[122] Philips Hue support Topic is solved
TroisSix
Target OS: Raspberry Pi
Domoticz version: 3.8153
Re: [122] Philips Hue support
Post by TroisSix » Monday 29 May 2017 10:22
This works very well on my pi3, but I still can't make it working with my Synology DS412+ cause I have a compatibility problem with core.so files.
If anyone has an idea, I will take it ;)
The errors:
...error loading module 'socket.core' from file '/usr/local/lib/lua/5.2/socket/core.so':
/usr/local/lib/lua/5.2/socket/core.so: invalid ELF header
or
/usr/local/lib/lua/5.2/socket/core.so: wrong ELF class: ELFCLASS32
Thanks for your help !
Domoticz stable v3.8153 (Pi3), RFXCOM RFXtrx433, Aeotec Z-Stick Gen5, APC ES700
- rts: dio, oregon, somfy
- zwave: aeotec extender, fibaro fgs212 switch, aeotec smart switch gen5, vision ZG8101
- logitech harmony hub, philips hue, gps Pilot
djac
Post by djac » Tuesday 24 October 2017 10:08
New here!
I have been using Hue with Philips lamps for some time, works fine. Now I added Ikea Trådfri bulbs and I see some issues when they go across to Domoticz. The ambient lamps shows up as dimmable, but I can't set the tone from Domoticz, and the colored bulb comes up as only on/off.
Looking in the HUE app they works fine, I can set tone and colors.
What i find a bit strange is that the colored lamp shows in "Scenes" with the option to set color.
Can anyone confirm that this is the best we can achieve at this point, or if not, suggest work arounds?
Stockfisch
Post by Stockfisch » Friday 27 October 2017 17:14
Hi guys
I'm having exactly the same issue as TroisSix above.
I'm on odroid c2.
My log says:
Error: EventSystem: in Upadate_hue_LUA: error loading module 'socket.core' from file '/usr/local/lib/lua/5.2/socket/core.so':
I believe that's because the socket is build for the wrong architecture. Right?
Thanks Dirk
EDIT:
Fixed it:
I've installed the correct LUA socket for my architecture from the package manager
sudo apt-get install lua-socket
and then added symlinks to the location domoticz expects the files to be
ln -s /usr/lib/aarch64-linux-gnu/lua/5.2/socket/ /usr/local/lib/lua/5.2/socket/
ln -s /usr/lib/aarch64-linux-gnu/lua/5.2/mime/ /usr/local/lib/lua/5.2/mime/
Regards Dirk
NUC5CPYH - Proxmox VE - Ubuntu 18.4
Goldwing1973
Domoticz version: Stable
Post by Goldwing1973 » Sunday 11 February 2018 21:18
For the last week i’m having a lot of problems with Domoticz controlling my Hue Lights.
A lot of times If “forgets” turning a light on, off or at the right color/brightness.
This is only When i Control them from my iPad (Domoticz web) or from a z-wave wall switch.
When i Control them from a Hue TAP it works fine.
It started around the time I did a software update on the bridge.
I already tried to power off (and back on) the Domoticz server and Hue Bridge, but that didn’t make a difference.
Domoticz version V3.8342
Hue Bridge sw version 1801260942
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
RikkieB
Domoticz version: 4.9732
Post by RikkieB » Friday 22 June 2018 21:19
Since the beta V3.9672 the status of the Hue bulbs (as a switch) isn't coming back in domoticz. I installed a new hue bridge on the hardware page and disabled the previous one. Scenes and groups are imported, also the motion sensor, but the bulbs are not imported. Who sees the same? And what to do about it? I restarted domoticz, Hue bridge, PI and router, no luck.
thx
Rik
Wob76
Post by Wob76 » Tuesday 10 July 2018 15:23
RikkieB wrote:Hi,
thx
Rik
I am also seeing this, moved to the new stable and status of bulbs no longer update.
Sent from my SM-G935F using Tapatalk
Post by waaren » Tuesday 10 July 2018 15:45
This is solved in recent beta's
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Wob76
Post by Wob76 » Tuesday 10 July 2018 22:42
waaren wrote:This is solved in recent beta's
Thanks for the info, I was hoping to stick with stable, but I'll update today.
Wob76
Post by Wob76 » Tuesday 10 July 2018 23:27
Confirming it is working as expected with 4.9758.
On the hardware what should the poll interval be? I had it as 0 before and all working, tried a value to see if it fixed (before update), back to 0 now. Just wondering what it does with this hardware?
Wob
kimhav
Domoticz version: 4.9895
Post by kimhav » Thursday 16 August 2018 22:00
Running with Domoticz v4.9863 and the Philips Hue works fine, but did have to disable and enable the Philips Hue Gateway to get it to import the devces, groups and scenes.
Speaking of groups and scenes are there any progress on ensuring that they'll be added under Domotics Scenes instead of Switches?
Member of Domoticz Sweden Telegram Group
