08/11/simple-c ... en-source/
but for now i just want these sensors supported
https://www.sparkfun.com/products/12872
https://www.sparkfun.com/products/14090
https://www.sparkfun.com/products/11194
manutremo
Post by manutremo » Sunday 06 August 2017 9:03
Both the ORP and dissolved O2 sensors provide the option to use UART mode in addition to I2C. The manufacturer provides all the required information about both protocols and even provides some sample code, but doesn't seem to provide a suitable arduino library.
Searching through the inet I found the following which you could use as a base:
https://github.com/fab33/MySORP
http://www.instructables.com/id/ORP-pH- ... ta-Logger/
I also found other similar projects for the DO and pH sensors, so it shouldn't be too difficult to write your own version for your project.
For pH, the sensor you point to seems to require and additional interface. The same manufacturer seems to provide another option using a standard probe with a BNC connector:
https://www.amazon.com/Atlas-Scientific ... arduino+ph
Another option is using the following breakout board, which is widely used with arduino:
https://www.amazon.com/SainSmart-Detect ... arduino+ph
Another varation:
https://www.amazon.com/Analog-Arduino-A ... arduino+ph
I hope this helps.
Rostikator
Post by Rostikator » Tuesday 05 June 2018 11:00
Anybody who connect Neptune Apex to Domoticz ( https://www.neptunesystems.com/ )
hardware for reef aqua with own web server.
status.xml , example of measured data and settings over xml
status.xml
(3.45 KiB) Downloaded 33 times
i5+W2K12+Domoticz+EQ3+RFLink
SjoerdNLD
Post by SjoerdNLD » Monday 02 July 2018 20:25
Can confirm mysensors + arduino zero works good.
Had only a groundloop problem with pH, but using a i2c adc and i2c / 5v isolator, it works like a charm, very steady.
Output to 4 ledstrips and input from 2 flowmeters, pH sensor and ds18b20 temp sensor;
