iPhone Safari - empty homepage
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
vladtsit
Post by vladtsit » Monday 31 July 2017 20:05
Hi!
I checked all forum but cannot find a answer how to resolve problem with iPhone Safari browser. When I trying to open Domoticz homepage on local network I'm getting empty page (attached).
I'm running latest stable build on Windows.
Please help!
Thank you,
Vladimir
bluepi
Target OS: Raspberry Pi
Re: iPhone Safari - empty homepage
Post by bluepi » Monday 31 July 2017 20:10
Basic auth?
Does it work if you turn it off?
vladtsit
Post by vladtsit » Monday 31 July 2017 20:22
Tried with Login page, tried by adding local network exception for login. Nothing helped.
BTW API calls work seamlessly.
droop
Post by droop » Tuesday 01 August 2017 9:00
i have the same problem since i update to 3.8153 on a raspberry pi and ngnix
regards
droop
Post by droop » Tuesday 01 August 2017 9:32
In fact when i use safari in non private mode, it works. When i use Safari in Private Mode i have the problem.
regards
Cidex61
Post by Cidex61 » Tuesday 01 August 2017 16:35
Everything was working with Version 3.5878.
Unfortunately I have just updated to 3.8153 on a raspberry pi... And I get the same problem with iOS Safari.
I have tested the problem with iOS 9.3.5 on a iPad and iOS 10.3.3 on an iPhone:
I confirm that the empty page arrived only if Safari is set to private browsing, it appears for both local connection (192.168.0.###) and remote connection (www.#######.com).
Firefox on a computer is working and my iOS app "Pilot" is also working...
Thank for helping,
Regards,
bluepi
Post by bluepi » Tuesday 01 August 2017 21:41
I get a similar thing on the Mac using Safari 10.1.1 with basic-auth (Pi2 Domoticz Version: 3.8153)
Cidex61
Post by Cidex61 » Thursday 03 August 2017 16:47
Any idea ?
Because it will take 6 months for the next update of domoticz... So during 6 months we will have trouble using our iDivices :cry:
Domotizer
Domoticz version: 3.8153
Post by Domotizer » Saturday 05 August 2017 14:13
Hi All,
I have the same problem with Domoticz v3.8153 and Safari 10.1.2.
Firefox is working well.
Any news on that?
tom789
Post by tom789 » Sunday 06 August 2017 9:06
gizmocuz
Post by gizmocuz » Sunday 06 August 2017 13:00
There have been some changes recently (today/yesterday)
Mac systems:
- Clear your browser AND appcache (two different things)
iOS:
If you have added domoticz from safari to your homescreen, delete the icon there
From 'Settings'/Safari, clear all browser data
Now you should be fine again
iOS:
Once on the dashboard page, add a shortcut to your homescreen for the native app
Domotizer
Post by Domotizer » Sunday 06 August 2017 14:21
Hello all,
All the tricks didn't work.
Thats because the real reason for black screen was: "Browsing in Private Mode"!
In Safari private following error occurs:
[Error] QuotaExceededError (DOM Exception 22): The quota has been exceeded.
(anonyme Funktion) (domoticz.xyz.de:279)
i (jquery-1.12.0.min.js:2:27457)
fireWith (jquery-1.12.0.min.js:2:28217)
ready (jquery-1.12.0.min.js:2:30020)
K (jquery-1.12.0.min.js:2:30376)
So, simply don't use private browsing for Domoticz and everything is fine again!!!
On iOS devices the issue will also happen in safari private mode
Thanks for spending time to help with that issue!
D.
gizmocuz
Post by gizmocuz » Sunday 06 August 2017 17:30
Thanks fur the feedback... Maybe you can specify the appcache size or disable this on private mode...
Do you have the range issues with chrome?
Domotizer
Post by Domotizer » Sunday 06 August 2017 19:52
It's just Safari throws in private mode.
What i found out is Safaris didn't support localstorage in private mode. Others also report about this behavior: https://forums.developer.apple.com/thread/71593
It seems Safari expose a feature and later didn't grant to allocate these resources. Strange...
Thanks,
D.
zicht
Domoticz version: 3.8xxx
Post by zicht » Monday 07 August 2017 9:38
Domotizer wrote:What i found out is Safaris didn't support localstorage in private mode.
There are more platforms where private browsing does not support caching anymore, like television browsers, and other equipment with embedded browsers. In most cases is turning off private browseing solves it. Looks like manufacturers disencourage the use of private browsing.
Never the less even Chrome is now also posting messages in the console log :
running local network on http: 8080
[Deprecation] Use of the Application Cache is deprecated on insecure origins. Support will be removed in the future. You should consider switching your application to a secure origin, such as HTTPS. See https://goo.gl/rStTGz for more details.
running on local network https: 443
Application Cache Error event: Manifest fetch failed (9) https://192.168.178.208/html5.appcache
192.168.178.208/:85 GET https://192.168.178.208/css/remote.css net::ERR_INVALID_CHUNKED_ENCODING
jquery-1.12.0.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
Rpi & Win x64. Using : cam's,Nest,RFXCom,Kaku,LaCrosse,RFY,IsAlive,Dummy,Wether Underground, standard Lua, Curl on windows,Domoticz Android App & Tasker,
"The only source of knowledge is experience (A.Einstein)"
Dutchsea
Domoticz version: V3.4834
Post by Dutchsea » Thursday 04 January 2018 21:24
I also have this issue for half a year or so.
Just in Safari on iphone6 (latest ios).
Via Chrome app on iphone I have perfect access to Domticz. (both via home wifi and via internet)
Just there is no way to create a shortcut on iphone for a chrome page.
So it would be a very nice to have to have the safari issue resolved.
Any suggestions as it seems many users have no problems with this???
Regards,
Dutchsea
Raspberry PI 2B, Razberry, RFXCOM, OpenZwave (live)
Raspberry PI 3B, Aeon Z-Wave G5 stick, RFXCOM, OpenZwave (test)
Dutchsea
Post by Dutchsea » Saturday 13 January 2018 14:46
No ideas anyone?
jono
Post by jono » Wednesday 16 May 2018 20:57
vladtsit wrote:Hi!
Please help!
Thank you,
Vladimir
Hi Vladimir
Did you managed to resolve the issue nines just started doing it after DOMOTICZ restore
Thanks in advance
Jon
raceeend
Post by raceeend » Thursday 17 May 2018 22:56
Version: 3.8153
Platform: Pi 1
Plugin/Hardware:
I had the same problem with safari on a iPhone 6S and android devices.
After a "curl -L install.domoticz.com | sudo bash" update and the question if https access was required, I turned https access on.
The problem still occurs using the http://IP-address:8080 access but does not occur when using the https://ip-address:443 access.
Regards,
Race-eend
Users browsing this forum: No registered users and 5 guests
