Python plugin: UPS Monitor
ycahome
Domoticz version: lat Beta
Re: Python plugin: UPS Monitor
Post by ycahome » Thursday 15 February 2018 21:51
Also, am wondering if you could include a bash script on your plugin in order to update with a single command:
filename: upgrade.sh
#!/bin/bash
git reset --hard
git pull --force
sudo chmod +x plugin.py
sudo chmod +x upgrade.sh
sudo /etc/init.d/domoticz.sh restart
this way, next time you can upgrade with a single command
sudo ./upgrade.sh
Logread
Target OS: Raspberry Pi
Post by Logread » Friday 16 February 2018 0:00
@ycahome,
Thanks for the suggestions... please feel free to contribute the script on GitHub and/or the wiki
hamster
Post by hamster » Saturday 17 February 2018 7:05
Logread wrote:
Thursday 15 February 2018 15:13
New version 0.2.1 is available.
AWESOME! Will install and begin testing.
manutremo
Post by manutremo » Saturday 17 February 2018 9:18
Hi, just wanted to let you know that I just installed it on my Synology and it works perfect. Many thanks!
Logread
Post by Logread » Saturday 17 February 2018 18:24
Thanks for the positive feedback 8-)
nmaster
Domoticz version: 3.6304
Post by nmaster » Saturday 17 February 2018 20:01
Hi Logread,
I upgraded to the last plugin version, all is fine here with 4 UPS.
Velly
Post by Velly » Sunday 18 February 2018 16:05
Help needed with EATON 9130 running on Windows 10:
EATON 9130
ip of Windows server : 192.168.1.107
port: 4679
Usp name in EATON Intelligent Power Manager: EATON9130
error:
2018-02-18 16:57:52.553 Error: (UPS EATON) Error reading UPS variables: HTTP/1.0 501 Not Implemented
2018-02-18 16:58:44.241 Error: (UPS EATON) Error reading UPS variables: HTTP/1.0 501 Not Implemented
2018-02-18 17:00:09.587 Error: (UPS EATON) Error reading UPS variables: HTTP/1.0 501 Not Implemented
2018-02-18 17:01:18.703 Error: (UPS EATON) Error reading UPS variables: HTTP/1.0 501 Not Implemented
2018-02-18 17:02:18.751 Error: (UPS EATON) Error reading UPS variables: HTTP/1.0 501 Not Implemented
Anybody with NUT on Windows Intelligent Power Manager?
Thank you!
eaton 3.PNG (18.07 KiB) Viewed 1651 times
hamster
Post by hamster » Monday 19 February 2018 2:35
Latest update working great for me on pi Logread. Thanks!
Logread
Post by Logread » Monday 19 February 2018 8:27
@Velly, looks like you are configuring the plugin to hit a http webserver (the Eaton intelligent power manager) rather than a NUT server... first make sure you have a NUT server up and running and adjust to the right IP/Port
jeecee
Post by jeecee » Tuesday 27 February 2018 14:48
Tnx a lot, works perfectly!
febalci
Post by febalci » Wednesday 14 March 2018 21:52
@Logread, thanks for the great work! Works perfectly with 2 APC BX950U-GR UPSes. One of them is installed on a Synology and the other one on ubuntu Domoticz Server Intel NUC. Everything works perfectly, i also set a notification on UPS Alert Sensor; If svalue is 'ONBATTERY DISCHARGING', send a notification as 'Power Cut!!!', If 'ONLINE CHARGING' send 'Power Back ON!'. However, as you have guessed the status change waits up to 1 minute for UPS Status update. Is there any way you can suggest for the status change to be reflected instantenously?
Thanks again...
copernicnic
Post by copernicnic » Thursday 26 April 2018 10:34
Hello, thanks for the plugins :D . I have a little worry with nut, my ups is directly plugged into my raspberry and the server nut is also on the raspberry. my problem is that i can not disable user / password access.
do you have an idea of ​​how?
Logread
Post by Logread » Friday 27 April 2018 7:39
@copernicnic, authentication is not yet handled by the plugin. Not difficult to implement, bear with me for a few days and I’ll send you by pm a new version for testing.
copernicnic
Post by copernicnic » Friday 27 April 2018 10:57
hello, everything is ok now :D :D , just wait a moment that domoticz update the device.
do you know what value to put in the event to make interact?
screenshot 2018-04-27 à 10.54.41 1.jpg (34.77 KiB) Viewed 1181 times
Thank you very much for your work
copernicnic
Post by copernicnic » Friday 27 April 2018 11:32
@Logread,
I just tested the plugin you sent me, it does not work unfortunately. here is the log
The attachment screenshot 2018-04-27 à 11.28.57.jpg is no longer available
I just saw in the command that there is a story of master and slave
screenshot 2018-04-27 à 11.31.21.jpg (49.13 KiB) Viewed 1177 times
screenshot 2018-04-27 à 11.28.57.jpg (38.82 KiB) Viewed 1179 times
Logread
Post by Logread » Friday 27 April 2018 19:18
@copernicnic, let’s debug this by private message rather than posting on the public thread, to avoid clogging it... in my last pm, I told you that the edits were not tested... since my own setup does not require a login. Let me do some investigations in the network ups tools code and docs but this will not be before several days.
In the meantime, if you have the knowledge to do this, please try to login from shell with a telnet session and post me the result by pm, not on the forum thread pls.
toutazimuth
Post by toutazimuth » Friday 11 May 2018 20:47
Hi Logread
Your Python plugin UPS monitor, works perfectly with my Pi3B, Python 3.4, Domoticz béta 9424, Synology and eaton 650 Pro.
everything is great
Thx ;)
Logread
Post by Logread » Saturday 12 May 2018 14:27
Hi Logread
everything is great
Thx ;)
Thanks for your appreciation !
lmet
Domoticz version: v4.9700
Post by lmet » Wednesday 01 August 2018 14:31
Now i have UPS Monitor working fine on Domoticz 4.9700 using stretch.
For me the reason was python version 3.5.1.x after downgrade it to 3.4.1.x all is Ok now.
Thanks a lot for this very usefull plugin.
legus49
Domoticz version: 3.7207
Post by legus49 » Monday 05 November 2018 2:34
I just installed UPS Monitor and it's working fine on Domoticz 3.7207, but I do not have the units for the sensors (Volt, %, W...) Any idea ?
