Onkyo Plugin Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
JimmyH1969
Onkyo Plugin
Post by JimmyH1969 » Monday 31 July 2017 14:54
In the latest version the Onkyo plugin is integrated right?
When i add the hardware, IP adress and Port, i'm seeing this in the log:
2017-07-31 14:45:13.672 OnkyoAVTCP: Send PWRQSTN
2017-07-31 14:45:13.672 OnkyoAVTCP: Send MVLQSTN
2017-07-31 14:45:13.672 OnkyoAVTCP: Send ZPWQSTN
2017-07-31 14:45:13.672 OnkyoAVTCP: Send ZVLQSTN
2017-07-31 14:45:13.672 OnkyoAVTCP: Send SLIQSTN
2017-07-31 14:45:14.733 OnkyoAVTCP: Packet received: 8 PWR00
2017-07-31 14:45:14.733 OnkyoAVTCP: Packet received: 8 MVL17
2017-07-31 14:45:14.733 OnkyoAVTCP: Packet received: 8 ZPW00
2017-07-31 14:45:14.733 OnkyoAVTCP: Packet received: 9 ZVLN/A
2017-07-31 14:45:14.733 OnkyoAVTCP: Packet received: 8 SLI01
But thats all. Shouldnt there be any buttons created? Am i missing something? :?
jorgh
Target OS: Raspberry Pi
Domoticz version: 3.8224
Re: Onkyo Plugin
Post by jorgh » Monday 31 July 2017 15:30
@JimmyH1969,
That is not a plugin, there is also some native support within Domoticz now, the functionality at this time seems more limited than the plugin, but it should work. You need to configure the IP and port number for the plugin to work.
The switches can that be added from Setup->Devices.
Regards,
Jorg
JimmyH1969
Re: Onkyo Plugin
Post by JimmyH1969 » Monday 31 July 2017 15:44
Hi Jorgh,
I am talking about the native support from within Domoticz. I configured the IP and PORT and i see in the log there is communication. I dont see any devices being created in Setup ->Devices. Not sure what the build-in Onkyo device should do. All it does in the log once is:
gizmocuz
Re: Onkyo Plugin
Post by gizmocuz » Monday 31 July 2017 15:49
'Accept new devices' enabled in the settings ?
JimmyH1969
Re: Onkyo Plugin
Post by JimmyH1969 » Monday 31 July 2017 16:15
Oke, that was my second stupid question for today. enabling Accept new Devices did the trick :oops:
Thank you!
baseship
Domoticz version: 3.4834
Re: Onkyo Plugin
Post by baseship » Thursday 15 March 2018 15:27
i can't turn my TX-NR414 with native supprt on,
Master Volume and turn off is OK...
anyone an idee?
Raspberry Pi B / B+ / 2
Aukru 433 MHz Modul
Intertechno
DS18b20 tempsensors
JimmyH1969
Re: Onkyo Plugin
Post by JimmyH1969 » Thursday 15 March 2018 18:11
I had to change the standby parameters in my Onkyo for that.
It's called something like "Network Standby" and needs to be "On"
baseship
Re: Onkyo Plugin
Post by baseship » Friday 16 March 2018 15:29
Thanks Jimmy!
Aukru 433 MHz Modul
Intertechno
DS18b20 tempsensors
leecollings
Re: Onkyo Plugin
Post by leecollings » Tuesday 08 May 2018 13:52
I've also just obtained a TX-NR414, and the Power, Volume and Zone2 power work fine with the native Domoticz plugin.
But is there anyway to change the input source via a switch?
biggles
Re: Onkyo Plugin
Post by biggles » Wednesday 09 May 2018 22:48
Hi there,
You should see a: Onkyo Output Selector in you device list.
First make sure you switch input a couple of times.
Under switches you should also see this output selector. It has a pulldown menu with all the outputs.
Biggles.
leecollings
Re: Onkyo Plugin
Post by leecollings » Thursday 17 May 2018 17:30
Am I right in assuming this is on the Beta release?
I'm on the stable, and don't see any devices to do with inputs, just the three I have already mentioned.
Users browsing this forum: JoergZ, XerachCruz and 8 guests
