Dashticz - Function - Graphs
Moderators: robgeerts, htilburgs
astrapowerrr
Re: Dashticz - Function - Graphs
Post by astrapowerrr » Friday 18 May 2018 11:19
hi is it possible to change my p1 toon graph to see my actual usage instead of total usage? also for the gas meter
and can i set with what parameters the graphs are?
i would like to create my dashboard just like the original toon layout
EdwinH
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by EdwinH » Tuesday 03 July 2018 8:44
Does graph function support IDX with three digits ?
I have in Domoticz twice my solar panels..
IDX 66 generated by omnik script and recently IDX 945 , generated by Domoticz by import PVOutput.
Graph_66 works but does not show solar curve (Power generated( see screenshot)
I think I got cause of no solar curve : I use 3 PVOutput and imported power usage into Solar ID
When I change (in CONFIG.js) 'graph_66' to 'graph_945' it does not show graphics.
I tested with some more utility sensors of domoticz, it looks like graph function does not works when idx is set above 99.
Ccan some one confirm or point me in right direction?
stavroshamster
Re: Could not load graph message
Post by stavroshamster » Saturday 11 August 2018 11:24
@whatisk
whatisk wrote:
Monday 29 January 2018 9:26
Also, is there a way to change the number format/separator in Dashticz? Ie: have a comma as the thousand separator and a dot as the decimal point.
To change the number format, you need to edit the 'main.js' file:
var _THOUSAND_SEPARATOR = '.';
var _DECIMAL_POINT = ',';
to
var _THOUSAND_SEPARATOR = ',';
var _DECIMAL_POINT = '.';
Did the trick for me...
