Baldr Temp Humidity sensor
Spotted a nice hardware deal? Share here!
JHO01
Target OS: Raspberry Pi
Domoticz version: 49700
Post by JHO01 » Saturday 08 July 2017 12:19
This device works out of the box with RF-link
https://nl.aliexpress.com/item/Baldr-Wi ... f4bfb714fb
RPI-3, Z-stick Gen5, RFlink, 1-wire DS18B20, Fibaro switches, various RF-433 sockets, , BMP018
Mozart
Re: Baldr Temp Humidity sensor
Post by Mozart » Saturday 08 July 2017 12:27
Your link is not working. Do you mean this product?
https://nl.aliexpress.com/item/Baldr-Wi ... 78320.html
Raspberry 3
Aeon Labs Z-Wave Stick Series 2 - RFLink USB Gateway
Z-Wave switches
433 MHz Temperature + Humidity sensors
Philips Hue Lights
Mi-Light WiFi Bridge + RGBW Controllers
JHO01
Post by JHO01 » Saturday 08 July 2017 12:59
Yep that's the one, thnx I have updated the link in the above post
desertdog
Domoticz version: 4.9700
Post by desertdog » Friday 21 July 2017 19:12
How did you get it connected to the domoticz system. I tried all 3 channels and pressing the test button, but the device doesn't show up in the device list
JHO01
Post by JHO01 » Friday 21 July 2017 19:44
The device simply became visible on the list of unused devices. You have to browse through the listing, which can be long.
In my case the device appeared als Baldr.[img]
Screen Shot 2017-07-21 at 19.40.57.png (79.92 KiB) Viewed 2045 times
[/img]
desertdog
Post by desertdog » Friday 21 July 2017 19:49
It doesn't show up in my device list. Discovery is on, so I guess it had something to do with the software/firmware version
I have
- Domoticz Version: 3.5877 Build Hash: 15b013c
- RFXtrx433 USB 433.92MHz Transceiver // Ext2/1019
Which versions do you have?
tonbor
Post by tonbor » Saturday 22 July 2017 16:31
desertdog wrote:How did you get it connected to the domoticz system. I tried all 3 channels and pressing the test button, but the device doesn't show up in the device list
rflink is not rfxcom
Verstuurd vanaf mijn SM-T813 met Tapatalk
JHO01
Post by JHO01 » Sunday 23 July 2017 13:56
Domoticz V3.8114
RFLink: R46
corederoma82
Post by corederoma82 » Monday 21 August 2017 16:20
Whic is the procedure to install it in domoticz?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826
