Domoticz compatibility with debian 9 stretch
ebretteville
Target OS: Raspberry Pi
Domoticz version: 2.3530
Post by ebretteville » Monday 19 June 2017 14:15
As debian 9 codename stretch is out, raspbian should come along with this new packets as default:
- PHP
- MariaDB
So my question is: "Is domoticz is/will (be) compatible with this new packages?!
Thx
MacJL
Target OS: OS X
Re: Domoticz compatibility with debian 9 stretch
Post by MacJL » Monday 19 June 2017 14:52
I don't think PHP and MariaDB will impact domoticz, as domoticz does'nt use them.
But I tried to use Stretch, and I have this issue at start :
/domoticz/domoticz: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
In stretch, libssl is at version 1.1.0.
Egregius
Post by Egregius » Tuesday 20 June 2017 8:14
Is the libssl error only valid if you use https? Or always?
I'd like to update to Debian Stretch. Just updated my 3 pikrellcams and it went smoothly without any issues.
First thing I noticed in Debian Stretch is a huge memory usage difference. A freshly booted pi with Jessie used 150MB memory, one with stretch 56MB.
MacJL
Target OS: OS X
Post by MacJL » Tuesday 20 June 2017 9:52
Thank you for your response Egregius. I'm running domoticz in a docker container on x86_64 architecture. So I've installed the minimum packages for make it work, whicl include libssl-1.1.0. And the start options doesn't specify anything about https.
Could you tell me which version of libssl do you have installed ? Are you using domoticz pre-compiled binaries, or do you build it from sources?
Egregius
Post by Egregius » Tuesday 20 June 2017 9:56
If you set the ssl port to 0 it will be disabled.
Can't check versions right now, updating to Stretch... Will soon know if mine keeps running...
MacJL
Target OS: OS X
Post by MacJL » Tuesday 20 June 2017 21:06
I tried disabling https, and still have the error.
Does your upgrade complete? Have you the same problem?
Egregius
Post by Egregius » Tuesday 20 June 2017 21:31
Well...
Domoticz ran
Lighttpd ran
But I had a major issue with pages that embed the camera mjpeg streams so I reverted back to Jessie.
ben53252642
Post by ben53252642 » Monday 28 August 2017 7:24
Solution for me (64bit Debian Stretch):
1) Download https://packages.debian.org/jessie/amd6 ... 0/download
2) dpkg -i libssl1.0.0*
