Beta 3.8035: log file full of Python: xxx messages
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pavelbor
Target OS: Raspberry Pi
Domoticz version: LastBeta
Post by pavelbor » Tuesday 04 July 2017 10:59
in last beta 3.8035: log file full of Python: xxx messages. Log file grow up very fast. Is it possible to disable logging of python messages ?
2017-07-04 11:58:11.318 Hardware Monitor: Fetching data (System sensors)
2017-07-04 11:58:11.336 Python: Changed: ID: 43 Name: Memory Usage, Type: 243, subType: 6, switchType: 0, s_value: 26.68, n_value: 0, n_value_string: 26.68, last_update_string: 2017-07-04 11:58:11
2017-07-04 11:58:11.337 Python: Number of user_variables: 2
2017-07-04 11:58:11.337 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:11.337 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:11.394 Python: Changed: ID: 47 Name: CPU_Usage, Type: 243, subType: 6, switchType: 0, s_value: 5.58, n_value: 0, n_value_string: 5.58, last_update_string: 2017-07-04 11:58:11
2017-07-04 11:58:11.394 Python: Number of user_variables: 2
2017-07-04 11:58:11.394 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:11.394 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:11.431 Python: Changed: ID: 44 Name: HDD /boot, Type: 243, subType: 6, switchType: 0, s_value: 39.73, n_value: 0, n_value_string: 39.73, last_update_string: 2017-07-04 11:58:11
2017-07-04 11:58:11.431 Python: Number of user_variables: 2
2017-07-04 11:58:11.432 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:11.432 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:11.475 Python: Changed: ID: 45 Name: HDD /, Type: 243, subType: 6, switchType: 0, s_value: 67.00, n_value: 0, n_value_string: 67.00, last_update_string: 2017-07-04 11:58:11
2017-07-04 11:58:11.475 Python: Number of user_variables: 2
2017-07-04 11:58:11.475 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:11.475 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:11.509 Python: Changed: ID: 46 Name: RPi1 CPU Temperature, Type: 80, subType: 5, switchType: 0, s_value: 39.6, n_value: 0, n_value_string: 39.6, last_update_string: 2017-07-04 11:58:11
2017-07-04 11:58:11.510 Python: Number of user_variables: 2
2017-07-04 11:58:11.510 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:11.510 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:12.258 Python: Changed: ID: 56 Name: Lux, Type: 246, subType: 1, switchType: 0, s_value: 3672, n_value: 0, n_value_string: 3672, last_update_string: 2017-07-04 11:58:12
2017-07-04 11:58:12.258 Python: Number of user_variables: 2
2017-07-04 11:58:12.258 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:12.258 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:13.288 Python: Changed: ID: 5 Name: Кухонный балкон: 1-wire розетка, Type: 80, subType: 5, switchType: 0, s_value: 20.6, n_value: 0, n_value_string: 20.6, last_update_string: 2017-07-04 11:58:13
2017-07-04 11:58:13.289 Python: Number of user_variables: 2
2017-07-04 11:58:13.289 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:13.289 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:13.327 (1-wire) Temp (Кухонный балкон: 1-wire розетка)
2017-07-04 11:58:31.128 Python: Changed: ID: 6 Name: Кухня: PIR датчик температуры, Type: 80, subType: 5, switchType: 0, s_value: 22.1, n_value: 0, n_value_string: 22.1, last_update_string: 2017-07-04 11:58:31
2017-07-04 11:58:31.128 Python: Number of user_variables: 2
2017-07-04 11:58:31.129 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:31.129 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:31.165 (1-wire) Temp (Кухня: PIR датчик температуры)
2017-07-04 11:58:33.367 Python: Changed: ID: 28 Name: Maxim: BMP085 Temp, Type: 247, subType: 1, switchType: 0, s_value: 21.6;998.1;1;415.51, n_value: 0, n_value_string: 21.6;998.1;1;415.51, last_update_string: 2017-07-04 11:58:33
2017-07-04 11:58:33.367 Python: Number of user_variables: 2
2017-07-04 11:58:33.367 Python: User-variable 'XiaomiMP3' has value: 10001
2017-07-04 11:58:33.367 Python: User-variable 'XiaomiMessage' has value: -1
2017-07-04 11:58:33.404 (Max temp/давление) Temp + Baro (Maxim: BMP085 Temp)
pavelbor
Re: Beta 3.8035: log file full of Python: xxx messages
Post by pavelbor » Tuesday 04 July 2017 11:40
I have found solution here
melgi
Post by melgi » Monday 11 June 2018 9:23
Does anybody know to what solution the reference was as the link looks dead. I have the same issue with my current beta version 3.9616 and wanted to see if the mentioned solution would work for me.
Users browsing this forum: waaren and 18 guests
